Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 17, 2019 at 10:33 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Didn't realize it is a hatchback. Thought it was a sedan for some reason. I forgot they offer more variations these days.
  2. Aug 18, 2019 at 11:25 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Not mine, though I suppose I could always use an extra, or an excuse to finally meet @Squeaky Penguin :D.
    Nice! Did you do the rebuild yourself? Details please. :thumbsup:
  3. Aug 18, 2019 at 12:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Nope. Replacing the seals and new oil should be fairly straight forward but without a way to recharge afterwards there is no point. I sent them off to Tim at 303 Shock Services @TMFF
    TMFF and jubei like this.
  4. Aug 18, 2019 at 12:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm kinda just betting on not making it to retirement, seems easier to leave someone with a hospital bill and call it a day compared to trying to actually retire as part of this generation.
    m3bassman likes this.
  5. Aug 18, 2019 at 12:53 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    :eek:
    retirement is not overrated.
    Digiratus likes this.
  6. Aug 18, 2019 at 12:55 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    So - for anyone who's pulled the rear axle seal...Timmy suggests an SST (slide hammer-thingy) for that, but I cant imagine that I couldn't just stick something in behind it and pull it out. Is it really hard to get out?
  7. Aug 18, 2019 at 12:59 PM
    Speedytech7
    Timmy's stuff is very much "by the book basic" a normal seal puller or a good screwdriver should work fine
    BossFoss and turbodb[QUOTED] like this.
  8. Aug 18, 2019 at 1:04 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I use a 12" prybar with the end taped up to prevent scratching.
    turbodb[QUOTED] and Speedytech7 like this.
  9. Aug 18, 2019 at 1:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not as unique as you might think. A little effort and planning goes a long ways when your in your mid-twenties.
    turbodb and Blackdawg[OP] like this.
  10. Aug 18, 2019 at 2:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's my play
    turbodb and Digiratus[QUOTED] like this.
  11. Aug 18, 2019 at 3:31 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You guys have any neat tricks or tips for taking pictures of the stars? The night sky at bear camp is pretty nuts when it’s clear.
    PFA
  12. Aug 18, 2019 at 3:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lots. What are you trying to achieve and what camera?
  13. Aug 18, 2019 at 3:33 PM
    JKO1998
    Utah
    Sony A6000, nothing too complicated I guess?
  14. Aug 18, 2019 at 3:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What kind of lenses do you have. And what does that mean? Like just starts? or trails?
  15. Aug 18, 2019 at 3:37 PM
    JKO1998
    Utah
    Stars, it has a 16-50 mm f3.5-5.6 lens and then one with more zoom or whatever.
    Obviously I’m a noob when it comes to this stuff
  16. Aug 18, 2019 at 3:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay. Typically you'll want wide for a few reasons. One is focus though, likely will struggle to get any focus on anything zoomed further than 18mm. You want the focus on Infinity which can be achieved at night by using a bright flash light to focus on that is as far away as possible. Once it is focused. Turn manual focus on and do not touch the focus ring.
    Every camera is a bit different, but a good place to start is 16mm - f4 - iso1600(up to 4000) - 30sec shutter.
    You will need a tripod no matter what.
    The goal is to get a little noise as possible but not always doable depending on the photo. You want as long of a shutter as possible. However too long and you'll start to get trails. But you'll be safe to do like 10 mins or so before its bad.
    But the higher the iso the more starts the camera will pick up. But noisier it'll get too.
    Getting a remote is wise but if you set your shutter timer to 2 sec delay when on a tripod thats all you really need to take just start photos like this
    [​IMG]Frank and FRV Under Stars by Monte Nickles Photos, on Flickr
    [​IMG]Reach for the Stars by Monte Nickles Photos, on Flickr
    To get into layering and star trails you'll want a remote and/or intervalmeter, which your camera might have built in, like these
    [​IMG]M~D~U-134.jpg by Monte Nickles Photos, on Flickr
    Then just practice practice practice. The darker your environment the better.
    The last set is of course editing. Star photos require the most editing of any photo I do to make it look good.
    jubei likes this.
  17. Aug 18, 2019 at 5:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I get dizzy every time I see this photograph. Some would say I tend a little that anyways so it probably doesn't take much... :rofl:
    Speedytech7 likes this.
  18. Aug 18, 2019 at 5:40 PM
    JKO1998
    Utah
    Guess Ill just stick to halved ass bear and lion pictures haha
    Thanks for the info
  19. Aug 18, 2019 at 6:52 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    So one of the guys I worked with is a photographer. Holy smokes, what the right equipment (a star-tracking tripod) and a little (more) knowledge (than we have) can do...
    66627388_10155970837505793_3109054262101_a2ceb96170066fc638b9d4149c3a89ba6e4c0da9.jpg
    jubei, BossFoss, Speedytech7 and 3 others like this.
  20. Aug 18, 2019 at 7:30 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You sure you want to wheel with me? Your truck will end up in a downward spiral of never-ending repairs. :bananadead:
    And while we're on the subject - at least once a trip I go try to get some star pictures. I take a few, then give up because they never turn out (probably because I have no idea what I'm doing). I would rather be enjoying a beer staring into the stars then trying to get the shot.
