Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 8, 2020 at 9:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    He is pretty impetuous :p
    m3bassman and Digiratus like this.
  2. Feb 8, 2020 at 9:38 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    OK, what's the word I'm looking for? "prompting" synonym. I really thought it was impetuous, hahahahaha.
  3. Feb 8, 2020 at 9:39 PM
    Speedytech7
    Impetus, you were close. Thought it was autocorrected
  4. Feb 8, 2020 at 9:42 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Nah, eye jus kan't spel ;)
    Speedytech7[QUOTED] likes this.
  5. Feb 8, 2020 at 9:42 PM
    Speedytech7
    It's like texting with Ben, basically have to have a separate lexicon for that
    turbodb[QUOTED] likes this.
  6. Feb 8, 2020 at 10:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    impetus =motivation
  7. Feb 9, 2020 at 10:35 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    JKO1998 likes this.
  8. Feb 9, 2020 at 8:52 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I mean, I wouldn't worry about the misalignments. You were so overdue for the spherical bearings that they were the real issue. Just replace them.
    So, what's the sound do you think? Not the AC Idler?
  9. Feb 9, 2020 at 8:57 PM
    Speedytech7
    Time to take the belts off one by one. Who knows maybe it's a timing idler or water pump bearing.
  10. Feb 9, 2020 at 9:08 PM
    Speedytech7
    That's what happens to those spacers. It's gonna keep happening, plan to do em once a year or more.
  11. Feb 9, 2020 at 9:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Exactly my thought. Just wasn't sure if that was a "well known noise" that I didn't know :).
    Here are the parts for you:
    90080-10124 1995-2004, 6 cyl 4WD, PreRunner Suspension Lower Front Coilover Flange Bolt
    90170-14026 1995-2004, 6 cyl 4WD, PreRunner Suspension Lower Front Coilover Nut (I didn't replace these, but just in case you want the #)
    That is quite the restraint, kudos (or perhaps, sorry to see you're getting old). Come to think of it, you probably only did that b/c Zane wasn't there to fix your alternator :p.
    Yep, this.
  12. Feb 9, 2020 at 9:14 PM
    Speedytech7
    Haha I've got a spare 5vz alt now just in case. Putting in my 105a Suzuki alt.
  13. Feb 9, 2020 at 10:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Race truck parts..race truck maintenance.
    Seems like a silly move for a cheap part that on the turd gen will will...well still need replaced every year haha
  14. Feb 10, 2020 at 6:54 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    The newer trucks have their own issues too. Unless you plan on swapping trucks every few years, you'll more than likely end up in the same boat.
    You check the fan pulley bearing?
  15. Feb 10, 2020 at 8:42 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Just remember - you went on a what, 2500 mile trip there? There's a reason that when you drive a vehicle for business/govt. use, you get to write of ~$0.52 cents/mile - that's because you should assume that is the wear and tear on the vehicle over that mile. Not to mention depreciation of the vehicle value.
    My guess is that even though you don't love fixing the green truck, (a) it's cheaper to fix than the 3rd gen (or an Excursion) and (b) the depreciation is definitely less.
    That's of course just putting the financial aspect into perspective - you shouldn't change rigs to think that things will be cheaper, because they won't. Of course, I know you've got comfort and "build fun" to consider as well, so it may not be just about financial for you.
  16. Feb 10, 2020 at 8:56 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I have a T100 that needs built if you're having an itch to build!
  17. Feb 10, 2020 at 8:58 AM
    Squeaky Penguin
    Brett
    Fair enough. If what you want is a new build - go for it. But don't think it will exclude you from simple maintenance.
    And quit splashing through puddles. :stirthepot:
    PcBuilder14 likes this.
  18. Feb 10, 2020 at 9:49 AM
    Reh5108
    Idaho
    Long travel, full cage, twin turbos. :burnrubber: you know, all the expensive stuff.
  19. Feb 10, 2020 at 10:16 AM
    Speedytech7
    This I understand too well. It may work really well for what it is right now, doesn't mean you couldn't tear it down to its bones and go after a more creative/capable build. That's kinda what the plan was with my grey truck before I decided it wasn't worth it on that shell. It's what the plan is now, trying to keep it interesting. Certainly isn't gonna save me any money, but I've come to terms with having a spendy hobby.
  20. Feb 10, 2020 at 10:56 AM
    Squeaky Penguin
    Brett
    You said it yourself, the 3rd gen is good for most of what you do.
    Put some decent tires and suspension on it, swap the tent over, go adventuring.
    Then do whatever the hell you want with the 1st gen.
    Kinda where I see myself heading in a few years. Do a very simple build on a 2nd gen (and know where to stop this time), put the GFC on it, and use it for 'overlanding'. Then I can go crazy with my current rig.
