Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 10, 2020 at 12:02 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I have 265k on the duramx and have ran duratracs for every set. Usually get about 60-65k on a set. I got talked into a set of the Maxx and regretted them. Terrible on snow/ice and sucked in mud. Never going that route again.
  2. Nov 10, 2020 at 12:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    much harder compound.
    Id just stick with the duratracs then. Running an MT you'll risk not having a good time on the snow. The duractracs are the best "hybrid" AT for snow duties.
    Otherwise the M/S tire is made for mud and snow. I've not had any issues with them.
  3. Nov 10, 2020 at 12:07 AM
    FreidTaco
    FreidTaco boost
    jeff
    I have a wholesale account through simple tire....Tax free and better pricing, too many damn choices. May just end up with the trusty duratracs again.
  4. Nov 10, 2020 at 12:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    snow is the tricky part.
    Granted depending on what kind of snow you're dealing with the most could sway you to try a cheaper MT. but only if its deep stuff and stays malleable. If it feezes and melts constantly then you're fucked on an MT.
  5. Nov 10, 2020 at 3:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    can't really think of any MT that is "good" in snow for the most part. Other than real deep shit where they do shine. But still. Would not pick on 99% of time.
  6. Nov 10, 2020 at 3:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I was wondering how they would do. Not all that surprised really. I suspect my bighorns will be similar.
  7. Nov 10, 2020 at 3:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't see how that keeps you out of the ditch. Form is useless without some function.
  8. Nov 10, 2020 at 5:12 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Duratracs, they get louder as they age, other than that I’ve found no downsides.
    PcBuilder14 likes this.
  9. Nov 10, 2020 at 5:35 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I think every MT sucks in packed snow and ice. My KM2s were especially bad, the Hankooks being slightly better. Would be curious to get a set siped, but I would never run them on a vehicle I regularly need to use in winter conditions, so I'll probably never try it.
    I've talked shit about Duratracs for a while as I've seen like 3 of them blow sidewalls.
    That being said - I'm planning on getting a set for the 2nd gen next year as I want a load range C AT I'm comfortable running in the winter, and that's about the only option.
    Pltmnky[QUOTED] likes this.
  10. Nov 10, 2020 at 5:35 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Hey from Maryland.
    m3bassman likes this.
  11. Nov 10, 2020 at 5:55 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    KM2’s on my 1st gen in Missouri Winters were horrible. I couldn’t imagine being somewhere like Colorado or Wyoming with them!
  12. Nov 10, 2020 at 5:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mtrs are far worse hahaha
  13. Nov 10, 2020 at 6:14 PM
    PcBuilder14
    Brent
    Nor Cal
    I could imagine. I just live somewhere so I don’t live in snow. Then I don’t have to worry about it :p
    Speaking of MTRs, I wonder if they plan to make an updated version anytime soon. I feel like they’ve been around for quite a bit.
  14. Nov 10, 2020 at 6:15 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Late, but oh well.
    Never had any problem with Dick Cepek Extreme Country’s. I’ve had 2 sets on my hunting truck and it literally only left my driveway when the weather was straight shit on the mountain.
    Fairly cheap too.
  15. Nov 10, 2020 at 6:44 PM
    PcBuilder14
    Brent
    Nor Cal
    Well I was also a young adult who drove like a teenager thinking it was fun to spin out around corners, so my experience might have been a bit skewed. I’ll have to go and test out my KM3’s in the snow when we finally get some in the mountains.
  16. Nov 10, 2020 at 7:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you're talking KO2s he's talkign KM2s.
    I can attest the KM2s are not good either in snow.
    I grew up never putting snow tires on as well. But now, no way. They are amazing. I love them. But I probably have to drive in the worst conditions more constantly than anyone else in here(thats really active I should say)
    PcBuilder14 and JKO1998 like this.
  17. Nov 10, 2020 at 7:30 PM
    Squeaky Penguin
    Brett
    Planning on sticking with 265/75s on the new truck. Almost all LT tires in that size, including KO2s, are load range E, and I want to avoid that.
    Depends on how much snow you drive in, but the roads are snowy here a lot of the winter. My WRX with snow tires was incredible in the snow, Volvo was pretty close to. Nice to have the added safety and confidence in your setup when you're driving on snow regularly.
    We'll see how the 2nd gen with the Falken ATs does. I actually really like those tires so far, just with they weren't P rated.
  18. Nov 10, 2020 at 7:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The biggest difference for me stopping. You can REALLY stop. And if you loose it you can always regain control. Can't do that in other tires. Can I can drive almost normal speeds in winter instead of 35-45 everywhere.
    What wheel size? You stuck on a 16 or do you have 17s? Some good options in C load in 17s.
  19. Nov 10, 2020 at 7:38 PM
    Squeaky Penguin
    Brett
    Stopping for sure is one of the biggest differences, but it's just about loosing traction in general. Nice to be able to go around a corner at a decent speed and not worry about going off the road.
    I like the TRD Fakelocks that are on it, which are 16s, but I might consider swapping the Stealth 6s from the 1st gen on. Will be getting actual beadlocks for that thing whenever I get around to that build.
  20. Nov 10, 2020 at 7:52 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    The set on the 4Runner has 30k on them and I’ve had no problem ice-skating the ten or so times over togowotee this year. Can’t really comment on the sidewalls, SXS sees all the shit these days.
