Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 26, 2021 at 4:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah couldn't do much. Couldn't really run the heater cause the poor dog was hot AF too. I did for a bit at one corner that I got out to help Brett get up. But Ollie was out of the truck then after that he didn't want to get out. It was just too hot in the sun.
    We both sat at 220-230 for most of the switchbacks and beyond a bit. Not much to be done about it but push on. Thankfully all was well.
    Did make me miss the manual but at the same time, it was steep in spots and the auto was a blessing.
    Yeah Idk if that would fit behind the grill not with out trimming. Not sure I would anyways. That's never happened anywhere else i've been.
    But fair enough haha I think I'd do it again. But not without a locker.
  2. Jul 26, 2021 at 4:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah he gets to ride in the cab. Also 10 years old going on 11. He does great but gets really hot. This year is odd I swear his winter coat didn't really come all the way out.
  3. Jul 26, 2021 at 5:53 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I remember you had to tighten your u bolts when we were at Crystal Mill in CO, I wonder if they were starting to walk around then. With 9/16” you should be able to take those up to 100 ft-lbs, especially with tall nuts.
    FWIW, 220-230 trans temp is not uncommon for me, especially going slow up steep grades. I’ve never had an issue with it, I just drain and fill once a year or so. You’d have to run at 240+ for a long time to start creating varnish deposits.
  4. Jul 26, 2021 at 6:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah it only hit 240 once. Stayed around 230 most the time once it got up there.
    Yeah exactly! They were basically new right before the trip. And I kept tightening them on this last one. Glad to have the bigger bolts now.
    Yeah the fluid is pretty new as of last year so Im not too worried. I'll do a drain and fill this winter.
    drr[QUOTED] likes this.
  5. Jul 27, 2021 at 10:39 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    How long until Monte's wheeling the red truck at this rate? :luvya:
    Also, where did he mention the fat ass 2nd gen on 265s cruised up the switchbacks with zero issue? :p I'd still say you should have one locker for that trail, and it is probably rougher than it was, but it's still not overly difficult from a technical wheeling perspective, just high consequence.
    m3bassman likes this.
  6. Jul 27, 2021 at 10:39 AM
    Squeaky Penguin
    Brett
  7. Jul 27, 2021 at 11:33 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    So where's the rest of the pics? :popcorn:
    And I do miss sawtooth lake. Would definitely like to revisit that place.
    edit: NVM, I just saw them in your road trip thread. Goose looked awesome.
  8. Jul 27, 2021 at 11:48 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Say it ain't so @Blackdawg. Can't be having a 2nd gen making us look bad! Lol
  9. Jul 27, 2021 at 11:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha no way man. No AC! No way.
    And true you had no issues. Need the locker more times than I thought. few real tight squeezes but did the job just fine!
    Is nuts I cruised up it though with no lockers two times before. I woudn't go back without one that's for sure.
    Well other than getting hot as fuck and then not cooling down as fast as mine it performed great. Probably some big ass dents in the skid, definitely a low handing truck and heard it get smacked around a few times :laugh:
  10. Jul 28, 2021 at 11:31 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Well, back from Idaho on an abbreviated trip. Just too damn smokey in the Sawtooths, and forecast is for more smoke and thunderstorms. I don't need to get asthma and a bolt of lightning to the face hiking up a 12K foot peak, so will conquer the rest on another trip.
    Ben - I also need to do Boulder Basin again, with you. I skipped the very, very, top (past the lake) so I could let you show it to me. :) That's quite the trail, esp. the section that is steep, loose rock, with ledges and the creek running down. Loved it. Can't wait for the top. :thumbsup: @m3bassman
    Sawtooths through smoke near ID-75.
    Digiratus and Squeaky Penguin like this.
  11. Jul 28, 2021 at 11:44 AM
    Squeaky Penguin
    Brett
    I'm so sick of smoke.
    I couldn't see the sawtooths when I went last year, so was hoping I could see them this year, but it's not looking good.
    Currently in Cody and went for a bike ride this morning, and it was almost unbearable. Probably not ideal to be breathing that hard with this much smoke, but oh well. :rofl:
    turbodb[QUOTED] likes this.
  12. Jul 28, 2021 at 11:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah this is by far the worst smokey summer I've ever experienced. Its really discouraging to go out and do stuff. I don't think we have seen blue sky for days now down here.
  13. Jul 28, 2021 at 11:55 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It cannot decide what it wants to do here. I've got red sun in the morning, clear blue sky in the mid day, rain and clouds and smoke again in the evening. Wind changing so much the smoke is unpredictable. Was super doom/gloom and smoke yesterday and fairly clear today
  14. Jul 28, 2021 at 2:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah thats what it usually does here. But for the last 3 weeks its just been socked in smoke.
  15. Aug 7, 2021 at 2:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was wondering what LR stood for...
    Is this an addon or a replacement?
  16. Aug 7, 2021 at 2:25 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I have never known someone with such an active auto-acquisition hobby as you sir. :hattip:
    At first I thought you were crazy. Now, I realize we are all crazy in our own ways, but you are definitely crazy. ;)
  17. Aug 7, 2021 at 2:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was going to say it looks comfortable. Street tires? Is it dog friendly?
    turbodb likes this.
  18. Aug 7, 2021 at 3:10 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I was thinking "Another one?, goodness he goes through alot of vehicles" and then I saw your post and was vindicated lol.
    turbodb[QUOTED] and m3bassman like this.
  19. Aug 7, 2021 at 3:48 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Jeep clubs?
  20. Aug 7, 2021 at 4:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    what the mpgs on it? The tent will surely impact that a tad. But im sure it cruises nice. be a good tour of the national parks rig.
