Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 26, 2019 at 6:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not my fault you're slow, haven't you removed a dash before, you swapped your whole cab without removing it? I've done it like 5 times now haha, it's cake
  2. Nov 26, 2019 at 6:29 PM
    Speedytech7
    Or rust, mines rusty AF in this new/old taco
    m3bassman[QUOTED] likes this.
  3. Nov 26, 2019 at 6:33 PM
    Speedytech7
    Well when coolant gets old and loses those additives that prevent corrosion you have the perfect mixture to make corrosion, three different metals, fluids, and heat. Rust color coolant isn't uncommon on your average car, because the average person never thinks to just change coolant.
    m3bassman[QUOTED] and JKO1998 like this.
  4. Nov 26, 2019 at 6:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah i did but like...shit idk. 6 years ago?
    And the dash was easy really. The shit to get the heater wasn't. Plus by cross bar was like fused together. And the hoses were super glued to the tubes.
    Yeah i'd like to do that. So I'll just drive Igor to work tomorrow and flush it. It seemed pretty dirty.
    That said, there is actual orange coolant. So I don't think its a blend.
    A quick search says its usually okay to mix orange and pink, but not anything with green.
  5. Nov 26, 2019 at 6:44 PM
    Speedytech7
    You don't even have the AC box to contend with haha, what was tough about those, you just loosen all of the bar bolts and take off just the right side and everything slips right under. I got new heater hoses lat time because they seemed weak when I did mine.
  6. Nov 26, 2019 at 6:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I don't have the burping funnel from the Timmy video. Thought about it. But honestly...didn't need it. If you just fill the engine up with fluid from the get go before the radiator...you don't have to burp it hardly at all.
    Speaking of the AC..i have never had one without it. Mine had a funnel basically from the fan to the heater, but it had a very weird electrical thing in it. Almost looked like a heating element..no idea wtf it was. Do you?
    Hell I took all the bar bolts off and it barely wants to move. Not sure why..but got everything out fine now. Aside from the core melting the firewall liner to itself..that wasn't fun either..haha
    My hoses are fine really, soft feeling still. Look like they were replaced recently.
  7. Nov 26, 2019 at 6:49 PM
    Speedytech7
    Blower motor resistor
  8. Nov 26, 2019 at 6:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hmm odd why is it inside the air tunnel?
  9. Nov 26, 2019 at 6:55 PM
    Speedytech7
    It's slowing down an amperage hungry brushed motor, you'd get hot too if you used thin wire to essentially voltage regulate and brushed motor
    Blackdawg[QUOTED][OP] likes this.
  10. Nov 26, 2019 at 6:57 PM
    Speedytech7
    Take the hose off and fill it first, have to do that with fancy cars now with electronic thermostats/
  11. Nov 26, 2019 at 6:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    take off the upper radiator hose from the radiator side. Pour fluid down it until it stops flowing. Let it sink in. top off. Repeat till it stop sinking in. Attach to radiator. Causes a tiny spill but not much. This gets fluid all the way down the motor and to the pump, basically priming the whole system.
    Works well really.
    But that tool is nice. I just didn't see the need. But for a full flush it would be handy. Doubt I can get it due to the holiday for when I have time.
  12. Nov 26, 2019 at 7:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    did what for igor?
    Yeah I'll order it. Can't hurt. have to do another TB/wp soon anyways. Probably just put distilled water in it for now tomorrow. Don't need to drive for a bit.
  13. Nov 26, 2019 at 7:33 PM
    Speedytech7
    Don't let it freeze! I mention that because it's fucking cold here and we had black ice everywhere. There was a 70 car pileup on i90
    gordi and JKO1998 like this.
  14. Nov 26, 2019 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    sounds fun haha
    its cold here too. Supposed to snow on Friday..need to get it back together tomorrow to get it out of the garage since its half sticking out. Might not even bother filling it up at all. Just gonna drive it to the front yard.
  15. Nov 26, 2019 at 7:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah gotcha.
    Yeah I just prefer not to DD Igor. Plus as bad weather rolls in the snow tires are on the lil truck so its better to drive. Aside from currently no heater or wiper fluid wording :laugh:
  16. Nov 26, 2019 at 7:48 PM
    Speedytech7
    Oh theres even more, huh. I avoided it like the plague and took surface streets home. I'm at exit 272
  17. Nov 26, 2019 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not supposed to hit here till friday.
  18. Nov 26, 2019 at 8:11 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Utah’s about to get fucked up over the next few days. The Gorge got 12 inches from the storm today, more big storm come then next couple of days.
    I think my drive home Friday is probably dead
  19. Nov 26, 2019 at 8:28 PM
    Speedytech7
    Will certainly try, opting to take the cruiser to work tomorrow, and then after work straight across the state to be with the family for thanksgiving. It has better tires and handles the snow better than the Taco with it AT tires and no weight.
  20. Nov 26, 2019 at 10:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you goona be able to give me a hand with the redhead this weekend?
