Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 6, 2020 at 10:58 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I know I'm not Monte but Matt's email is: matthew@mcmfablv.com
    Speedytech7[QUOTED] likes this.
  2. Jun 6, 2020 at 11:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We are all Monte on this blessed day
    BossFoss, jubei and Digiratus[QUOTED] like this.
  3. Jun 6, 2020 at 11:57 AM
    Speedytech7
    So I went and bought a winch. And you're all going to hate it :p
  4. Jun 6, 2020 at 11:59 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    As long as you didn’t get a shittybilt POS
  5. Jun 6, 2020 at 12:36 PM
    Speedytech7
    Better
  6. Jun 6, 2020 at 1:21 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Literally everything is better
  7. Jun 6, 2020 at 1:25 PM
    Speedytech7
    Lol show me on the doll where the winch touched you. There's a story here I'm sure.
    When you see what I got you might not think so low of the Smitty
    BossFoss likes this.
  8. Jun 6, 2020 at 1:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Harbor Freight
  9. Jun 6, 2020 at 1:29 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    There is. It’s one of my three main rants I rotate through on this forum.
    I’d take a Badlands over a smitty
  10. Jun 6, 2020 at 1:33 PM
    Speedytech7
    jubei, Digiratus and drr[QUOTED] like this.
  11. Jun 6, 2020 at 3:38 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Shit at 12k even it halfway works it should pull you out no problem.
  12. Jun 6, 2020 at 4:23 PM
    Speedytech7
    Some minor modification is taking place
  13. Jun 6, 2020 at 6:13 PM
    Speedytech7
    Professionally bodged together
    jubei and Digiratus like this.
  14. Jun 6, 2020 at 7:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Where is the contractor? Seemed unlikely it would fit anywhere in the bumper.
  15. Jun 6, 2020 at 7:36 PM
    Speedytech7
    Elsewhere, it came with a relocation kit, including brackets to mount on another surface and cables. I haven't decided if I want it on the top of the bumper or somewhere in the engine bay yet. I'm leaning toward the engine bay. Anyway the entire thing is IP69x rated so it's not really a concern. Has wireless and wired remote function too.
    jubei likes this.
  16. Jun 6, 2020 at 7:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds like quite the setup. Very nice. Are the mounting points the standard 4 x 10 pattern?
  17. Jun 6, 2020 at 7:47 PM
    Speedytech7
    Yup, fit right in and bolted down perfect. Completely standard and it only had one set of holes
  18. Jun 6, 2020 at 8:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That was the one concern I had.
    I had to go find my HF coupon book/magazine (found it in the recycle bin :p) to see their ad for this. Listed at $599. -20% = $480 + tax. I'll bet they will have it marked down even further at some point. I think I might keep an eye on this. If for no other reason so Dan won't disown me for having a smittybilt. :rofl:
    drr and Speedytech7[QUOTED] like this.
  19. Jun 6, 2020 at 8:07 PM
    Speedytech7
    I got it for $480. I remember seeing it in store for $799 at one point so I jumped on it. Just gotta be prepared to make a longer clutch handle since it isn't clockable.
  20. Jun 6, 2020 at 8:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Would it not fit underneath the top plate?
