Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 8, 2019 at 6:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's just a daytime running light, they only say to hook it up if your vehicle has DTRLs which most vehicles in the US with sealed beams never did. Canada has since like 1989 tho. Anywho, no mine didn't have those, they were just your standard high and low and ground. Gotta have a separate harness to convert the ground side switching to positive switching tho.
  2. Nov 8, 2019 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ah I do recall you saying this. Surely you can just swap the blades on the head light in the connector though as well.
  3. Nov 8, 2019 at 6:27 PM
    Speedytech7
    Nope you can't, believe me I tried. The lights need two positives and a constant ground. The Toyota setup cannot do this, you have to use relays to switch it around. The harness I got was $12 and worked flawlessly, you couldn't really make it yourself any cheaper even.
  4. Nov 8, 2019 at 7:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm interesting. Where did you get it?
  5. Nov 8, 2019 at 7:10 PM
    Speedytech7
  6. Nov 9, 2019 at 10:19 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Late to the snow tire discussion. Just put these on Jen's car, it will be there fourth winter. Treadwear and performance has been awesome. They are winter claw extreme grip mx. Carry on
    m3bassman likes this.
  7. Nov 9, 2019 at 12:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think that's what we have on Devin's car too. Something like that. Lasted so long they dry rotted haha only reason she got new ones. Was starting to throw studs too.
    My Cooper's are being mounted right now.
    SconnieHailer[QUOTED] likes this.
  8. Nov 9, 2019 at 1:34 PM
    SconnieHailer
    Marc
    Jen's are not studded and still work great. I've never driven studs before so I have no comparison.
  9. Nov 9, 2019 at 3:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got studs too. Will see if I think it's worth it. Figured it won't hurt in the crap I have to drive in a lot.
  10. Nov 10, 2019 at 10:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well, i love snow tires! Fun driving around on shit roads with them.
    SconnieHailer, m3bassman and Reh5108 like this.
  11. Nov 11, 2019 at 9:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Me either. Made it a long time really considered where I grew up. But the fact is that the part of Wyo I grew up in doesn't really see that much snowfall, just damn cold. Compared to here which gets a ton more moisture. I went the last 2 years without them but had plenty of close calls and went off the road once each year on the county road..though that has more to do with not being able to see shit in bad conditions.
    But between these and the hankooks, I probably won't need new tires for the DD for a long time. Probably dry rot before they wear out honestly. And if the Duratrac is around maybe I'll try those for a year round tire again.
  12. Nov 11, 2019 at 10:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have only owned one car my whole life and I never got to drive it haha well..i drove it 3 times.
    But 4x4 only does so much in real bad stuff. Doesn't do shit when it comes to stopping and sometimes nothing when it comes to steering even.
    Pltmnky likes this.
  13. Nov 11, 2019 at 5:07 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    80% tire for sure 20% driver, 4x4 just keeps you semi-straight when accelerating.
  14. Nov 11, 2019 at 7:39 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  15. Nov 12, 2019 at 6:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So Zane. If its MCM front LT and possibly some solo upgrades mixed in there...what are you going to do in the rear?
    I've really been toying with the idea of doing a custom SUA setup using the Archive garage towers with a 12/14'' shock. This way not bed cage needed but should pull the same travel numbers as the front(ish) and probably run a double or triple bypass in the rear. Add hydro bumps and run either a LC axle or a 9'' that is wider to accommodate all of this. keep the bed fully in use in the case but should still be fun fun fun.
    You going full SUA? Links? Just mid travel rear? Link it? haha
    PcBuilder14 likes this.
  16. Nov 12, 2019 at 6:31 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    SUA with all of your weight? Or is that contingent on a GoFast Camper??? :D
  17. Nov 12, 2019 at 6:33 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've been investigating that exact setup.
    FJ80 axle
    SUA with custom springs for the weight
    Outboard shocks with hoops - notch frame if necessary
    :spy:
    jubei and PcBuilder14 like this.
  18. Nov 12, 2019 at 7:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I'd love a GFC. But not ready to swallow that price tag..yet.
    But yeah custom springs man. Be fine.
    Yeah kind what I was thinking. Should work well with the lt front.
    So you better upgrade haha
    PcBuilder14[QUOTED] likes this.
  19. Nov 12, 2019 at 7:17 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I could do a lot more with that much money over just a camper. But it would make life a lot easier with a dog and kid over setting up the stupid annex. Such a pain.
    Depending on how everything works out next year I might try to grab a spot if somebody puts one up for sale. Those wait times are too long.
    Be interested to see you make the springs work. Don’t know that I’ve seen anybody successfully do it with an “overland” setup. Just 4-link it :boink:
  20. Nov 12, 2019 at 9:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    was pretty set on 4 linking it...but...not really worth it I think with just a standard LT kit. And the XLT kit would be fun if I was building a KOH rig but for what I do LT already can be interesting width wise haha
    Yeah the wait is so long now. The used market isn't there, people just ask full price or even more for them. Be great to have though. Super nice. Especially with that Kingmans or whatever awning. Be slick.
