Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 4, 2021 at 10:09 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  2. May 4, 2021 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow, that brings back some memories.
    So does this...:luvya:
  3. May 4, 2021 at 10:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ha! It had actually blown all the spares I had. Can't remember now how many, but it was several on that trip.
  4. May 4, 2021 at 10:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i don't think he had any. Was the first trip ever I think with it and didn't really know wth happened. not till later did he try other fuse I think?
    haha good times.
    Was a slow fill up with that thing.
  5. May 4, 2021 at 10:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, there fast till they run out. :laughing:
  6. May 4, 2021 at 10:31 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I cut mine out of the ARB harness, as the ARB goes through the relay on the Bussmann, and that uses the mini-blade fuses, so I have tons of those (though I've yet to blow one for the compressor). But I'll start carrying them for everyone else, hahahaha.
    Except Monte and his damn CO2. :luvya:
  7. May 4, 2021 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yall are jealous of the CO2 life haha
  8. May 5, 2021 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Man it's sad RAAM audio is gone. Freaking Second Skin is like $800 bucks wtf..
  9. May 5, 2021 at 7:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
  10. May 5, 2021 at 7:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You mean the high beams don't work?
    Then the protector shield is stuck or broke.
    Hm cool will check it out.
  11. May 5, 2021 at 7:49 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Plenty of options for butyl and closed cell foam. Never saw the RAAM stuff but assume it's very similar. I've used the Noico stuff on both my trucks with good success.
    I did spring for the Second Skin MLV with built it foam just for the floor of the 2nd stuff. That stuff is thick and hard to work with, but I have like no noise through the floor. Now if I could figure out how to quiet down the back window.
  12. May 5, 2021 at 7:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well the light is on in the photo so low beam should be working.
    Only way to check the projector is to take the head light apart.
    I like the look of the mlv with foam. It's just pricey as hell.
    Same issue for me. I'm going to do the single cab first. But the back window will be loud as hell regardless.
  13. May 5, 2021 at 7:59 PM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Moving this here for any Laramie or Woods Landing folk that could help some good guys out.
    TMFF[QUOTED] likes this.
  14. May 5, 2021 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn I'd go help Tim out in a heart beat if I was a bit closer.
    TMFF likes this.
  15. May 5, 2021 at 8:04 PM
    Squeaky Penguin
    Brett
    Yeah, I think I spent $250 just to do the floor. It's also so heavy and hard to work with I don't think you would want to use it anywhere other than the floor.
    I assume the pass is still closed though?
    I take it there's no Saratoga members? :rofl:
  16. May 5, 2021 at 8:04 PM
    alee891
    Austin
    Black Hills
    Tacomaless
    I would as well if my wife wasn't minutes/hours away from us heading to the hospital to meet our little one.
  17. May 5, 2021 at 8:16 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ima pop in here for some more uncluttered opinion, srry.
    I got a quote of ≈600$ to rebuild some icons today.
    I almost shit, but it sounded like he knew what he was talking about so I left them there.
    what say you all
    I don’t wanna mess with it myself
    And yes
    allll of the preload
  18. May 5, 2021 at 8:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Seems reasonable to me I guess, he must've seen shafts that needed replacing. Should be about right is one or two shafts need replacing. I'm used to rebuilds being $150 per shock for 2.5s and $100 for 2.0
  19. May 5, 2021 at 8:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If it is to rebuild (new seals and oil only) for all 4 pieces, $600 is a little high but not unreasonable. I have paid $250 + shipping for a pair of COs with Tim @TMFF
  20. May 5, 2021 at 8:24 PM
    JKO1998
    Utah
    Shafts are fine.
    He did say something about the gas and oil being mixed, and that being an icon thing, adding more time/ labor.
    So you all would just go with it? I feel like I can trust the dude, seems to know his stuff, going off of what he’s got going on in his garage.
