Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 16, 2020 at 4:14 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Good plan not to modify; those are top heavy and will tip over very easily. Make it safer welding a piece of 1/8 steel to the front of the 'feet' or guy wire the top to the wall stud!
  2. Aug 17, 2020 at 9:18 AM
    トヨダ MASTER
    トヨダ MASTER Toyota Hoarder?
    Woods Landing, WY
    '18 T4R '07 FJC '84 PU w/LS '83 Hilux '94 PU '80 Hilux w/R2.8 C
    Didn't one of you guys do a Prerunner to 4x4 conversion a while back?
  3. Aug 17, 2020 at 1:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    @BossFoss did a 4wd and 5spd conversion to his double cab....then decided to put a diesel in it haha
  4. Aug 17, 2020 at 2:37 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Whatever became of this unicorn?
  5. Aug 17, 2020 at 3:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Still in progress I believe.
    This is Brett's busy season so probably won't be until Nov he comes back to it.
    Plus he has a working 2nd gen with a GFC on it to use now as well for the camping season.
    gordi[QUOTED] likes this.
  6. Aug 17, 2020 at 3:42 PM
    トヨダ MASTER
    Woods Landing, WY
    I'm back by the way. This is Will from Laramie. I thought somebody did something like this. Having trouble finding good info on this swap with an Auto trans.
    Digiratus likes this.
  7. Aug 17, 2020 at 3:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There are some others that have done it. Look for double cab swaps as they all have autos.
    It shouldn't be too hard though. Only annoying part will be the tcase you end up using and ADD tube and the wiring for that setup.
  8. Aug 17, 2020 at 3:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Were you member 1 million?
  9. Aug 17, 2020 at 4:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    #317095
    トヨダ MASTER likes this.
  10. Aug 17, 2020 at 4:05 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Any update, Ben?
    At this point I'm not planning on going through Boise at all, but may be able to rearrange things to be there Thursday afternoon (assuming you have a couch to crash on or place to setup the GFC) or Saturday midday.
  11. Aug 17, 2020 at 4:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The Will I remember from Laramie was an auto shop owner with a username of member 1 million or zillion or something like that.
    @トヨダMaster's refference to being back made me remember the Will from Laramie (I think) who got banned a couple of years ago.
  12. Aug 17, 2020 at 4:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahhh right right.
  13. Aug 17, 2020 at 4:50 PM
    トヨダ MASTER
    Woods Landing, WY
    I already did the swap. Just working on little things now.
    I seem to remember a past life. Perhaps......
    :yes::D
  14. Aug 17, 2020 at 5:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotcha. What kind of details?
    Welcome back. Forgot you'd been banned haha
  15. Aug 17, 2020 at 5:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Understood. Welcome to TW. :)
    Also, it is a bit of a challenge to tag you. I don't know how to type one of these.
  16. Aug 17, 2020 at 6:00 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Yeah it's still in progress. Swapping to manual was easy just had to trick the neutral safety switch for starting ability. It will be winter for sure before I get back to it. Been de-consructing the old extended cab to sell in my free time. Just need to get the rear leafs off for the DC and it's ready to sell. I was in Laramie Saturday moving some friends down for school. Lame the mt west canceled football.
  17. Aug 17, 2020 at 9:18 PM
    Fishing Grizzly
    Fishing Grizzly Well-Known Member
    Joe
    Southern Idaho
    2011 DCSB TRD OR 6 speed
    ARB Bumper URD Short Shifter Leer 100r Caliraised bed stiffeners Meso dome light Ironman stage 2 w/ constant load leafs
    Hey guys, I recently had to cancel a trip due to the virus and now am looking to to do a road trip instead. Looking to explore north western Wyoming. Avoiding yellow stone though. Looking for national Forrest, lakes to fish and camp by for a few days. My buddy isn’t super keen on technical off-roading but fire roads are good. Also looking around Jackson to do some golfing too. Any recommendations?
  18. Aug 18, 2020 at 6:44 AM
    ns7i
    ns7i Member
    06 Tundra DC Limited
    Shadow Mountain around Jackson is NF and has a great view of the Tetons, Green River Lakes is super beautiful north of Pinedale, Beartooth Pass/Chief Joseph are amazingly beautiful roads and have lots of NF both on the Wyoming and Montana sides. My favorite part of Yellowstone is getting there and getting out.
  19. Aug 18, 2020 at 7:46 AM
    トヨダ MASTER
    Woods Landing, WY
    Details on the swap? Did it in my shop with a lift and trans jack. I had all the parts leftover from my SAS Taco project(the one in my avatar currently). I think I spent under $400 for everything including new wheel bearings and seals.
    We've talked before, I bought some parts from you a couple years ago. Google "toyoda" and convert it to Japanese. "Toyota" is a smidge different. I went with the original spelling. :thumbsup:
  20. Aug 18, 2020 at 7:49 AM
    トヨダ MASTER
    Woods Landing, WY
    What are you doing with the leftover x-cab and how complete is it? I might be interested. Yeah, the sports thing kinda sucks. Laramie needs those dollars! I'm a small business too so a bit nervous about the near future.
