Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 4, 2020 at 1:06 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    New tire day is a good day.
    m3bassman likes this.
  2. Jan 4, 2020 at 1:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    lol which truck are you building? The LC or taco? Decide already! Haha
  3. Jan 4, 2020 at 1:15 PM
    Speedytech7
    The Taco, I just needed tires, can't drive a daily without tires. They're small tires anyway, just 285/75/16 :p
  4. Jan 4, 2020 at 1:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i was more surprised to see the RTT on the LC..
  5. Jan 4, 2020 at 1:23 PM
    Speedytech7
    Oh, well I didn't want it taking room in the garage so I bought some Yakima towers used and shoved it up there for the time being. I need to build a rack for the Taco still, it has that dumb canopy shell on it right now.
    Blackdawg[QUOTED][OP] likes this.
  6. Jan 4, 2020 at 6:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are those BFG KO2s?
  7. Jan 4, 2020 at 6:12 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    @drr any more feedback on the 80 series axle? Pretty sure that's what I'm going to pick up at this point.
    Also - mind sharing what you paid for it? I see a couple on car-part for $350, but minimum for 3 hours away.
    jubei likes this.
  8. Jan 4, 2020 at 6:14 PM
    Speedytech7
    I'm not above hitting an old man
    :eek:
    BossFoss likes this.
  9. Jan 4, 2020 at 6:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jan 4, 2020 at 7:17 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I'm getting a little gear noise at higher speeds, I might pull the 3rd and re-check backlash and preload. I wouldn't normally be so cavalier about pulling the differential, but I don't even need to take the wheels off or disconnect any brakes lines for it, so why not. Other than that, break in is going well - it has a very slight shudder on takeoff but otherwise no vibrations at all.
    I wouldn't say the brakes are a night and day difference, but they're at least as good as the drum brakes. The Tundra brakes up front and discs in the rear are asking a lot from the stock 13/16" master cylinder.
    I would say $350 is a pretty decent deal, I overpaid for mine ($500) but it was literally the only one I could find in Washington or northern Oregon. It was also in good shape (still had the links attached and everything) so I felt good about the condition. Are the ones you're looking at open diffs or have the e-locker?
  11. Jan 4, 2020 at 7:20 PM
    Speedytech7
    You still got them links?
  12. Jan 4, 2020 at 7:26 PM
    Squeaky Penguin
    Brett
    Only looking for open diffs that I would toss an ARB in.
    I was told to stay away from the elocker units. Besides the price being substantially higher, I was told that they could have an issue which would result in grenading the locker or axle shaft and then not being able to pull the 3rd out.
  13. Jan 4, 2020 at 7:27 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I left the upper and lowers at the junkyard, no room in the truck for em haha. I still have the panhard though, was trying to think of something to use it for.
  14. Jan 4, 2020 at 7:28 PM
    Speedytech7
    Yeah don't get an elocker one. You wouldn't be able to find one anyway, but still don't get one. I got chromoly ones just to avoid that issue on mine since the splined section is longer and likely to twist there if bound up hard on large tires or with lots of torque.
  15. Jan 4, 2020 at 7:29 PM
    Speedytech7
    I'm doing every bushing in the suspension on the cruiser. It'd be nice to do it on the arms and just swap em in. Oh well.
  16. Jan 4, 2020 at 7:30 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah that was my thinking as well. I've known too many people who have had issues with Toyota e-lockers, I'd rather spend the extra money to get something I know I can count on.
  17. Jan 4, 2020 at 7:31 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Ah, well they're probably still at that yard in Brewster if you want to pick them up next time on your way over lol.
    You're welcome to the panhard if you want it.
    Speedytech7[QUOTED] likes this.
  18. Jan 4, 2020 at 7:33 PM
    Squeaky Penguin
    Brett
    Funny enough, I've head of, and seen 1st hand, several issues with ARBs, but my elocker has always worked perfectly.
    This issue I was talking about is exclusive the the 80 series, and isn't the same issue you hear of on our tacos with the actuator/engagement.
    Speaking of which, @m3bassman if I do get this other axle, I've got a perfectly functioning elocker actuator I'll be selling. :p Also - do you still want this steel winch cable that's taking up room in my garage?
    Reh5108 likes this.
  19. Jan 4, 2020 at 9:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have a T100 master cylinder and and booster it'll bolt too if you want.
  20. Jan 4, 2020 at 9:37 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    We tried that combination, remember? Although who knows, maybe it'll work now with the extra volume of the rear calipers.
