Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 10, 2020 at 8:18 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    KO2's have to be the ugliest tire ever made. I have always had an irrational hatred for them.
    If anyone needs tires for cheaper than simpletire and you arent in a hurry, I can hook you up. Wholesale price is usually 2%-20% off reg price.
    Blackdawg[OP] and turbodb like this.
  2. Nov 10, 2020 at 9:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    might be worth looking at just cause there is a lot more options on 17s these days.
  3. Nov 10, 2020 at 10:03 PM
    FreidTaco
    FreidTaco boost
    jeff
    I just found the Nankang MT-1... Doesnt look terrible.
  4. Nov 10, 2020 at 10:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not bad for a MT
  5. Nov 10, 2020 at 10:18 PM
    FreidTaco
    FreidTaco boost
    jeff
    Price is right too...
  6. Nov 10, 2020 at 10:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow nice.
  7. Nov 12, 2020 at 3:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  8. Nov 12, 2020 at 3:56 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yes, they are clearly having issues right now; I can't sign in to the site either (I thought maybe signing in would give a different experience).
    Also, just FYI, you want Package #2, not Package #1; there isn't quite enough BXT in package 1 for an extended cab.
    Digiratus[QUOTED] and jubei like this.
  9. Nov 12, 2020 at 4:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ok, thought I was going crazy.
    Package 2 is a 50% increase in both BXT and Ensolite. Were you short that much on both?
    I was thinking package 1 because I was under the impression that it contained enough. I was going by a discussion I read between Monte and Jordan. @Blackdawg @Madjik_Man
  10. Nov 12, 2020 at 4:14 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I think I used Package #2 as well, but it was enough for 100% coverage on the floor, doors, extracab portion, and the rear wall. I had a little left over, but I also didn't do the roof. So you could probably get 90%+ coverage on everything if you included the roof.
    According to the installation write up on the Raam Audio website, it's not really necessary for that kind of coverage. I went the "more is better" route.
    turbodb and Digiratus like this.
  11. Nov 12, 2020 at 4:30 PM
    Madjik_Man
    Colorado Front Range
    I can’t remember what package I bought but I bought one pack of BXT II, 20 sheets, 37.5 sq ft and 3 running yards of PS Ensolite, 42 sq ft.
    That was more than enough to do the rear wall, rear quarter panel, and two doors. Plus I have some Ensolite leftover.
    Edit: just saw their website. I ordered package #1
    Putting raammat and Ensolite on your floors yields very little returns. The yield you get from raammat is stiffening up otherwise very resonant panels. Our floors are already very stiff due to the bracing, seats bolted to it, etc.
    Best material for floor would be mass loaded vinyl to cut down on those types of frequencies.
    Digiratus[QUOTED] likes this.
  12. Nov 12, 2020 at 4:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I wasn't planning to do the roof. I primarily want to cover the doors and extra cab panels and see how much material is left after that. Might do some of the floor, especially the back seat floor area. I already have some mat (not raammat) on the back panel that I put there when I removed the rear seats and interior to make a little more room for the refrigerator.
    Thanks. This is what I remember reading. And what you described is the contents of what is listed for their package 1.
  13. Nov 12, 2020 at 4:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Doing the back wall and doors will make the largest difference. Then the area by the extended cab. Then the roof.
    And then if you're really up for it pulling the dash and everything and the fire wall.
    Then MLV for the floor.
    Digiratus likes this.
  14. Nov 12, 2020 at 5:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds like their package 1 should be enough for my needs. Now just gotta be patient until their website is back functioning correctly.
    turbodb likes this.
  15. Nov 12, 2020 at 5:46 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I could have used about 6-8 extra sheets to more fully cover the floor with BXT. Everything else was pretty well covered. Package 1 had plenty of foam.
    I covered the roof (though I have the sunroof), rear wall, quarter panels, doors...well, you can see it all in the write-up, hahahaha. Note that I essentially had 2 layers on the doors, as I was following their instructions on the web site, where they use the BXT as weather seal as well.
    Oh, and I should mention that I notice quite a bit of difference with the roof being done. Rain is much less audible, especially on the highway.
    :thumbsup:
  16. Nov 12, 2020 at 6:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The roof is tin foil and moves SO much. I'd do it for sure.
    I remember laughing my ass off in high school after putting my subs in and watching the roof just bounce like crazy. hahaha
  17. Nov 14, 2020 at 4:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Well it looks like I wont be using RAAMmat. Got an email from Rick McCallium saying he can no longer get it made and has none to sell.
  18. Nov 14, 2020 at 4:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am curious about the Ensolite you got from RAAMmat.
    Was it peel and stick?
    Did it come in a roll? How wide is the roll?
    How thick is it? 1/4". 1/8"?
    Thanks.
  19. Nov 14, 2020 at 4:37 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Did he go into detail as to why? Is it due to shipping issues with covid or are they just done doing business?
    I was considering doing this sometime soon and planned to go with Raammat as well.
  20. Nov 14, 2020 at 4:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am not sure of the exact reasons. I had written to him saying the website wasn't allowing me to place an order. Here is the response I got:
    Sorry buddy, bad news, 20+ years of helping my fellow enthusiasts has come to and end due to not being able to get more RAAMmat manufactured for me.
    Closing the site very soon.
    Sincerely,
    Rick
