Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 28, 2020 at 9:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm not interested in selling them, I figure I'll hand out the dxf files and people can get em cut however they want
    jubei and Blackdawg[QUOTED][OP] like this.
  2. Jun 28, 2020 at 9:11 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Pretty neat. Also not sure I like the canopy without the frame...
    But I do like that the mattress is an Exped. Making it that 2" wider than the GFC is going to be great for sleeping comfort from that regard.
  3. Jun 28, 2020 at 9:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well what da fawk. I guess I'll need another set anyways haha
    hurry up! :D
    The bed in general is larger. Its more like the Vagabond in that regaurd. The floor always has an open section. So there is more over hang.
    Be cool either way. No budget for that crap though.
    I used 3/16 haha
  4. Jun 28, 2020 at 9:22 PM
    Speedytech7
    I'd have them cut out of 3/16 for myself as well.
  5. Jun 28, 2020 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah figure might as well.
  6. Jun 28, 2020 at 9:40 PM
    Speedytech7
    I'm not looking to do it again. If I had a coil bucket to use as an example I'd just build a whole new set out of 1/4". 3/16 will be perfect, the weight between the two for something this size will be negligible anyway. But it makes it so I don't have to also have coil bolt pattern circles cut out of 3/16 to reinforce that on top of an 1/8 bucket reinforcement. But hey that's why I'd offer the DXF, I don't care to argue it with folks who know what they want, not my build not my problem.
  7. Jun 28, 2020 at 9:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I feel like is positioned to be in between the GFC and the Vagabond. The design without the frame is a lite-duty drifter and at 300# it is a little more than the GFC.
    Price (not intro) will be in between as well.
    1/4" or go home. :rolleyes:
  8. Jun 28, 2020 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    All 2lbs of it.
    I'm using the top hats from @eimkeith which are 3/16 so matching mostly. But also...why not? Beat the hell out of them now.
  9. Jun 28, 2020 at 9:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah it's cool to see another option. Some cool feature on it for sure. Lot of money still though..too much for me.
    Well..that bucket will be 1/4" after I'm done does that count? Haha
  10. Jun 28, 2020 at 9:47 PM
    Speedytech7
    I have no idea who you're talkin about. All I know is I'm building wrap around reinforcements out of 3/16. To use your metaphor. Instead of stacking two sheets of paper I'm going to use a sheet of cardstock to reinforce my paper. Thank you for coming to my TED talk
    jubei and Blackdawg[OP] like this.
  11. Jun 28, 2020 at 9:50 PM
    Speedytech7
    Then it should work absolutely fine for you and stock geometry.
  12. Jun 28, 2020 at 9:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sort of true.
    Brett added a ring but he did not weld it to his top hat. It was really just one giant washer that the three bolts passed through.
    Eimkeiths is made to be welded to the truck.
    I'm basically.aking wrap over reinforcements just in three pieces. His is the top and I'm making the sides and will weld them all together on the bucket.
    And I'm sorry but the maybe 2lb difference between 1/8" and 3/16" for this job is not worth fighting over. Haha Im going for overbuilt not "good enough". There is too much evidence of this being a problem we all should be worried about and I don't want to ever have to redo it.
    This isn't the same as like talking about 1/8 vs 3/16 for skid plates to me.
    Speedytech7 likes this.
  13. Jun 28, 2020 at 9:59 PM
    Speedytech7
    I'm underway for the rear stuff already. Been working on my axle. Need to get this front stuff made but I'm hesitant to rip the engine out until the Lexus sells. I'm not going to put any LT shit on without the reinforcements.
    jubei and turbodb like this.
  14. Jun 28, 2020 at 10:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    A catastrophic failure, the worst case scenario, takes an unbelievable amount of effort to overcome. I sure hope that no one else has to go through that.
    jubei and m3bassman like this.
  15. Jun 28, 2020 at 10:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Difficult to be certain of that. I don't think there was any evidence of impending failure. I was certainly aware and looking.
    It may be that the only certain way to know is to actually remove the CO and inspect that way. Otherwise the beginnings of cracks are too easily hidden.
    m3bassman[QUOTED] and turbodb like this.
  16. Jun 28, 2020 at 10:10 PM
    Speedytech7
    I do but I'm prepared to build my dream truck now and I want it out of the way, or I'll spend more money on it and slow down the truck build. It's a matter of priority, I like the truck more and I want to build it because ideally it's a toy I can use to escape home and work and hang out with folks like you. And that's far more interesting than beating a couple of kids in Subarus to work. Which I can probably do in a turbo Tacoma anyway, cause let's face it Subarus are lame as fuck. So the Lexus will go, I'll find another, or maybe I won't. Either way I got to play with it and work on a 2J, and save a car from neglect. What could be better?
    jubei and m3bassman[QUOTED] like this.
  17. Jun 28, 2020 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know you would that's why I said it haha
    Yeah true. I wanna go fast..all the time. Well...like 90% of the time. Too much either way.
    I don't wanna have that shit happen to me like it did to Mike. That wasn't fun to see or get out of the woods. And my God a lot of work to fix.
    But I wanna go fast...
  18. Jun 29, 2020 at 8:39 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    My thoughts on the coilbucket -
    A - check frequently and repair before its a serious issue. If you blew out your coilbucket, there was probably evidence it was about to fail long before hand. Sorry Mike. Add it to your list of pre-trip inspection items.
    B - I still think a crossbrace between the buckets to prevent flex would be one of the best solutions. I would have one already if I had access to a bender.
  19. Jun 29, 2020 at 9:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there are a few in the area every year. And In some ways, I will end up there. Just can't now. No shop space for that kind of build. Hopefully some day though.
    Crossbrace would be best for sure. But Im in the same boat, I don't have a bender....well actually I do but again, no room to use and I don't want to install it at my rental and piss off the land lord or neighbor rental.
    I have the DD brackets for it though. Sitting on a shelf...
    Either way, I think reinforcing the bucket itself is not a bad idea.
  20. Jun 29, 2020 at 11:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    uhhh...holy shit. Solo is just sending me brand new arms..wow. Wasn't expecting that.
    Reh5108 and jubei like this.
