Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 9, 2020 at 7:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's just a passive attenuation control.
    More importantly what is the crossover freq set at?
  2. Dec 9, 2020 at 7:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :notsure: Is that a parameter I set in the HU settings? High Pass filter?
    I asked about the passive crossover now because I don't want to have to pull off the door skin later to change it because of the added sound deadening.
  3. Dec 9, 2020 at 8:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Check the specs on the speakers. If there isn't a switch on the crossover for that itself then it's a fixed frequency
  4. Dec 9, 2020 at 8:32 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Just so you know, the coverage I did - some % on the outer panel, and full coverage of the inner panel, was just following the instructions from RAAMAudio. My reading of their instructions was that the RAAMMat doesn't mess with the sound as much as the ensolite does - that's why you only put a little bit of ensolite behind the speakers.
    But, I'm no Monte, so I'd follow whatever he says as far as audio goes.
    ...not that it probably matters that much in a 1st gen Taco, :rofl:.
    Digiratus[QUOTED] likes this.
  5. Dec 9, 2020 at 9:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I see their pics. So far the RAAMaudio website is still up.
  6. Dec 10, 2020 at 10:14 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The matt won't kill the sound. If anything it'll help. You won't be able to "over do" the matt really in a super negative way. You'll get diminishing returns at some point though and just be adding extra weight.
    The ensolite stuff you do want to be careful of as it actually absorbs sound. The Matt just helps stop resonance mainly.
    turbodb likes this.
  7. Dec 10, 2020 at 10:38 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I know it would not be a truly sealed box, but completely covering all of the openings with mat, especially the big, main one, seems like it might be too much. Aren't speakers designed (or not) for sealed enclosures?
  8. Dec 10, 2020 at 10:41 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Car speakers are designed for infinite baffle (free air) use
  9. Dec 10, 2020 at 12:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Some are yes but not all. And often performance is increased being in a sealed box.
  10. Dec 10, 2020 at 12:29 PM
    Speedytech7
    The really nice expensive ones are designed for a box, and they make it known with all sorts of stickers on the speakers themselves and pamphlets explaining the volume needed for said box. But your average ones are not and often will be reduced in output and frequency reproduction in a box.
  11. Dec 10, 2020 at 12:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't agree with that. But i supposed it will also depend on your subjective view on "better" when it comes to sound.
  12. Dec 10, 2020 at 12:53 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I feel like having almost any conversation about sound quality inside a 1st gen is meaningless. It takes relatively big jumps in quality to pick up any difference inside our cabs.
    gordi and m3bassman like this.
  13. Dec 10, 2020 at 12:55 PM
    Speedytech7
    Does yours sound that bad? Mine doesn't, and it's a pretty damn simple setup. Not as good as what I setup in the cruiser, but also 1/8 the price
  14. Dec 10, 2020 at 1:05 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    That’s exactly my point. A reasonably cheap set up can sound just fine, and the acoustics of a Tacoma cab are such that a better set up isn’t going to sound all that much better.
    No matter how much sound deadening you put in one of these things, there’s no getting over a) that it’s a car and b) that it is a 20-year-old car.
    And all we’re really talking about is a little more or less mat on an inner door skin. The floor, back wall, roof, glass are all going to make much more difference.
    m3bassman likes this.
  15. Dec 10, 2020 at 2:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh. It's all subjective anyways(as all things are). Im sure if you wanted to you could make it sound pretty damn good. Is it worth it? Idk. Maybe for someone.
  16. Dec 10, 2020 at 2:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would not call myself an audiophile, but I definitely appreciate a good sounding system.
  17. Dec 11, 2020 at 10:20 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    as long as it covers up all of the noises the truck makes, its a good sounding system
  18. Dec 11, 2020 at 10:49 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Naw, Monte is an audiophile, I am not. I just like the tunes to sound good.
    Edit: I like this definition:
    Audiophiles are an exceptional breed of people who are fascinated by pure audio, motivated by sound quality and addicted to audio gadgets. Audiophiles take their passion for music one step further. They're curious about how songs are recorded and the science behind how sounds are reproduced.
    m3bassman[QUOTED] likes this.
  19. Dec 11, 2020 at 10:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty good description of me actually. Now just add in engineer/producer who makes his own shit and we good haha.
    Speaking. Did my first commerical ad music mix this week. For a Christmas commercial for beard products no less hahahaha
  20. Dec 11, 2020 at 11:20 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya. quality is pretty low on the list of things i care about when listening to music. $20 skull candys are perfectly sufficient. could never ever tell if its "compressed".
    I do like me some old railroad ties though
