Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 25, 2020 at 7:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I can warn you about this just a bit.
    You REALLY want to have the wheel and as close to a new tire as possible that is going to as close as possible to the one you're gonna run. Seriously.
    Zane has a lot of wiggle room due to the LT. I don't imagine that's in your play book at least not in the next couple of years. So your dealing with fitting it in a much tighter area. And you won't want to do it twice!
    jubei and Speedytech7 like this.
  2. Mar 25, 2020 at 7:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    8" wide wheels with 0 offset. Right now I could get away with a 35 I think, it'd rub the frame but it wouldnt touch the uca or spindle. I'm running an 11" wide tire with tons of clearance at the moment. Need to get over this virus BS so I can drop MCM a line to get that LT.
  3. Mar 25, 2020 at 7:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do you have it?
    And yeah you'll be fine.
    I need to get Igor ripped apart still and put back together..
  4. Mar 25, 2020 at 7:38 PM
    Speedytech7
    Not yet thanfully, and my work is officially protected. But at the same time it's not a great time to be buying expensive shit. Since we're having okay weather I'm just planning on cleaning my frame and prepping to weld some bracing in.
  5. Mar 25, 2020 at 7:39 PM
    Speedytech7
    You need to get Frank ripped apart, so you can put Igor back together better. Manual trans and LT dbl cab.
  6. Mar 25, 2020 at 7:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah good.
    And good point.
    That would be nice. But I really couldn't do that here haha and can't do it in powell either really cause my dads shop is a wreck since they used it as a kitchen for almost a year while remodeling the house. Can't pull any rig in there.
    Manual trans, dual locked, supercharged, LT double cab. Add crawlbox and GFC and bam. Perfect 1st gen.
  7. Mar 25, 2020 at 7:46 PM
    Speedytech7
    I still think you should come up here and we can do em together. Plus then I can send you home with a welder for your future projects.
  8. Mar 25, 2020 at 7:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The other thing you'll wanna check is your bumper. And might as well do something about the washer bottle now too.
  9. Mar 25, 2020 at 8:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I realize your search may be on hold but I’ll share anyway
    2001 Toyota Tacoma SR5
    http://www.ksl.com/auto/listing/6332605
    Blackdawg[QUOTED][OP] likes this.
  10. Mar 25, 2020 at 9:22 PM
    Speedytech7
    We're you thinking of doing this pain in the ass project in the next month or something. I was thinking when this shit dies down a bit. Good luck tackling this with the welder that the Beverly hillbillies passed down haha
  11. Mar 25, 2020 at 9:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. I like it.
    Always looking!
    Wasn't worried about the rear. They design all those to match the stock rear flare so lots of room. Fronts vary.
    Might as well rip off all the flares too haha
  12. Mar 25, 2020 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I'd imagine it'll either end up not good. Or a new welder will magically be purchased haha
    Oooooorrrrr
    Green truck goes into shop... Ben is ready to take his build to the next level. He's excited. Gets things read and cuts the first large hole in the driver side. After hours of work he's ready to patch the hole only to find it impossible to weld.
    Not wanting to be adventure truck less while he waits to save for a new welder..the turd gen gets the rtt. Slowly the build begins. After a few months Ben finally remembers he had another truck, it's been on jack stands for so long it's become a tool shelf more than anything still with a hole in the floor board.
    And thus Ben became a turd gen instalander. Like a slow disease it consumed him...all from just cutting a hole in his first gen..that he never patched.
    :D
  13. Mar 25, 2020 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay.
    #1 - LT
    #2 - PS
    #3 - L/R Enfuse
    #4 - LR
    So first off, I screwed up the Pano comparison by not using the same kind, thats why one is rounder/taller than the other.
    That said, for me, the PS is clearly better as the LR one is very soft and the detail isn't there. I'm not sure why, because I have no idea wtf LR is doing to make the pano. There isn't any control and while I like the preview option in the new LR to be able to quickly see the different, this is a no go for me. I haven't tried the new version of PS yet so was still on CS6 but it was still much better looking all around to me.
