Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 22, 2019 at 7:40 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    It's not a "normal" looking bed, but it's got a bed back there....
  2. Nov 22, 2019 at 7:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Gonna need some drugs to appreciate it though
  3. Nov 22, 2019 at 7:48 PM
    Speedytech7
    I'm not about to make an attempt to overcome my bias just for that POS electric shitbox. That's like doing work for no pay
  4. Nov 23, 2019 at 7:40 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    My favorite so far
  5. Nov 23, 2019 at 9:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oh that's great lol
  6. Nov 23, 2019 at 10:01 AM
    Speedytech7
    Even Microsoft is clowning him
  7. Nov 23, 2019 at 10:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn I have to remove the whole dash to get to this heater core..hmm. well joy.
  8. Nov 23, 2019 at 10:08 AM
    Speedytech7
    You'll have it done in 15 minutes. Removing the dash does not take long on these. Just don't forget the little clip that holds the wiring harness to the dash fascia. Otherwise you'll end up yanking on your harness wondering why it's not coming loose
  9. Nov 23, 2019 at 10:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah still pita. Oh well
  10. Nov 23, 2019 at 11:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  11. Nov 23, 2019 at 11:39 AM
    Speedytech7
  12. Nov 23, 2019 at 11:42 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Asshole cat slowly pushes it off table*
    While making eye contact*
  13. Nov 23, 2019 at 11:45 AM
    Speedytech7
  14. Nov 23, 2019 at 11:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    No, it's a good price for BF.
    Aside from the issues Monte has encountered, these look really stout and offer a solution (of sorts) for adding caster. Now before Mr. Brett jumps in here, there are still issues with using the stock frame mounts or at least what happens with the bushings.
    So who is making heimed UCAs at stock-ish geometry?
  15. Nov 23, 2019 at 11:56 AM
    Speedytech7
    Cut and weld, not hard to add heims really. They just need a threaded hole to screw into.
  16. Nov 23, 2019 at 11:57 AM
    Digiratus
    Roaming the PNW
    The RedHead
    This is not the lunchtable.. :rolleyes:
    JKO1998[QUOTED] likes this.
  17. Nov 23, 2019 at 11:58 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Can be done on Camburg arms?
  18. Nov 23, 2019 at 12:00 PM
    Speedytech7
    Yeah, I don't see why not.
    Digiratus[QUOTED] likes this.
  19. Nov 23, 2019 at 1:07 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I saw that. Their LT kit with heimed uppers is also on sale...
    I actually wouldn't say that as they would fix a lot of the problem. If I got those, what I would do is square up the alignment cams to help the bushings. It would result it about the same caster, but would be a better setup IMO as you'll get the caster from the LCA and not by maxing out the cams.
    TC is the only company making heimed uppers IIRC.
  20. Nov 23, 2019 at 4:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Total chaos makes stock heim uppers
    Good price on the solos for sure. Still haven't figured out if mine as a fluke or what. Haven't had time. They are nice but I think you could upgrade the stock ones with the weld on parts from eklien and add secondary shocks to them easy as well. Much cheaper.
    But the added castor and clearance is great...
    Half ruin my grill but swapped head lights today.
