Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 4, 2020 at 10:48 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    A clean looking old school taco. Such a pretty sight! Don’t stick around here too long. Those tend to get rode hard and put away wet haha. Wouldn’t want you to follow suit with the the rest of us
  2. Oct 13, 2020 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Oct 13, 2020 at 10:21 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    What pump are you talking about? I didn't realize you were having a pump issue...
    Also - that 5th gear swap does seem super interesting. Probably over my head for now, but boy, I'd love it on the highway.
  4. Oct 13, 2020 at 10:23 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  5. Oct 13, 2020 at 10:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    washer fluid pump. Sprayers won't work on the dd.
    And it really doesn't seem too bad to do honestly. If you do your clutch soonish that would be a great time to do it. Honestly doesn't look that complicated. I think I'll try it when I swap my Tcase. Im at 2750 rpms as it is going 70ish. So about 300 rpms won't be bad, be great for gas i bet.
  6. Oct 13, 2020 at 10:29 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, maybe I can get some moral support from the rest of the WA crew if I do it, that always seems to make things go a little less stressfully.
    You do it first, then I'll do it. ;)
  7. Oct 13, 2020 at 10:31 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've swapped gears in a manual before, it was a Nissan FS5W30A but same basic idea, important thing is order of components, perfect task for anyone who's anal retentive and can hold a tool, so naturally I struggled :p It's not bad as long as it isn't a gear near the center bearing plate, those are pressed.
    turbodb[QUOTED] likes this.
  8. Oct 13, 2020 at 10:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha I probably will. If it goes well I'd do that to Frank. Could do normal speeds under 3k maybe haha
  9. Oct 13, 2020 at 10:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah this is just 5th so you just split the Tcase and it's right there, don't even have to open the full tranny.
    Looks very simple to do. Only like 3 things that you really need to not loose haha
  10. Oct 13, 2020 at 10:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just regear your diffs already.
    but you could do that but I read its REALLY hard to find the gear and you have to swap the shaft so probably very expensive as well and a pain.
  11. Oct 13, 2020 at 10:56 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Or put the 32s back on. :rolleyes:
  12. Oct 13, 2020 at 11:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    certainly not impossible. But quite a task and Im not even sure you could find the parts as you'd have to get something from an r150 in the early 90s. But I guess you could buy an old yota tranny and hope for the best and tear into stuff.
    m3bassman[QUOTED] likes this.
  13. Oct 13, 2020 at 8:39 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Does your washer reservoir have its cap still? I had the same problem when my reservoir cap disappeared. Mouse decided to commit suicide, decomposed, spray nozzles were clogged with mouse hair.
  14. Oct 13, 2020 at 8:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    HA! that is awesome.
    Yeah cap is fine. Plus I put new nozzles on it. The pump isn't firing for some reason which I knew the switch was bad. However it has a full new steering collum and stalk in it as well and when I did that I checked with a volt meter and power was being sent to the plug correctly when the button was pushed. Tried 2 different pumps now too.
  15. Oct 13, 2020 at 8:59 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    @Blackdawg we‘ve got a new artist space in Dubois called the Barn at wind river. He’s got a page on Facebook, looks pretty cool, hope to dust off all my guitars and check it out soon. Might end up with our own redneck tippet rise:rofl:
  16. Oct 13, 2020 at 9:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not impossible however unpluging the line at the pump does nothing. Just runs out of the pump. No pressure when fired.
    ha nice. Doesn't look like much but doesn't mean cool things can't happen there!
  17. Oct 13, 2020 at 9:06 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    What? A calving barn turned into a sound stage isn’t the height of sophistication?:D
  18. Oct 14, 2020 at 10:26 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Move to WY
  19. Oct 14, 2020 at 10:57 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    too far away. And not enough land.
  20. Oct 14, 2020 at 11:20 AM
    JKO1998
    Utah
    Fair, lots of cool thing right around it though
