Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 5, 2020 at 2:36 PM
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    MAP only systems have poorer streetability mannerisms, they rely a ton on their alpha-n map because the pressure sensors are less accurate than a MAF. I can build a half ass alpha-n map, and will, but I don't want to rely on it for all of my out of boost behavior. I'm just going to go up to a Nissan Q45 MAF (its huge diameter and common, plus has been mapped for aftermarket computers so I don't have to build a sensitivity map). Plus this gives me redundancy. I can run with only a MAF, only a MAP (MAPs in my case cause I wanted one for barometric pressure too), or just in alpha-n. But all things running correctly I'd want to be in blended volumetric and MAF metering for best efficiency and behavior with alpha-n as a fallback failsafe.
    Blackdawg[QUOTED][OP] likes this.
  2. Nov 5, 2020 at 2:37 PM
    Speedytech7
    Really good question though, I thought a fuckload about it, and if I was building a trailer or track queen I'd ditch the MAF since wide open would be more common and street driving wouldn't matter as much.
  3. Nov 5, 2020 at 2:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fun.
    Build me one while you're at it :p hahaha
    Speedytech7[QUOTED] likes this.
  4. Nov 5, 2020 at 2:46 PM
    Speedytech7
    Well you and I have the same exact configuration, so I'll be nice and map all my pin to pin connections for ya.
  5. Nov 5, 2020 at 2:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'll take that. haha
    what size whistle you gonna run?
  6. Nov 5, 2020 at 2:53 PM
    Speedytech7
    You're gonna hate it...
    Garrett T3 .63AR 60trim compressor 51mm compressor, water cooled and oil lubricated
  7. Nov 5, 2020 at 3:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow tiny. Insta boost. Not gonna have a lot past 3500rpmish Id say. Eh...maybe 4k. Which is enough.
    I don't mine the size overall, but T3? really? I'd do the same A/R but a T4
  8. Nov 5, 2020 at 3:29 PM
    Speedytech7
    I’m thinking you’re overestimating the flow of this 3.4 haha. We’ve had no problems with T3 flange at 500hp on a 3.0 v6, which I intend to not even come close too. This thing will be done about 350hp. Not cause the flange is outflowed, but because the turbo is tiny. I’m not trying to stress the 5VZ, there’s no aftermarket for it and the main bearing design is meh at best. Just want some extra fun on top of the LT.
  9. Nov 5, 2020 at 3:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    mmm. Idk. I mean I know the T3 will work but I think it's still too small for good flow.
    But yeah, not like we are going for 450+ here. So ultimately probably be okay.
    I also want to keep preassure down but flow high. So I'd like to go a bit bigger than you and t4 to flow better and have lower pressure.
  10. Nov 5, 2020 at 3:42 PM
    Speedytech7
    I suppose we will find out. I think staying the same size turbo and going for t4 will be a net 0 improvement in flow. And I really don’t want to go bigger on the turbo, this one maps well to the 5VZ. I’m not going to let the boost come in too hard either, really going to be nannied hard by my ECU tune to keep it safe.
  11. Nov 5, 2020 at 3:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean I've seen dudes in the turbo thread go from t3 to t4 on the 3rz and like it a lot more haha t3 is pretty small.
    But you'll have full boost by 2200 I bet easily haha
  12. Nov 6, 2020 at 6:26 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    motha fucking t case in the tow pig needs a new chain. Its making a horrific clunking noise in 4 lo, looks like the drive shaft is jumping. all signs point to case. Should be a fun project
  13. Nov 6, 2020 at 8:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I spy with my little eye...
    https://www.instagram.com/p/CHD6RB4HhEz/?igshid=2n9fz90io7r0
    Bummer. Hope it's a simple fix
  14. Nov 6, 2020 at 9:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats not a standard GFC..look closely.
  15. Nov 6, 2020 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well I do. And im sure a few others. But thanks for letting us know you don't. :notsure:
  16. Nov 6, 2020 at 9:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    GFC is going to make just a topper. That's pretty cool.
    With their soft shelf tent i bet that is probably the lightest most waterproof setup one could ask for.
    But honestly I think the topper is a cool idea. Price tag Im sure will be ludicrous though
  17. Nov 6, 2020 at 10:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The camper has the rtt built in. This is just. Topper with the fully opening sides.
    So you don't even need the rtt. Could just rock a gfc style topper.
    And water proof as in you could run a topper that has full access on the sides. But still run any rtt you want. Like say yours. Or mine.
    With their super light tent it's probably the most light weight combo, even lighter than their camper. Granted a lot smaller.
    And be like any topper water proof wise likely. .
    Still be just a cool topper. Hell be the only topper I'd want on my dd. Was gonna get a cover but that would be cool.
    Again though probably way too expensive
    Squeaky Penguin likes this.
  18. Nov 7, 2020 at 9:50 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The GFC is way more waterproof in general than my last canopy (not just from mud kicked up by the tires). The side access is also awesome, better than windoors can offer. If I were to just get a canopy for a truck, I would definitely look at a GFC canopy as an option.
    That said, I don’t really get the point of having a GFC canopy plus the ultralight RTT. It can’t be that much lighter than a regular GFC, and you lose the benefit of having the removable floor panels and full standing room. I guess if you’re switching the tent between truck and SUV or something.
    m3bassman and Squeaky Penguin like this.
  19. Nov 7, 2020 at 10:28 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I see the benefit for people who don't camp regularly and want to leave the rtt off most of the time.
    Price point will determine if it makes any sense over the regular GFC.
    m3bassman likes this.
  20. Nov 9, 2020 at 8:23 AM
    Speedytech7
    I did a thing, purchased two frame caps and some eastwood internal frame coating, can you guess what I'm battling? lol
