Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 29, 2021 at 8:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the merc is boosted?
  2. Apr 29, 2021 at 8:26 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    6.3 is na
  3. Apr 29, 2021 at 9:18 PM
    Speedytech7
    Nice, I think that's the Daimler unit, solid trans if I remember right, they handle aftermarket boosted versions of that 6.3 well into the 700whp range. My 135i has the 7spd dual wet clutch system that the M3s use (well up until this year haha, they killed it), shifts at max speed are 80ms, but like you said it's nice to sometimes flop it into normal drive mode and let it control (which is 150-250ms shifts depending). But since it's an auto, does yours come with adjustable launch control too?
    That 6.3 is a damn mechanical gem and I'll have a go at anyone who says otherwise. When you have some free time go find the Easter eggs, the AMG employee who built it will have their signature lasered in all over.
  4. Apr 30, 2021 at 6:36 AM
    トヨダ MASTER
    トヨダ MASTER Toyota Hoarder?
    Woods Landing, WY
    '18 T4R '07 FJC '84 PU w/LS '83 Hilux '94 PU '80 Hilux w/R2.8 C
    I have this
    and this lying around:
    The MX5 has a transponder issue that I can't seem to sort out but I haven't had time to really dig into it. But then I keep looking at this engine wondering if I should say "screw it, do it!" but then the time factor kicks in again. And do I really want that project or just fix the car and pedal it.
    At least you guys aren't playing with Bimmers. What pieces of shit those cars are to work on.
    m3bassman likes this.
  5. Apr 30, 2021 at 6:43 AM
    Speedytech7
    Do it, the LS miata swap is common place now, tons of info and resources for parts to do it quickly. And I am playing with a Bimmer, 135i is just an even smaller version of the 335i. All luxury cars are nightmares to work on these days, pick your poison.
  6. Apr 30, 2021 at 6:49 AM
    Speedytech7
    Yeah, I'm useless in 1st through 3rd if I hold the pedal to the floor, shit just keep spinning, I peak at 24psi on shift and the wheels just break loose. Traction control keeps it in check a bit too much so I've had the M3/M4 MDM traction mode coded in, I can have some wheel spin and moderate yaw movement before intervention. It helps but still lets me have fun. Launch control is great though on the dual clutch trans like mine, you set the RPM and it holds and makes boost then you let off the brake and it drops the clutches (or if you have it set it will slip and feather for maximum traction). How much life is left in your Pilot Sport 4s, they were 8k tires for me, trying some Potenza SA007 now after rave reviews from the friend with the M3.
  7. Apr 30, 2021 at 7:23 AM
    Speedytech7
    For sure, make sure to bring the garage up to moderately warm in the coldest winter months, anything below 25* ruins the Pilot sports, they flat spot and then crack. They uh, were the candle that burns twice as bright for me, they grip great but they're a short lived tire.
  8. Apr 30, 2021 at 1:34 PM
    トヨダ MASTER
    Woods Landing, WY
    Good point! Haha. I was researching this swap and was amazed how many companies make parts for the swap. Of course I wouldn't spend 13k on a 4k car so I'd have to get creative with my structural bracing and probably convert the rear to a Porche center section to hold the power. It would be a fun car in the end though. I did a BB Chevy swap into a '71 Vega when I was a kid so I imagine this would be similar in proportion.
  9. Apr 30, 2021 at 1:38 PM
    トヨダ MASTER
    Woods Landing, WY
    I rag on my old tech who opened his own shop. Every time I go in there, he's balls deep into a top end trying to find problems, plus he and his wife and kid have 3 of them and he's always having to tinker with the two older ones. Hers is two years old and been in and out of the stealership for TSBs and recalls. But I guess that's most new cars these days.
  10. Apr 30, 2021 at 3:36 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  11. May 1, 2021 at 10:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. May 1, 2021 at 11:38 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah they do fun stuff, the power wheels overlanding is pretty funny
    Blackdawg[QUOTED][OP] likes this.
  13. May 2, 2021 at 7:29 AM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    Hello again. I finally got mostly moved into my house in Worland. That was kind of a ride.
    The gig here is pretty sweet. We flew over devil’s tower and Mount Rushmore in one flight the other day.
  14. May 3, 2021 at 3:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    turbodb, Kheiron, jubei and 1 other person like this.
  15. May 4, 2021 at 5:20 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    It’s about 40A :p
    It’s a maxi blade fuse L size
  16. May 4, 2021 at 9:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You were kind of asking for it with the way you phrased it :laugh:
    トヨダ MASTER and turbodb like this.
  17. May 4, 2021 at 9:19 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Too bad you aren't closer. I have two of those that I'm never going to use and considered tossing. Should probably throw them in the OSK in case I'm ever on the trail with you and you need one.
  18. May 4, 2021 at 9:32 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    You're running an ARB compressor, right? While I think it's unlikely that a 40A fuse is going to blow under a normal compressor load, it could potentially happen.
    Alternately, carry one in your OSK for me :p
  19. May 4, 2021 at 9:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I always have a couple of spare in my tool kit. My first dual compressor, since replaced by ARB, used to randomly blow the fuses.
  20. May 4, 2021 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    [​IMG]Epic Day Two-15.jpg by Monte Nickles Photos, on Flickr
    トヨダ MASTER likes this.