    For the HDR set the LR also sucks. No control over anything. I also have no idea if I tweak the 3 frame any if LR uses the tweaks or just the RAW. Enfuse uses the tweaked images and is just much sharper and not soft.
    So basically I was hoping to use those two tools a lot in the new version as I like taking Panos and HDRs and I took HDR panos...but...not gonna happen. Much more control the other way and the fact the LR ones look soft is annoying. It's almost like the resolution gets stepped down.
    not sure that's as apparent in the web JPEGs but is very noticeable on my work station.
    All in all...disappointing. And not really worth keep the new version and falling into Adobe's damn subscription model..least not yet. Going to keep editing and trying it out to see what happens. I have 2 months free so worth a shot.
  14. Mar 25, 2020 at 9:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    14ga steel? Thats...way to thick dude.
    honestly...3 years? Seriously if that's the real time line then I wouldn't do it. Why? SO much work. I'd start a fund for the new truck, put all the money in there and put 35s on it in 3 years instead. Goes with the good ole saying "buy once, cry once".
    Not to burst the mod bug bubble but...that seems to make more sense then hacking up this truck. Might as well just keep on using the crap out of it for 3 more years.
  15. Mar 25, 2020 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also @turbodb editing with the license plate covers is great. You should just bring a few that are idk...black for random people to put on haha
    turbodb likes this.
  16. Mar 25, 2020 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hm not a bad plan I guess.
    And 14ga is too thick not because of the weld be because of forming it to fit. I tried 16ga and it was not going to happen. Think I explained that in the write up. I used 20ga to be able to form it into the space. You won't be able to bend the 14ga at all into a nice arch and bend it inwards. Not without beating the shit out of it with a hammer and then it won't ever ever ever be straight in the hole.
    Plus, the body is 20ga or thinner. THAT'S your real problem with that welder and why you will really just want a MIG :oops:
    jubei likes this.
  17. Mar 25, 2020 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah..thats why 20ga is better..it's thinner...14 is thicker..no need for that thick at all.
    And its not that MIG is easy..its fucking not easy on the body. Your problem is it is so thin you just blow right through it. If you can't weld 20-22ga steel with the stick you're fucked. You'll just blow through it and make your hole bigger and bigger. That's my point.
    So skip the 14ga. Not worth the practice at all. Just get some 20ga and go from there because thats why you have to weld too and 20ga is the thickest stuff you'll be able to hand form in a nice way with just hand tools.
    Don't be dense :p Even though I know you are. Im just trying to save you hassle and time.
    jubei likes this.
  18. Mar 25, 2020 at 10:13 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yah, saves so much time (from not having to think about it). Have thought about some covers for random folks; problem is that I'm cheap, and the covers aren't. :rofl:
    Doood, talk about getting too far ahead of ourselves. A few days at home and suddenly 35s?, after years of being happy that you were out exploring all summer in a truck that didn't break shit like Frank b/c it wasn't right on the edge? The green truck on 33s is so much more capable than you give it credit for.
    Get that stump removed from the side yard to keep yourself busy. :p
    :luvya: You know I'm just giving you a hard time. Do whatever you want, of course. I mean, if you're going 35s, I think you should try LT as well. Will make a bigger difference than the 35s, if we're all being honest about things. I'd go that way first myself - way more comfortable travel (which is what you like about the orange truck).
    :stirthepot:
  19. Mar 25, 2020 at 10:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    LOL :laugh: that's fair!
    This...is proof...that slowly....very slowly...I'm working my way into your brain
    :gossip: "LT, 35s, Supercharger"
    Do it
    do it
    DO IT!
  20. Mar 25, 2020 at 10:19 PM
    Speedytech7
    That would be a real advantage for you here. Because as a beginner MIG welder you'll still suck and it'll be better than your stick welding. Imagine how good it could be if you got good with a MIG. At least give yourself a Fighting Chance. I get 75% off FedEx shipping, I could probably just send you this spare welder.
    jubei likes this.
