Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 28, 2019 at 9:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Each of the 4 pieces required some grinding. The rear gusset on the passenger side required a lot of grinding. Way more than an 1/8".
    I am sure that some of the adjustments are due to each truck being unique. And it could be that the frame is tweaked there to begin with, but it sure seems like the kit could be a little closer than it is.
    Is there a way to convert the UCAs to heims?
  2. Oct 28, 2019 at 10:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    not really. You have to cut off the ends and then weld in new ones.
    Probably be better off just buying new ones. Solo makes some I believe, maybe TC too.
    You then want to solid mount the lowers(the cam tabs).
  3. Oct 28, 2019 at 10:07 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Yeah, it would be possible, but probably be better off just selling yours and buying new ones.
    I thought TC was the only one that made them.
    You wouldn't need to solid mount the lowers, but it could help with alignments.
  4. Oct 28, 2019 at 10:17 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I guess I'll just see how the bushings hold up. If they start squeaking, I am going to hate it.
  5. Oct 28, 2019 at 10:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't see the point of Heim uppers if you don't lock the lowers out. Then it just makes alignments a constant PITA. If you just lock them and get it adjusted right, you'll never have to change it again. Providing you don't change your ride height much that is ha
  6. Oct 28, 2019 at 10:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    race truck parts = race truck noises.
  7. Oct 28, 2019 at 10:19 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, unfortunately.
    Just crank up the stereo eh?
  8. Oct 28, 2019 at 10:25 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Hobbs likes this.
  9. Oct 28, 2019 at 10:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    good thing yours is good! haha
  10. Oct 28, 2019 at 10:44 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I think I agree with Ben. I had weak heat at one point and when I took it to the dealer for the 30K checkup, they said that my problem was low coolant levels. They filled and everything was hot again. But happened with both recirc and outside. If you've checked that as well as everything else, then the symptom sounds to me like the HC has enough juice to warm up the "warm" in-cabin air, but not enough to warm the outside air. So, weak HC.
  11. Oct 28, 2019 at 10:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Correct.
    Damn..
    Damn. Well that won't be fun.
  12. Oct 28, 2019 at 12:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Have you put a scantool on it to see if the truck is warming up. These trucks have pretty lame code setting criteria so they only let you know if something is horrendously wrong. But you might only be getting to like 150° which would certainly give you lame heat. My truck doesn't get all the way to 177.8 like it should right now so I have lame heat for a while until I get on the highway usually.
  13. Oct 28, 2019 at 12:22 PM
    Speedytech7
    Its really easy to change, trust me. You'll wonder why you didn't man up and just do it right away.
  14. Oct 28, 2019 at 12:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think that's it. Like I said it gets hot on recirculate. Plus I drive 25 miles one way. It gets up to temp by about mile 5-7.
    Well that's good. I most don't want to tear the thing out of the dash. Done that, not so fun.
  15. Oct 28, 2019 at 3:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well at about 75/25% recirc/fresh it works haha enough to get around. First drive home in a blizzard.
    On that note anyone ever run snow tires? Any one you like? Needs to be studdable as that's what I really want more than anything for stopping. Been an icy winter so far.
    Might pull a Ben and get some 235/85r16s :laugh:
  16. Oct 28, 2019 at 3:35 PM
    Speedytech7
    I absolutely love Blizzaks but they're expensive. Could probably just get some of those studdable Wrangler DTs
  17. Oct 28, 2019 at 3:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Blizzaks aren't usually studdable either. And I think I've read they don't last very long. Not that Im looking for a super long lasting tire but they don't last long period i guess.
    I was kind of eyeing the Cooper M+S with studs. Can get it in a C load on a 16 which I have a set of 16s still.
  18. Oct 28, 2019 at 3:40 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No problems with st maxx, but maybe I’m a fanboy.
  19. Oct 28, 2019 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Already own those. And they are terrible snow tires I think. Do fine. But way to hard of a compound.
    My hankooks do better.
    yeah i know haha Load E anyways which I would never do.
    265/75r16 I can get in C though.
    Blizzacks..hmm. Have to see what they have
  20. Oct 28, 2019 at 4:01 PM
    Speedytech7
    Winter tires aren't supposed to last long, their soft tread and billion sipes is why they work at all
