Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 26, 2019 at 7:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the knuckle sacrifice always does it.
  2. Dec 26, 2019 at 7:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    In other news... Today I took the redhead on a road trip to Mazama. She did well without any dramas or hiccups.
    I said this before, headers are interesting. Along with the upstream cat removal, the exhaust note is much louder. It is probably my blown out magnaflow contributing to that as well. Unfortunately, there is a drone as specific RPM/speed combinations. I think a new muffler is in my future.
    On a very positive note, I am seeing an increase in fuel mileage. Not sure it is just the headers causing that. It may be that the upstream cat was contributing.
    drr and Blackdawg[OP] like this.
  3. Dec 26, 2019 at 7:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ben, Is Kirsten still working for T-mobile?
  4. Dec 26, 2019 at 7:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    sweet! awesome to hear it is officially 100% road ready. Can't say I'm surprised about the drone with the headers. Happened to my Dad as well.
  5. Dec 26, 2019 at 7:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, happened to Dan as well. He added a resonator. I may need to go that route also.
  6. Dec 26, 2019 at 7:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Its at least 2, maybe as much as 3 mpg. I'll do the actual math when I fill up tomorrow and then again on the return trip.
    I asked about t-mobile because it looks to me that they are doing some interesting things. Have you switched over from verizon?
  7. Dec 26, 2019 at 7:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow sounds like you might have had a plugged cat
  8. Dec 26, 2019 at 7:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There were no codes but this is my suspicion too. The engine revs much easier, seems to breath much easier. I am sure the headers help with this as well.
  9. Dec 26, 2019 at 8:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah I want to cut Franks out. I think it is plugged as well.
    But makes sense.
  10. Dec 26, 2019 at 8:24 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Damn we fixed problems you didn't even know you had. I think we used all our project luck on this one, which doesn't bode well for the LC axle install this weekend.
  11. Dec 26, 2019 at 8:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nah dude you have karma on yourside for that project :cool:
    jubei and Digiratus like this.
  12. Dec 26, 2019 at 8:30 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    :fingerscrossed:
  13. Dec 26, 2019 at 8:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Luck has nothing to do with it... :cool:
    I am sure that thoroughness will pay off in the end.
    How do I 'like' this more than once.
  14. Dec 26, 2019 at 8:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have 5g service and a 5g phone? According to there map, Boise is covered pretty good.
  15. Dec 26, 2019 at 8:43 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Stock 80 series FF housing? Curious to see how it turns out.
    Still considering that, but would really prefer a fabricated housing, but $$$$ :spending:
  16. Dec 26, 2019 at 8:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    FZJ80 with 5.29s and ARB I believe :drool:
    jubei likes this.
  17. Dec 26, 2019 at 8:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there are some people that are worried about 5G due to the antennas and how they work. I don't know that much about it personally...but I think it has something to do with much higher wattage used as well as a LOT more towers needed. So there will be way more antennas everywhere pumping out a lot more wattage.
    But those people that say that just don't realize how much actual RF is in the air already IMO :laugh:
  18. Dec 26, 2019 at 9:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I just bought a new phone from a company named OnePlus. Ever heard of them? T-mobile sells this phone too.
    The 7t (the model I bought) is an unlocked GSM phone that will also work on T-mobile and AT&T with their sim cards.
  19. Dec 26, 2019 at 9:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is correct. And don't forget the disc brakes.
    jubei and Blackdawg[QUOTED][OP] like this.
  20. Dec 26, 2019 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not enough publicly on that one. Yet..ha
    m3bassman[QUOTED] likes this.
