Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 31, 2020 at 5:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I could only move it a few thousandths as well. I did however bend the large punch monte bent all those years ago back to straight lol
  2. Oct 31, 2020 at 5:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The new tool to use is a ground down prybar. Works way better.
  3. Oct 31, 2020 at 5:19 PM
    Speedytech7
    I have hardened punches that worked fine for my Icons.
  4. Oct 31, 2020 at 5:27 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Obviously I was unclear. It was easy to move the ring - we had the shock in the spring compressor, and so no pressure from the coil. I was giving Mike a hard time b/c he knew how many thousandths he wanted to move the ring up the body. I've always just counted threads.
    Digiratus likes this.
  5. Oct 31, 2020 at 5:27 PM
    Speedytech7
    Neat
  6. Oct 31, 2020 at 5:34 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I need to do this. My punch has a nice bend to it now as well :rolleyes:
  7. Oct 31, 2020 at 5:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :gossip: He probably doesn't remember. :rofl:
    You probably di change the ride height. But it was only by a few .001". Todays change, lowered the right front about ~.5"
    The real problem is when the shock is on the truck there is just no room to work. The resi hardware is right in the way and the adjustment ring does not have enough holes in it.
    Speedytech7[QUOTED] likes this.
  8. Oct 31, 2020 at 5:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What surprised me most, well, other than driving down your alley and finding a brannick spring compressor mounted to a telephone pole, was how little the spring had to be compressed to relieve the tension.
    turbodb[QUOTED] likes this.
  9. Nov 1, 2020 at 1:37 PM
    Speedytech7
    Today is a red letter day. Those of you whom have witnessed or been a part of fabrication projects at my house know that the vise is strictly a nomadic and floor dwelling fixture. But no longer I say! It now has a home, one which I painstakingly beat into submission so that it would fit sturdily.
    You can barely even see where my mallet and punch destroyed the powdercoat on the bench.
    jubei, drr, Blackdawg[OP] and 2 others like this.
  10. Nov 1, 2020 at 4:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Solid work!
    I spent the afternoon coming up with some ditch light brackets that are on the mirrors. Prototype is going well.
    The hardware and mounting bracket for these lights sucks though. Won't actually tighten down which is annoying.
  11. Nov 1, 2020 at 4:20 PM
    Speedytech7
    So we got to test the new Millimeter Wave 5G, you're not reading that wrong. We actually pulled 3gigabit per sec on the next one but didn't screenshot it
  12. Nov 1, 2020 at 4:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow I thought it was only supposed to be 1 gigabit?? Haven't seen anything near that high.
    Probably because not a lot of people are using it though.
    But cool! Be years before I see that haha
  13. Nov 1, 2020 at 5:52 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    They have gotten around 70gbps in labs with 5g.
    But most deployed 5g is in the 700mbps to 1gig range. But pretty much all the players in 5g have state their plans are to eventually get up to 10gig speeds and to expand 5g from just cell service into isp service for home.
    What's crazy is the towers only have a range of 1500 feet (least when it first came out).
    I'm more excited for Starlink since I might actually see that service lol
  14. Nov 1, 2020 at 6:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting.
    Yeah the range is not good. Some cities will see the benefits more than we will.
    And elon musk can go fuck himself with starlink. Not happy about that personally. will single handily ruin our night skys. Plus..bit of a bummer to have internet literally everywhere.
  15. Nov 1, 2020 at 6:36 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I remember watching people when t mobile first out 5g towers in NYC. Signal was great unobstructed. But stand under an umbrella and it would drop to 4g
    Starlink is definitely a love hate. The potential benefit for having that internet "everywhere" isn't a bad thing. The wife has worked in remote places in AK where the internet was prohibidly expensive with slow speeds and crap data caps (like 10gb a month). Being able to have Starlink in those places would be huge.
  16. Nov 1, 2020 at 6:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Who's network is Millimeter Wave on?
  17. Nov 1, 2020 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    think he's just talking about how it works.
    bingo
  18. Nov 1, 2020 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, got it.
    Millimeter wave ia a refference to the frequency spectrum. It looks like it is Verizon's new 5g network.
    Verizon’s 5G network will be based on higher frequencies—more specifically the 28 and 39GHz frequencies, known commonly as millimeter wave spectrum. These frequencies can carry massive amounts of data at very high speeds and with very little latency, or lag. That makes them ideal for accommodating a massive increase in data demands from mobile-first users, connected homes, AR/VR devices, cloud gaming systems, self-driving vehicles, IoT sensors and other cloud-connected devices. In the global race to 5G, Verizon’s investment in millimeter wave technology can provide consumers and enterprises with more computing power than ever before.
    https://www.verizon.com/about/our-company/5g/what-millimeter-wave-technology
  19. Nov 1, 2020 at 9:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    correct.
    also why it doesn't do well in long distances or through/around objects
    jubei likes this.
  20. Nov 2, 2020 at 4:27 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its not just "on paper" anymore. its already out there in beta. People are actually using it and its been working quite well. We are well past the point of stopping it at this point.
    I was against it for the same reason as you guys but now that its here and actually working...the potential benefits and talking to people/groups who will truly benefit from it...itll bring good (potentially...like everything it depends how its truly deployed)
    But could never argue against the point of cluttering the night sky with satellites.Its by far the biggest negative
