Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 29, 2019 at 9:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's a costly weight loss plan. Maybe try one of those dietary pyramid schemes first... Or a different vehicle haha
  2. Sep 29, 2019 at 9:26 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The crossmember is the mount in the front and mid mounts.
    I believe the center of the crossmember drops down so it's not straight across. I think @jubei confirmed this.
    I'm pretty sure play sand is terrible for your health when used in a blaster.
    Speedytech7 likes this.
  3. Sep 29, 2019 at 9:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    While I admire the effort. The compromises will be a challenge regardless.
    m3bassman likes this.
  4. Sep 29, 2019 at 9:29 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I haven't been running my mid skid all year, so truck is actually lighter than that. :p
    Kinda thinking I'll never run it again. All it did was decrease ground clearance. Need to just make a little skid for the tcase and call it good. Not worried about the trans at all. Might be different with a slush box.
    Reh5108 likes this.
  5. Sep 29, 2019 at 9:30 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I think anything coming out of a blaster is terrible for your health. For sure whatever surface you're abrading is. I didn't figure I needed to tell him to wear a respirator. If I do, then you should get this one Ben.
    What's life without challenges?! ;)
  6. Sep 29, 2019 at 9:32 PM
    Speedytech7
    I did this challenge a long time ago remember my truck only weighed 4800 lb with me in it. Thankfully now with the new vehicle I don't have to do that. There's very little risk of it cracking apart.
  7. Sep 29, 2019 at 10:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not much more than your rtt.
    This is why aluminum is fine I think. Not likely to hit it there but when you do it'll do it's job. Probably get ruined too but save the tcase.
    The auto does hang down a LOT more than the manual. It's a whole nother oil pan to worry about.
    Speaking of...
    Mine is still slipping.
    Local wrecked extended cab for $1000 with a manual ...........tempting.
  8. Sep 29, 2019 at 10:48 PM
    Reh5108
    Idaho
    Curious what you come up with. I definitely think it's worth the piece of mind knowing that nothing on your belly can be damaged. I've seen a truck get a rock in between both crossmembers and it took a little creativity to get out of that predicament.
  9. Sep 29, 2019 at 11:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The new Toyota 86 is said to come with a 2.4l turbo possibly. Over 250hp maybe. That'll be great
  10. Sep 30, 2019 at 6:45 AM
    Speedytech7
    Well that's 2 years and change so if it's true that's about right for Toyota to get em out there. Likely mostly dependant on Subarus schedule since the car is 80% subi
  11. Sep 30, 2019 at 7:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    All over. For 2020 model supposedly.
  12. Sep 30, 2019 at 7:44 AM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    @m3bassman You can get sandbox sand at lumber yards (usually), hardware store, maybe HD or Lowes.
  13. Sep 30, 2019 at 7:58 AM
    Squeaky Penguin
    Brett
    That's my only concern.
    Need to play around a little.
    I'm going to build a little crossmember off the factory sway bar mounts to support the back of the IFS skid. Maybe I'll tie a couple pieces into the trans crossmember with some UHMW or something. Need to see how much that weights. Just don't need a 2x4' sheet of 3/16" like I have now... I also don't want it to go further back than the tcase. That's where I get hung up the most.
  14. Sep 30, 2019 at 8:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn that was my idea :p The sway bar mounts a perfect skid mounts.
    UHMW would be cool but its not light. Not in the thickness you'd need for it to be to not rip off when used.
    Yeah...thats why I said supposedly..
    True, the EJ20 is finally dead after this year. Took them long enough.
    m3bassman[QUOTED] likes this.
  15. Sep 30, 2019 at 9:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there can always be more :p
  16. Sep 30, 2019 at 9:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Supra can't come in a manual..thats a major turn off.
    Yes they will just recycle a motor. Thats the way it is now. Why a lot of are speculating it'll be the 2.2l turbo.
  17. Sep 30, 2019 at 12:00 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    WY mud is unforgiving! Riding trails in thunder basin and it's about impossible with this grey colored peanut butter vaseline infused mud.
    Do people that know better just stay off it till it dries?
    Justrom likes this.
  18. Sep 30, 2019 at 12:05 PM
    surfandturf
    CT
    2014 TRD DCLB
    Here's a visual
  19. Sep 30, 2019 at 2:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Welcome to Bentonite Mud!
    No there is no real good way to avoid it other than staying off it. Its all over Wyoming and Utah and probably lots of other places.
    Its like super glue, so the best thing to do is to wash it ASAP cause if it dries you'll never get it totally out from under your truck.
  20. Sep 30, 2019 at 4:36 PM
    surfandturf
    CT
    2014 TRD DCLB
    Thanks for the tip
