Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 18, 2021 at 6:10 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    You have a link to the IG posts? Curious about more info. Would make a good ranch beat around truck for someone around here depending on just how much it would need, or possibly pull the parts and put on a cleaner truck to flip
  2. May 18, 2021 at 7:45 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Well we could start with this sort of fuckery...
    https://www.youtube.com/watch?v=Yl1FNX08HFc
  3. May 18, 2021 at 9:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    They sell mine trucks around here every now and then from the big platinum mine. Same sort of deal. I can't remember why but they have a good reason for only using diesel down there. They are always pretty trashed.
    Kheiron likes this.
  4. May 18, 2021 at 9:52 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You gotta get one of the office guy company trucks, that’s where it’s at.
  5. May 18, 2021 at 6:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    anyone ever deal with a dog that is terrified of thunder? Ollie is getting worse and worse.
    I just bought a "thunder jacket" to see if it would help. He's so bad now that if it just get cloudy basically and cools off or smells a bit like rain he freaks out.
  6. May 18, 2021 at 7:14 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    @Blackdawg I had a Thundershirt for a one of my dogs (actually my most favorite one) it worked well until the second summer when she figured out that that when 'her' shirt came out the thunder and lightening wasn't far behind. When she was older and her hearing had diminish to virtually being totally deaf she couldn't hear the thunder but sure saw the flash. Same reaction.
  7. May 18, 2021 at 7:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I usually don't do much make sure he's comfortable where ever he goes and half the time turn on tv with Looney toons or something to distract him. Usually helps.
    Interesting well good to know. Will see how it works out I guess
  8. May 18, 2021 at 8:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Long travel will help with that :boink: lol
  9. May 18, 2021 at 8:55 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Think vets have mild sedatives you can give a pet for calming them during thunder storms. Friends mom uses them on the 4th of July for the fireworks.
  10. May 18, 2021 at 8:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    true. Be quite the contrast. In the rocks though the fat tires are worth it.
    Yeah I've seen some of that. Just hesitant to use it as I'd have to a lot. We get a lot of thunderstorms here, the classic short burst ones and multiple ones a day can happen type things.
  11. May 18, 2021 at 9:03 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Ah, yeah prob not ideal for that
  12. May 18, 2021 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh yeah not good for a dd haha toy hell yes.
    Frank got away with blow 5100s because of the fat tire mod for a while hahaha
    yeah don't want a drugged dog all summer ha
  13. May 20, 2021 at 8:39 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    lol
    suggestion wheel. i like that
    m3bassman[QUOTED] likes this.
  14. May 20, 2021 at 7:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya see I keep a real loose grip on the wheel, because I figure it’ll wobble back and for enough the lefts and rights will even out and it’ll go straight
  15. May 26, 2021 at 4:20 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Welllll the MR2 has always had issues with idle. Idle is partially set based on coolant temps. MR2's are also often difficult to get bled, so any air in the system can mess up the idle. I knew i was losing coolant somewhere as idle would go from~1k to 2k to surging which is all signs of air in the system. But it was always dry under the car after parking it so figured it was a small leak.
    So went and picked up a fancy Radiator pressure tester hoping it was something simple. Got the system to 10 PSI and it was definitely a slow leak (like a psi a minute loss). And didnt see anything. Bumped it up to 15psi and it would instantly drop to the 10psi.
    I found the leak at least. Not 100% where exactly its leaking from but its running down the firewall under the carpet. So Im betting its the heater core. But spent time cleaning up the mess and left it to dry out and went and had beer with the wife leaving this for tomorrow (well today now)
    Could always be worse. When you dont see any drips or anything the mind starts going towards the parts you DONT want to deal with (block of head) and luckily the interior is simple to pull apart
    Kheiron and m3bassman like this.
  16. May 26, 2021 at 7:55 AM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    That does not look like fun.
  17. May 26, 2021 at 11:58 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Woooo TW dark theme in bound! Finally!
    Supposedly live this evening.
    jubei and PcBuilder14 like this.
  18. May 26, 2021 at 1:46 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Luckily not to bad. Everything is just held with screws pretty much
    Be interesting to try. I've never had issues with the current them though
    Kheiron[QUOTED] likes this.
  19. May 26, 2021 at 2:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I work on computer all day. Dark modes are the shit.
  20. May 26, 2021 at 3:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    And it's live!
    Bottom left corner, click Default Style and you can change it to Dark.
    BossFoss, PcBuilder14 and jubei like this.
