Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 4, 2020 at 7:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Dammit, that was my plan too :/
  2. Jun 4, 2020 at 7:17 PM
    Speedytech7
    At this point I'm not sure what I want for a rear axle anymore. The 80 series one seems like the smart choice still. And diamond has that nice centered diff housing. But off center is fine too with a dual DC shaft. I dunno maybe I do want your housing. Hubs and gears are easy enough to find. I have so much shit to mock up for the rear but I need an axle before I start cutting the frame up.
    jubei likes this.
  3. Jun 4, 2020 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol yeah it's the internet after all!
    I'd probably never buy one. Even a raptor. But they look like a nice mid sized truck.
    Oooooo sweet.
    Also..why? Any reason specifically?
    What are you doing to the rear first of all. Full lt?
  4. Jun 4, 2020 at 8:01 PM
    Speedytech7
    Asking if someone is doing full LT is like telling someone your car build in stages. Means nothing. I'm going to match the rear travel to at least the front, if it cycles more thats great, 14" max for shocks, cause that's what my measurements say will work for structure clearances
    Digiratus likes this.
  5. Jun 4, 2020 at 8:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So you're doing the same thing I'm going to try and do sounds like. Not do a full bed cage. So not full long travel.
    See that wasn't so hard to answer...haha
    Honestly I think a Ford Evo line van 9" will be cheaper to build than a LC one.
  6. Jun 4, 2020 at 8:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There you go... Ford again. :rolleyes:
  7. Jun 4, 2020 at 8:14 PM
    Speedytech7
    That might work, I don't know if it's an 8.8 or a 9" but I'd have to find shafts that work with our 6lug pattern. I'm not sure I want to bother with a Ford axle, especially not if it's only an 8.8. lots of shit to choose from around here. I may just find a tundra or t100 in the meantime. They're simple enough to make work. I just need to mock things up, I hate Toyota semi floats, but they're so cheap I can afford to run one until I blow it up and I have a good record of not doing that.
  8. Jun 4, 2020 at 8:18 PM
    Speedytech7
    It's a tough call to make but I'd feel safe running an American axle, they're far and away easier to find parts for on the go and they're built for heavier duty vehicles. Toyota axles with the exception of the LC stuff are weak sauce second only to Suzuki in overall weakness.
  9. Jun 4, 2020 at 8:48 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    He likes it
  10. Jun 4, 2020 at 8:48 PM
    Speedytech7
    Aren't you eying Ford's version of an Alaskan village on wheels?
  11. Jun 4, 2020 at 8:50 PM
    JKO1998
    Utah
  12. Jun 4, 2020 at 8:54 PM
    JKO1998
    Utah
    I’m just drunk again, carry on, I’ll keep being annoying.
  13. Jun 4, 2020 at 8:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not that drunk. You can still spell. :rolleyes:
  14. Jun 4, 2020 at 8:58 PM
    JKO1998
    Utah
    close one eye and you’re good to go, not my first day
  15. Jun 4, 2020 at 9:03 PM
    JKO1998
    Utah
    He doesn’t know I’ve been drunk since the first of may apparently
  16. Jun 4, 2020 at 9:28 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah if you're willing to dick around with the driveshaft to make it work with the compound angle, should be fine. I don't know why people screw around with early Tundra axles, there's no way I'd jump my truck with a semi float axle.
    The off-center diff doesn't work well on my truck, driveline vibes are too much at highway speeds. I could chase it around with a custom driveshaft, but that's a bandaid fix and I'd be halfway to the price of a diamond housing at that point anyway. That's the main reason, but along with that I'd get a stronger, lighter housing with more ground clearance, custom length to match the front, and RCV shafts that I would probably never be able to twist or break.
    jubei likes this.
  17. Jun 4, 2020 at 9:35 PM
    Speedytech7
    I just need a stop gap measure right now. I'm not looking to jump my truck, just get a proper width axle under the thing to get suspension setup on while my wallet recovers from the financial ruin that is the front LT kit.
  18. Jun 4, 2020 at 9:43 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Seems like a reasonable way to go then. Have you already pulled the trigger on the front kit? You going with the full Solo XLT setup?
    JKO1998 likes this.
  19. Jun 4, 2020 at 9:46 PM
    Speedytech7
    Been talking with folks, gonna go with the MCM kit. Not looking to pull massive wheel travel, I'm looking for insane comfort and ability to keep the speed up on rough terrain. But dunes and jumping shit, while certainly possible here and there for fun, aren't the main goal. Thinking I'm gonna pull that trigger tomorrow, last thing I need to clarify are front spring lengths and rates for the ads coilovers.
    jubei, drr[QUOTED] and Digiratus like this.
  20. Jun 4, 2020 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There is a specific year of eco line van that has a 9" not an 8.8 that is the perfect width for long travel front.
    I'll try to find it. I know I found one locally in a junk yard for $250 so...yeah.
    Gotcha. Very cool.
    How's the 5.29s?
    Yaasssss :cool:
    Also for some reason I thought you'd already bought the kit a while ago.
    My experience stick with 16" coils and if you're going for a light build weight Wise like last time 650 should be good or even 600. Remember the lever ratio is different on the shocks. I'm running 700s which on Frank were a dream with 0 preload. Igor probably be a bit stiff
