Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 10, 2020 at 10:57 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    You can't see, but the leaf across the back is attached to the bottom of the frame. So, it's just providing more resistance. Like having an extra half-leaf pack on each side of the wagon.
    Here's one photo, a few more in the write up.
  2. Aug 10, 2020 at 3:18 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    So the horizontal leaf pack with a set of shackles connected to the longitudinal shakles acts like suspension for the body of the wagon and the regular set of shackles is suspension for the axle?
  3. Aug 10, 2020 at 3:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    was wondering how the axle doesn't wander under the wagon top laterally, looks like it has all that shackle room to move left and right
  4. Aug 10, 2020 at 6:06 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    My guess is that it does wander more than it would otherwise. But the speed that wagon saw in it's lifetime was probably in the what, 5-10mph range? :) Probably not very fast, so not as much of an issue.
    Also, I think there were u-bolts on that crossmember originally, and as we all know, those things are pretty strong, so probably helped prevent too much lateral movement as well.
    But hey, someone should go grab it and rebuild it and then we'll know for sure, hahahaha.
    Speedytech7[QUOTED] likes this.
  5. Aug 10, 2020 at 6:09 PM
    Speedytech7
    Kinda interesting that it has a differential though huh? makes me think it wasnt always towed
  6. Aug 10, 2020 at 6:13 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I think that it was originally a frame from a vehicle. Later repurposed, and that rear cross brace (with the funky leaf pack) was added.
  7. Aug 13, 2020 at 6:57 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Bummer.
    Well, you're welcome to borrow the tools, or come over and we can do the job here... I mean, the "good" news is that it's not hard to fix, just a couple hours of time.
  8. Aug 13, 2020 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bearings aren't bad. You have a press? It'll be damn expensive for a shop to do it. And they might not do it right.
    Also..weird. my foxes have never done that.
  9. Aug 13, 2020 at 8:49 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, should work time wise.
    I think there's debate on how long you can run with a leaky seal. My theory is that it comes down to whether
    • the seal goes bad first and will eventually cause the bearing to go. In which case you can run longer. ...or
    • the bearing goes first, and it is what caused the seal to go. I this case, you're on a "shorter" clock.
    But again, just theory based on what I've heard from people who had bearings go, and people who have run with leaky seals for a long time (sometimes years).
  10. Aug 13, 2020 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd argue it's the opposite.
    My rear bearing took 6-7 months to die before the seal went out. Been was there for that. And that thing was TOAST.
  11. Aug 13, 2020 at 9:43 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Ben's already at the point where the seal is leaking though. So if his bearing isn't bad, then he might have 6-7 months.
    Again, none of us really know which is why I said there is debate, but we can find plenty of places online where people run leaky seals for an extended period of time. Or, they say they do. We can also find plenty of places online that say "you need to replace as soon as they start leaking."
    We had an interesting conversation around the camp fire on our last trip on just this topic! :) As with everywhere else, there were differing opinions (I think it was ~50-50 on the opinions) and none of us really knew for sure.
  12. Aug 13, 2020 at 10:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    2nd gen leafs? Not sure that'll go over awesome but cool.
    If the bearing isn't making noise I'd say your okay. Granted mine made noise for a long time and steadily got louder. You might not be hearing iver the tire noise as it is or just assuming it is tire noise. When I replaced mine I was shocked how much quieter it was haha
    I mean no one knows if the seals fail first and then the bearing. Or the bearing goes bad causing the seal to go bad.
  13. Aug 14, 2020 at 12:36 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Hopefully my POS truck makes it there. :rofl:
    Do you have a press? I'll stop by on my way up and help if you just want to knock it out.
    Otherwise, I'd send it. Just check your gear oil occasionally, and know that your rear brakes won't do shit.
    turbodb likes this.
  14. Aug 14, 2020 at 12:49 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I'm with Brett. I think you'll be fine as long as you keep it lubed and the bearing wasn't the problem to begin with. I drove my 4Runner over 500 miles with both seals leaking and when I pulled out the bearings, they still felt tight. Of course, it's anecdotal, but still.
  15. Aug 14, 2020 at 3:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The 99’s had popped seals for atleast 2 years, doesnt really ever get driven Other than during the winter though
  16. Aug 14, 2020 at 5:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Buy a press. It's handy as hell for lots of things.
    Brett Im sure will bring the tool to press out the old bearings and I bet if you asked nicely some 2'' tubing to smack in the new ones.
    You'll only need the press. And that'll be handy for the rest of your life.
    Just make sure your remember the C clips...cause Brett won't :laugh:
    BossFoss, Squeaky Penguin and JKO1998 like this.
  17. Aug 14, 2020 at 6:12 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I know it isn’t a trivial amount of money, but I’m with Monte. A HF 20T press isn’t ridiculously expensive, and you can fab up a puller tool with some steel and your welder.
    Get the tools, learn how to do the job, and knock that shit out :D
    Squeaky Penguin likes this.
  18. Aug 14, 2020 at 6:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Brett, Brett, and I had igor done in like 5-6 hours. If you have the truck torn down before Brett gets there you'd be done in 3 I'd guess. Or less.
    Barely cut into the wheeling time. Start the beer timer earlier if anything
  19. Aug 14, 2020 at 7:15 PM
    Squeaky Penguin
    Brett
    Well it's too late :luvya: cause I have a few extra days and working on a scenic route to get to Ryan.
    Just need to figure out what the scenic route entails...
    m3bassman likes this.
  20. Aug 14, 2020 at 8:41 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    What general route are you taking up? A quick stop at City of Rocks would be well worth it IMO, if it's on your way.
