Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 7, 2019 at 7:35 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ya, clicks and cranks but doesent turn over.
    Yes, like 6 months ago. Not stoked lol
    hopefully if it's a sensor or something easy, and not catastrophic it won't turn back on or go to limp mode...I have almost no tools except a socket set and some pliers, so I can't really do much
  2. Aug 7, 2019 at 7:49 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I mean it *sounds* like it's cranking full strength, all internal electronics seem to worm fine, I'm walking to an auto parts store now to borrow a code reader. I'll get a wire brush and but the connectors while I'm at it.
    The shop it got towed to is like "well we will see if we can get to it this morning" and I'm like come on I'm stranded In your methy town, give me a time here
  3. Aug 7, 2019 at 7:58 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya probably. I'll do that and see if I can get a spark plug out, dobtful, I don't even have my long needle nose pliers that I usually pull that out with. I'm all alone at the moment
  4. Aug 7, 2019 at 8:34 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well I have no idea how, but it's showing no codes, which makes no sense because I know there should at least be an O2 exhaust code since the cat is gutted. I know that mother fuckers was on when it died
    m3bassman likes this.
  5. Aug 7, 2019 at 10:23 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    It's at the shop, in the mechanics hands now.fuck it
  6. Aug 7, 2019 at 11:31 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sorry to hear about the trouble Mark. I'd come join you for a beer and some moral support but I'm 9 hours away and gotta do this work thing... :pout:
  7. Aug 7, 2019 at 12:00 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  8. Aug 7, 2019 at 12:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hopefully just the distributor or something failed.
  9. Aug 7, 2019 at 3:06 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Bad fuel pump. Expensive fix, but whatever. Life
    What terrible timing, why can't it die on the way to work in town, not on highway at 1am in fucking montana
  10. Aug 7, 2019 at 4:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn man. If it makes you feel any better mine died a slow annoying death in my DD. Hope a good one was put in!
  11. Aug 7, 2019 at 7:12 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  12. Aug 7, 2019 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    jubei and BossFoss[QUOTED] like this.
  13. Aug 8, 2019 at 6:50 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Hard to believe it’s been 13 years...
    I’m planning on basically listening to this on repeat all day today at work
    :headbang:
  14. Aug 8, 2019 at 4:42 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Lol I had it on loop today too :anonymous:,
    jubei[QUOTED] likes this.
  15. Aug 8, 2019 at 4:49 PM
    jubei
    NoCo
    Stuff. Also things.
    The full album drops the day before my birthday! Can’t wait!
    BossFoss[QUOTED] likes this.
  16. Aug 8, 2019 at 4:56 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Nice, going to preorder it from Amazon tomorrow hopefully. Maybe throw 10,000 days on there too since my disk has disappeared somehow.
  17. Aug 9, 2019 at 5:49 AM
    BossFoss
    Wyoming
    01 DC Tacoma
  18. Aug 9, 2019 at 6:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Aug 9, 2019 at 7:26 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    So huh @m3bassman, how’s that 3rd Gen treating you these days?
  20. Aug 9, 2019 at 8:40 AM
    JKO1998
    Utah
    You fooled me
