Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 27, 2020 at 11:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oooo nice!
    Cool. What are you going to use those for? What model?
    I'm doing the 4000k mod as well for the c2s I just bought for my ditch lights.
    Very nice. Excited to see how that build works out.
    For the swap? You moving the dealers to the double cab? That thing running yet?
    Ha! Well hope it works out man.
  2. Nov 27, 2020 at 11:19 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Lol, not quite. Working on it again though, now that I have some free time. Yeah swapping the deavers over. Headed to ace shortly to find fittings for the fuel filter housing inlet/outlet hoses so I can try and fire it again without losing prime :fingerscrossed:
  3. Nov 27, 2020 at 11:24 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Same here.
    They are Selective Yellow SS3 Pros. Going to pair them with clear SAE/Driving lenses. I will primarily use them on the highway to supplement the high beams. Will be mounted on the bumper where the light bar is right now.
    turbodb likes this.
  4. Nov 27, 2020 at 11:36 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  5. Nov 27, 2020 at 12:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice man. I'm ready to see that thing in action. Get it ready for spring!
    Ah cool. Do you find your high beams lacking? Kind of surprised by that..
    Actually no..my daily driver :anonymous:
    Time is precious now and it'll just be super easy to hook up the things I want to. Plus I like the trigger functions so I can set certain things to be trigger by the high beams and turn that function on and off.
    And they strobe/flash which I have a use for.
    So fuck it.
    I have a bussman in Igor so didn't need a new setup there really.
  6. Nov 27, 2020 at 12:34 PM
    PcBuilder14
    Brent
    Nor Cal
    No judgement here haha
    Didn’t know you had any accessories on the single cab.
    The 12v activation from an outside source and strobe features are pretty nice. Does the switch pro have the ability to dim as well?
  7. Nov 27, 2020 at 12:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm not totally sure on dim. Will have to check.
    I'm adding fog lights and ditch lights right now.
    Working on a rear light for inclement weather to flash.
    And adding heated wipers.
    Then I'm going to switch to halogen head lights I think and depending on how that goes I'll add driving lights as well.
    From there no additional plans. But who knows.
    I looked at the spot too but there were some features that I likes on the sp9100 vs the spot and the price difference was small. I like that it's sealed for one. Spod is not. And it's way smaller.
  8. Nov 27, 2020 at 12:56 PM
    PcBuilder14
    Brent
    Nor Cal
    Dang, turning that thing into an emergency vehicle. I didn't even know heated wipers were a thing.
    What other features did you like about the Switch-Pro over the Spod? I'm not completely sold on either one yet, so I'm willing to go with either.
    I don't know if it's due to user error in wiring accessories or not, but there have been failures of switch-pros due to supposed water intrusion and shorting out. The Spod has a waterproof gasket on the cover as well, but the lugs that the wires hook up to obviously have to be exposed somewhat vs. a waterproof harness plug like the Swith-Pro. But I do prefer having a crimped accessory wire that bolts to the Spod over wiring in the accessory to the Switch-Pro harness. Obviously just personal preference.
    I'd also argue that size difference is negligible. Swith-Pro is 6”L x 3”W x .5”H (excluding connectors). Spod is 5.38"L x 5.38"W x 1.48"H.
  9. Nov 27, 2020 at 12:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The low beams on my headlights are pretty good for what they are. However, their high beam is simply the removal of the cutoff. It could be the way the projector was set up in the housing, but I don't get much 'down range light' out of them. I am talking about light cast at 500-1000'. Plus, at 4500K, what long range light there is, is kind of thin.
    It is my hope that the 4000K Pros will fill that in some. :fingerscrossed:
    What did the SP9100 set you back. Did Colton offer you a good deal?
  10. Nov 27, 2020 at 1:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    When I'm back at a computer I'll have to look again. I also went spod but decided the SP was better.
    And yeah that was user error. People were mounting them with the ports facing up. You need to mount it perpendicular to that.
    And maybe but that's a nice size difference I think. Super thin.
    Ah gotcha. Well hopefully they do. I'd have gone for the max for that job haha
    And yes he did. Wasn't a huge break but still a bit. Best price I found anyways.
    PcBuilder14[QUOTED] likes this.
  11. Nov 27, 2020 at 1:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I hear what you are saying but the Max pods are only available with 6000K emitters. Didn't want that. The warmer emitters are way more interesting to me. We'll see how they turn out.
    jubei and Blackdawg[QUOTED][OP] like this.
  12. Nov 27, 2020 at 1:37 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Tryin my guy. Hoping to be able to make a maiden voyage with it come spring. Life keeps happening and its hard to find the time.
  13. Nov 27, 2020 at 2:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Be cool to see and compare to Dan's rigid pods though those might be like 3x3 pods or something.
    I can relate to that for sure. Haha so many plans..so little time.
    But I hope it works out.
    If you get it together is the Gfc going on it? Or keeping that on the 2nd gen?
  14. Nov 27, 2020 at 2:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If they turn out as strong as that, I'll be very pleased.
  15. Nov 27, 2020 at 2:44 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @drr I got the french-able mounts from RS, the design pretty much only lets you set them in the frame about 1", is that really enough to motivate you to do it twice? If they could mount further back on the frame you could potentially set them in flush, but if you did that how they are now, well you'd just bend the spring on the frame haha. I figure it doesn't hurt for me to do the work this time around, but I dunno seems like it wouldn't be an amount to be worth chasing twice for the extra work. Also got some spherical bushing hangers for the rear shackles. If you have that reference point on the frame, it would be cool to have a rough starting point.
    PcBuilder14 likes this.
  16. Nov 27, 2020 at 2:55 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    What is Selective Yellow? I'm wondering if I want to put something yellow in the bumper, or just get yellow covers for the Hella's...
  17. Nov 27, 2020 at 3:03 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah GFC on the 01 dblcab. You find a hacienda up there?
  18. Nov 27, 2020 at 3:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Selective yellow is the correct color for fogs. It is not amber.
    If you are looking for a fog light to mount in your bumper, I recommend the Diode Dynamics pods in either the Pro version or the Sport version. Monte and I were both running the Sport fogs on our last adventure.
    More technical info on what selective yellow actually is.
    https://en.wikipedia.org/wiki/Selective_yellow
  19. Nov 27, 2020 at 3:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
  20. Nov 27, 2020 at 3:14 PM
    Speedytech7
    That's pretty much what I put in my PIAA driving beams (that I aimed down to make fogs).
    Hella calls em Extreme Yellow, but they're distinctively not amber.
