Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 15, 2020 at 9:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    While I love my M18, I have had bolts it was unable to remove. Namely, 6 bed bolts. But then, mine is only the mid-level torque model so maybe that is why.
    This realy sucks. I assume you've tried driving it out with a BFH.
    Out of curiosity, that was not a new bolt or new misalignments last time was it?
  2. Mar 15, 2020 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    New shocks. New bolt. Antiseized.
    Guessed it got worn down as it wasn't an oem bolt.
  3. Mar 15, 2020 at 10:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh, right. Those are the ADSs. For some reason I was thinking Kings. I know Dan had some issues too but IIRC his bolts were not a new set.
  4. Mar 15, 2020 at 10:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah his did what my original bolts did on the kings. Same thing.
    My passenger side one is still in great shape. Looks new. Antiseize made that come right out.
    Driver side though which is just a grade 8 bolt, not so much. I'll get a new OEM one.
  5. Mar 16, 2020 at 6:13 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    What are you guys doing wrong? I'm on the same bolts and misalignment spacers for the last 5 years.
    Lots of spherical bearings though.
  6. Mar 16, 2020 at 6:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Answer is easy for Dan. Excessive miles.
    I figured I was being good. Basically a year old bearing which definitely need replaced. Well..they seemed okay but wouldn't have made it another year.
    Didn't think I had that many dirt miles last year. I did a decent amount but didn't think a ton. So no idea..
  7. Mar 16, 2020 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Well gents, it has happened. I will be working from home starting tomorrow and for the foreseeable future.
    Also, the state mandated the closure of all bars and restaurants. Takeout only ATM. No public gathering. Grocery stores and pharmacies remain open for now.
    m3bassman likes this.
  8. Mar 16, 2020 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well at least now you know you can work from home. So next step is making home...anywhere :cool:
    Same here though. Trying to work from home but I don't really have a mastering grade studio so that's tricky..trying to get my other employees setup too. And Billings shut down everything too.
    Justrom likes this.
  9. Mar 16, 2020 at 10:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thats the thing. I'm not sure I can be fully effective from here. Yeah, for the most part, sure. But many of the under appreciated things I do on a day to day will become glaring holes as time passes.
    But I understand what you are saying. My project tomorrow will be to figure out how to make my IP phone work with my hotspot.
  10. Mar 16, 2020 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well that'll just prove your worth all the more.
  11. Mar 16, 2020 at 10:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    or they'll decide they can just live without them...
  12. Mar 16, 2020 at 10:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I doubt it. You really that worried?
  13. Mar 16, 2020 at 10:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, maybe a little. I would tell you that I don't worry about things I have no control over. And for the most part this is true. But this whole scene is so unpredictable. There are too many factors to consider (worry about) so it is unsettling.
    Speedytech7 likes this.
  14. Mar 16, 2020 at 10:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Meh. Shit'll buff out. You'll see :cool:
  15. Mar 16, 2020 at 10:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :D One of the things I like about you... Your optimism.
  16. Mar 16, 2020 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can be a bit relentless at times even for me...but I suppose its a pro ha
    I have to either figure out how to get my macpro to work again, or...buy a new mac mini pro. Cause I don't have 7k to drop on a new mac pro lol
  17. Mar 16, 2020 at 10:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    it's appreciated, really
    I'm trying my hardest to adapt to being okay with being extremely vulnerable right now as I know many folks I live around are as well. It's not going well, but to hear the optimism from someone who truly believes it, is a powerful thing. So thank you for that :)
  18. Mar 16, 2020 at 10:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The least i can do :cheers:
    You'll be fine for sure. Something will work out. You're very employable. Speaking of, all in all how has machining been treating you?
  19. Mar 16, 2020 at 10:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Macs are the Toyotas of the computer world. They are always more expensive than you think they should be.
    Hell yeah buddy.
  20. Mar 16, 2020 at 10:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no doubt. I mean mine is from 2007 and until well..I tried updating it was working just fine. So 7k for a new one, if it lasts 13 years, that's a good investment in the computer world.
