Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 21, 2020 at 11:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I wasn't me. It was turbo.
  2. Oct 21, 2020 at 11:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ah sorry.
  3. Oct 21, 2020 at 12:15 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah for sure. I generally carry a chock block with me, if it’s super steep I’ll throw that in front of the tire.
    jubei and m3bassman[QUOTED] like this.
  4. Oct 21, 2020 at 5:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @Speedytech7 just an FYI if you're planning on getting those led headlights again, they do not melt snow and I would guess don't have a heater element in them.
    So that's a bummer
  5. Oct 21, 2020 at 5:51 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Huh, well that's too bad, I bet it's not a major concern for most. Rigid is the only one offering such a thing, or at least mentioning it as a feature. I'm not really concerned about it though, my truck isn't a daily and sits in the driveway most of the time, it's on MTs anyway, not a great idea for the packed ice our roads get after a day of snow.
  6. Oct 21, 2020 at 6:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    JBL Also makes one, actually read great things about it.
    not any cheaper though than the Rigid ones though.
  7. Oct 26, 2020 at 8:00 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Anybody looking for an 80's cruiser project? Located in Riverton Wy
    Blackdawg[OP] likes this.
  8. Oct 29, 2020 at 7:54 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I don't know the answer to your question. I've liked the Plastics Guy Durobumps, but dang, they are expensive now.
    Edit: ...though maybe not all that expensive when compared to other options... Why are little bits of rubber so $$$?
    https://toyotabumpstops.com/product/1st-gen-toyota-tacoma-4-25-rear-bump-stops-1995-2004/
  9. Oct 29, 2020 at 7:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am running timbrens in the rear. IIRC, they were sold as 2ng gen pieces. :notsure:
    How are you planning to mount them? U-bolt flip?
    turbodb likes this.
  10. Oct 29, 2020 at 7:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What’s wrong with the 1st gen super bumps?
    other than if you’ve flipped the U bolts
  11. Oct 29, 2020 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah they will work. Worse case they bump too tall but likely you'll be fine.
  12. Oct 29, 2020 at 8:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    man you suck at interneting these days :p
    JKO1998 likes this.
  13. Oct 29, 2020 at 9:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have a pic of the timbren mount you have?
    Or maybe from allpoo?
  14. Oct 29, 2020 at 9:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well thats not good.
  15. Oct 29, 2020 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
  16. Oct 29, 2020 at 9:44 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Or, 2x 4.0Ah plus one tool for $199. One of the "tool" options is a 5.0Ah battery, though as a woodworker, I'd get the router, hahahaha.
    https://slickdeals.net/f/14472374-m...hackable?prop=pfd-14472374|prt-3&src=featured
  17. Oct 29, 2020 at 9:54 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    So... I checked my spherical bearings yesterday. Actually, I was going to change them (b/c I heard them squeaking in CO), but on removing the lower bolt and playing around with them prior to completely removing the shock, I decided I could get one more trip out of them. And I may try to push it a bit to 2 trips.
    The ball is "loose" but doesn't wiggle.
    Right now, this set has ~5K miles and 2 trips on it. Each additional trip will be ~2K miles (Death Valley). With this set, I have not washed the spherical bearings directly, as I was doing with previous sets.
    I also have one more set (I think) of the regular-steel bearings from ADS, which I'll use before I try out the Stainless Steel variant.
    That 2x4.0 and 1x5.0 deal might be a good way to go then (also, if you read through that deal on Slickdeals, you can return the 2x4.0 and get the 5.0 for like $85) Or, Mike's link for 2x6.0's seems pretty cool to me as well.
  18. Oct 29, 2020 at 10:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean...how often do you actually use it on trips? You're never out in the woods that long anyways.
    I have 2.0Ah in my M12 stuff and they last a pretty darn long time. I think it have a 4 or 5 for the m18 though.
  19. Oct 29, 2020 at 10:20 PM
    Speedytech7
    You can probably stretch two amp hour a lot longer on the tiny tools. I only have five amp hour batteries for my makitas. They last a long ass time though.
    Ben just get yourself a nice discounted stolen battery. Got to be like the most common thing on the Facebook groups up here haha
    gordi and m3bassman like this.
  20. Oct 29, 2020 at 10:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    likely just a battery if you cheaped out on them.
    And sure I get that. Im much more religious about my batteries though and make sure they are fully charged no matter what before a trip.
