Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 21, 2019 at 11:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice what kind of tuning?
  2. Aug 22, 2019 at 6:25 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's Nistune. We adjusted the fuel table to to clean up cruising AFR
  3. Aug 22, 2019 at 8:32 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Hurry before
  4. Aug 22, 2019 at 1:15 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Curious to what you find. I have a similar noise, just haven't cared enough to figure it out yet. Though it might just be my rack slipping in the D bushing since it's been self lubricated with 5w 30 since the turbo went in.
    m3bassman[QUOTED] likes this.
  5. Aug 22, 2019 at 6:16 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Been there. On my third set. Luckily my rod ends are still good (snap rings are pretty well dickered). I can usually hear a clunk when I hit pot holes if they start to go. It's faint but you'll hear it if you drive it every day
  6. Aug 22, 2019 at 8:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Psh. That's cute
    SconnieHailer likes this.
  7. Aug 22, 2019 at 8:24 PM
    JKO1998
    Utah
    It was my first time
    Blackdawg[QUOTED][OP] likes this.
  8. Aug 22, 2019 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty much coat everything in anti seize now.
    And if the photo I just posted above is any indication then yes that is a good idea. The bearings totally got seized together and then ate everything apart.
  9. Aug 23, 2019 at 7:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Aug 23, 2019 at 8:07 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Reh5108 likes this.
  11. Aug 23, 2019 at 8:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah haha no just the rtt.
  12. Aug 23, 2019 at 10:32 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I don't know if they frequent TW much anymore. Just read the last few pages of the GFC thread....
    They started their own GFC forum that they've been active on.
  13. Aug 23, 2019 at 10:45 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    For the money I'd wait for a true GFC, seems to be the best use of protecting stuff in the bed/camping without a true hardshell bed camper.
  14. Aug 23, 2019 at 11:01 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  15. Aug 23, 2019 at 11:04 AM
    JKO1998
    Utah
    Looks like another hard shell RTT to me
  16. Aug 23, 2019 at 11:10 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, i've seen it. Regardless, the GFC's value is as a camper with access to the tent from within and the tent purched on the spaceframe with side door access. Their RTT is an afterthought. Only there to appease SUV users.
  17. Aug 23, 2019 at 8:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    New mini shower showed up, thanks for the tip Brent. Looking forward to having an easy way to wash dishes.
    And power steering cooler showed up. I've noticed on Igor the reservoir has been overflowing a lot lately in the hot. So hoping this will help.
    PcBuilder14 likes this.
  18. Aug 23, 2019 at 8:45 PM
    Reh5108
    Idaho
    Haven't wedge style tents been around for a while now?
  19. Aug 23, 2019 at 8:47 PM
    Reh5108
    Idaho
    Anyone else fall through there bed?
  20. Aug 23, 2019 at 8:53 PM
    Squeaky Penguin
    Brett
    If so, they're probably not willing to admit it.
    I blame alcohol. :anonymous:
    Pltmnky, BossFoss and Reh5108[QUOTED] like this.
