Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 10, 2019 at 6:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well every other thing is cable controlled too so if the cable that directs air over your heater core isnt moving the door you'll get didly fucking squat
  2. Oct 10, 2019 at 6:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Doubt that is the issue. Its not that complex. There isn't a "door" in there to direct air over the heater core. Air always goes over it only thing that controls the temp is the heater control valve in the engine bay which either lets in Coolant or doesn't. Only door is Fresh air vs recirculating. And I know thats working cause its loud as fuck when you move it haha and you can here it sucking in the cab.
    Look at you two, tellin me shit about parts you don't even know about and telling me I need more research :luvya: TW at it finest haha
    I've found the cables to be more reliable than the actuators anyways. Hard to be an "analog" connection directly to something. Sure, it sucks when the plastic end breaks off the thing you are trying to move. But the cables never don't work.
  3. Oct 10, 2019 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    1995
    If you can find that on Rock Auto. I'll be tickled pink.
  4. Oct 10, 2019 at 7:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well that's interesting...because mine was. haha
  5. Oct 10, 2019 at 7:36 PM
    Speedytech7
    We do have blend doors Ive fixed mine. You're going to be in there anyway to replace the heater core you probably don't need why don't you take a couple pictures and I'll make you eat your words then
  6. Oct 10, 2019 at 7:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :rolleyes: fine haha
    Find one for a 96 then
  7. Oct 10, 2019 at 7:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wasn't planning on replacing the core. Just wanted to know why you replaced yours.
    I will dig around in there this weekend hopefully
  8. Oct 10, 2019 at 7:40 PM
    Speedytech7
    It's really not that hard there's a big door right in front of the heater core. it's literally the exact same height as the heater core and I can tell you that because I've taken my two boxes apart when I had the gray truck and the green truck to build one perfectly working airbox. And my truck was just as old as yours all cable-actuated. A lot of it has to do with if your cables are adjusted properly, and if you slam them around like a caveman in the winter I bet you they're not anymore
    Blackdawg[QUOTED][OP] likes this.
  9. Oct 13, 2019 at 10:22 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  10. Oct 13, 2019 at 10:22 AM
    Speedytech7
  11. Oct 13, 2019 at 10:28 AM
    Digiratus
    Roaming the PNW
    The RedHead
  12. Oct 13, 2019 at 8:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Took the family to work today.
    IMG_20191013_154624.jpg IMG_20191013_161614.jpg IMG_20191013_163118.jpg IMG_20191013_164412.jpg IMG_20191013_170032.jpg IMG_20191013_171001.jpg IMG_20191013_173445.jpg
  13. Oct 13, 2019 at 8:30 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Are the rocks real or like fake art, if real we're they like that or brought in?
  14. Oct 13, 2019 at 8:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's concrete built on site. Huge. The last two photos is The Domo and is the longest continuous concrete poured in Montana history. 24 hours or more.
    Super cool to see in person
    BossFoss[QUOTED] and m3bassman like this.
  15. Oct 13, 2019 at 8:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What is growing out of the top of it?
  16. Oct 13, 2019 at 9:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Grass and shrubs. Natural landscape
  17. Oct 13, 2019 at 9:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    WTF :confused:
    BossFoss likes this.
  18. Oct 13, 2019 at 9:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Someone missed the snorkel delivery
  19. Oct 14, 2019 at 11:03 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Those are awesome. Some trip needs to take us by there.
    No, no I didn't.
  20. Oct 14, 2019 at 11:12 AM
    JKO1998
    Utah
    I know a guy that might give you one, but you gotta pick up trash
    gordi likes this.
