Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 10, 2014 at 10:28 PM
    #4221
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    No. Second. My parents were looking for a 4x4 tacoma in Northwest FL and found this one the day it was traded in for a camrey. A few weeks later I ran into the previous owner in our walmart parking lot. I came running across a few rows yelling "HEY thats my truck". He then gave a quick summary of what he did to it. 3" spacer lift and wider tires is all I got out of him before his phone rang and he left.
    Thanks I will try that.
    ^^Yeah I remember that from earlier.
  2. Jan 10, 2014 at 10:31 PM
    #4222
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be 4.10s for a base 5 speed 4banger 4x4
    If you have bigger tires. That's why your speedo is off. Although it should be reading slower.
  3. Jan 10, 2014 at 10:33 PM
    #4223
    anders99
    Matthew
    Penscola, FL
    The door sticker says stock came with 245/75/16 I am currently running 255/70/16 and when I did the tire calc thingy they were almost the same diameter just wider
  4. Jan 10, 2014 at 10:33 PM
    #4224
    BradyT88
    BradyT88 Well-Known Member
    Yeah, that was my thought at first, but it should be reading slower for bigger tires. Going to a lower diff gear will make it read faster though.
    So... :notsure:
  5. Jan 10, 2014 at 10:34 PM
    #4225
    anders99
    Matthew
    Penscola, FL
    Just did the math my new tires are .41 inches smaller that the stockers
  6. Jan 10, 2014 at 10:36 PM
    #4226
    Blackdawg
    Monte
    Wyoming/St. Louis
    Smaller??? Well that's your problem haha
  7. Jan 10, 2014 at 10:38 PM
    #4227
    anders99
    Matthew
    Penscola, FL
    Haha yeah but they were brand new so I couldn't justify getting rid of them yet. I know smaller will make it read faster but will it really read that much faster. Speedo says 85 while gps has me at 73
  8. Jan 10, 2014 at 10:40 PM
    #4228
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. When I had 33s over my 31s was about 3-6mph off depending on e speed as it's a ratio that it's off. Doesn't take much. That and Toyota is notorious for making their speedo fast anyways
  9. Jan 10, 2014 at 10:44 PM
    #4229
    anders99
    Matthew
    Penscola, FL
    Man thats crazy. I assume there is no easy fix for this is there? I am going to have a date with the toyota dealer in Laramie for the access cab seatbelt holder recall, oil change, and 100,000 mile maintenance since it is frowned upon to do car work in the parking lot of the apartments I will be at.
  10. Jan 10, 2014 at 10:47 PM
    #4230
    Blackdawg
    Monte
    Wyoming/St. Louis
    I do no about 2nd gens...is sorta for 1st gens. But think your speedo is electic so I can help ya :eek:
  11. Jan 10, 2014 at 10:52 PM
    #4231
    BradyT88
    You can buy an Ultragauge and calibrate it to read correctly. Won't fix your speedo but at least you will know how fast you are going.
    The manuals have a gear tooth in the tcase like 1st gens do to read speedo, but no one makes gears and no one has had any luck finding gears to work for it.
    Digital calibrator runs you about $200 which is crazy to me...
  12. Jan 10, 2014 at 10:55 PM
    #4232
    anders99
    Matthew
    Penscola, FL
    I am running an app called dash command that hooks up to the on board computer over the wifi to my phone which then displays on my head unit and in that app I have it so it knows to correct the speed.
  13. Jan 10, 2014 at 10:56 PM
    #4233
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wifi with the ecu?? Wtf??
  14. Jan 10, 2014 at 10:56 PM
    #4234
    BradyT88
    I would just use that then. haha
  15. Jan 10, 2014 at 10:57 PM
    #4235
    anders99
    Matthew
    Penscola, FL
    Yeah there is a wifi dongle plugged in to the OBD2 connection. I guess I should have mentioned that.
  16. Jan 10, 2014 at 10:58 PM
    #4236
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh..duh haha I was like..only e u piggy back I know that dose that is the Uconn haha
  17. Jan 10, 2014 at 10:58 PM
    #4237
    anders99
    Matthew
    Penscola, FL
    haha I usually do except I am driving across country so I had the navigation app running.
  18. Jan 10, 2014 at 10:59 PM
    #4238
    anders99
    Matthew
    Penscola, FL
    haha yeah I got the el cheapo one from Amazon and it works. Just takes a little set up each time I unplug it
  19. Jan 12, 2014 at 11:14 AM
    #4239
    anders99
    Matthew
    Penscola, FL
    Rolled into Laramie yesterday
  20. Jan 12, 2014 at 2:10 PM
    #4240
    Blackdawg
    Monte
    Wyoming/St. Louis
    Receiver winches are fine. But can be a pita when you need it. Sometimes they stick out too far and you can't get them in. Other then that tho. Nothing wrong with them. Still means you need a front receiver tho.
