Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 25, 2020 at 8:14 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    What are you gonna put it on? Time for a 1st gen double cab???
    To be honest, if I had the money to blow I'd probably push to a Vagabond. But there are many other things I'd rather buy first and am still happy with the GFC over an RTT for our camping situation with the kid.
    turbodb[QUOTED] likes this.
  2. Nov 25, 2020 at 9:08 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    At least being there alone gives you a less chance of getting sick, unless you are asymptomatic and are the one passing it to others. Have you or Kirsten been tested or done an antibody test?
  3. Nov 25, 2020 at 10:25 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, pretty much my plan as well. Although, since I don't have a partner, an antibody test would be interesting to have results for.
    In your situation, unless both of you are asymptomatic, you are probably clear.
  4. Nov 25, 2020 at 11:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    bummer. I'm lucky to see 3 people a day. And Devin is one of them haha
    m3bassman likes this.
  5. Nov 25, 2020 at 12:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That is a big unknown but I suspect it is much higher than we guess.
    Thanksgiving get togethers are an example. :facepalm:
  6. Nov 25, 2020 at 1:23 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i think my room mate and I were the last straw in basically shutting our building down again haha
    I for sure had it like 3 weeks ago, and probably gave it to my room mate/coworker who got a positive test result (that was taken 12 days ago). though his quarantine is over, and mines been close to 3 weeks since symptoms so im long done too
  7. Nov 25, 2020 at 1:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    IMO, unless you are gong to do this outdoors (seems unlikely considering the time of year)this is still very risky behavior.
    My siblings and I (and their partners) were strongly wanting to all gather. We had considered options of getting tested beforehand and then quarantining until the planned gathering. But in the end, we all decided that it just was not worth risking one or all of our health over. I would feel horrible if one of us came down ill because of it.
    It was a very tough decision to make because it is by far our most favorite event, but in the end we decided not to do it. And there will be plenty of future opportunities to do this.
    I can understand though for your situation, it is very challenging to say no to the parental units, a factor we don't have to consider.
    turbodb likes this.
  8. Nov 25, 2020 at 1:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My parents both had
    You have bad symptoms? You'll be like the 12th or more "close" person I know that has had it.
  9. Nov 25, 2020 at 1:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Your parents got sick after the CO trip?
  10. Nov 25, 2020 at 1:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    most of my friends just had a sore throat or lost taste and smell for a bit. I guess i have inferior genes, felt like a sinus infection/sore throat for a week, and lost taste/smell for a week or so. Mine seemed to linger longer than many other friends.
  11. Nov 25, 2020 at 2:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Mark, what were the dates you were sick?
  12. Nov 25, 2020 at 2:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    2nd week of november
  13. Nov 25, 2020 at 2:14 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    our whole town, under 35yo is just going for heard immunity at this point
    BossFoss and Squeaky Penguin like this.
  14. Nov 25, 2020 at 2:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So you were sick roughly 11/8 thru 11/14?
    I heard the immunity wears off...
  15. Nov 25, 2020 at 2:25 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what are you the health department?
    is that a pun
    jubei and Squeaky Penguin like this.
  16. Nov 25, 2020 at 2:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well after the trip yes. Last week of Oct I'd say?
    Yeah mom and dad were laid up in bed for about 3 days. Lose of tastes is odd.
    Wait you have 2 people die from it at work but you don't count those as people you know that are close to you? How's that work?
    I have friends in Billings that have had it. Los angles, Cody, Powell, Denver, Fort Collins...
    IDtrucks[QUOTED] likes this.
  17. Nov 25, 2020 at 2:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I was still out skiing and biking (alone, away from people of course) and was ok, just sucked more wind with a sore throat
  18. Nov 25, 2020 at 3:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It was a play on words, but is true, what I heard. Just as you heard that herd immunity is a (good) thing. :rolleyes:
    I was curious on timing. Since we don't really know the incubation periods, there is no way to know when you acquired it. Afterall, it now appears as though at least three of the people with us on our adventure have since gotten sick with the virus.
  19. Nov 25, 2020 at 3:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So roughly 10/25 to 10/31? But not you or Devin eh?
  20. Nov 25, 2020 at 3:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    im pretty sure i got it from a massive holloween house party, symptoms started torward the end of the 1st week in nov, then persisted through the second week
