Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 10, 2020 at 10:16 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    No, it was in good shape except some dents in the bed on the side you see. I can't figure out how that much damage happened yet the mirror is ok?
  2. Jan 10, 2020 at 10:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Idk when I flopped Frank the mirror was fine somehow. Same with Zane if I remember right.
    totally depends how and what you rolled over when it happened. So many variables haha
    m3bassman likes this.
  3. Jan 10, 2020 at 10:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's a good point.
  4. Jan 10, 2020 at 6:21 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Well, wife signed a contract. We are moving to Worland now. Not sure exactly when but she has a start date of Nov 1st
    Digiratus and Blackdawg[OP] like this.
  5. Jan 16, 2020 at 4:35 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Good one tonight
  6. Jan 16, 2020 at 5:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  7. Jan 16, 2020 at 6:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Speedytech7[QUOTED] likes this.
  8. Jan 16, 2020 at 6:07 PM
    Speedytech7
    For some reason I just love the way he calls the guy a fucking donut. Going to have to try that one at work
    Blackdawg[QUOTED][OP] likes this.
  9. Jan 16, 2020 at 7:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    YA FUCKIN DONUT! hahaha
  10. Jan 18, 2020 at 8:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I had the opportunity to get out and play in the snow last weekend with my friend Mark. Only got stuck once. :D
  11. Jan 18, 2020 at 8:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    We both got stuck turning around in the same spot. :luvya:
    m3bassman[QUOTED] likes this.
  12. Jan 18, 2020 at 8:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    And the red head is back!
    Digiratus[QUOTED] likes this.
  13. Jan 18, 2020 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There was a time...
  14. Jan 18, 2020 at 10:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    never had a doubt.
  15. Jan 18, 2020 at 10:25 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    FIFY
  16. Jan 18, 2020 at 10:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Bought a new set of screw drivers. Need them to take apart and clean my IAC valve.
  17. Jan 19, 2020 at 8:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Does anybody know if I replace this PCV do I also need a new grommet for it?
    Also, kind of annoyed at my IAC valve. I took everything apart and cleaned it and seem to have made it worse. If anything the idle is even higher than it was. :(
    Admittedly, it was dirty. A lot of carbon build up. And electrically, the servo mechanisn does work because I could hear it when I applied voltage to it. But unfortunately, the little door does not open and close like its supposed to. I cleaned it as good as I could but that little door does not move after cleaning.
  18. Jan 19, 2020 at 8:59 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You don't necessarily need to replace the grommet, but if you've never done it, it's probably a good idea to do so. They can get really stiff and dry rotted and make changing the PCV a pain.
    Also - if you end up needing any intake parts let me know. I have a a whole intake sitting on the shelf.
  19. Jan 19, 2020 at 9:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the offer. A new AIC is pricey but might be worth it. Does yours have 300K on it?
    I think the grommet has been replaced once but I'm not sure. I cant remember if it was done when we did the valve cover gasket. I have not tracked down the toyota part number for the grommet yet but saw that Autozone and Orielly's carry something that will work.
    The MAF's been cleanned and the computer reset, It is possible the ECU is playing a role, but I could also visually see when I applied voltage to it when it was apart that the little door did not appear to be moving like it did in timmy's video.
  20. Jan 19, 2020 at 9:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    get a new grommet for sure. Mine always just fall apart.
