Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 31, 2021 at 12:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Damn smoke is back with vengeance. Crazy.
    Kheiron and m3bassman like this.
  2. Aug 31, 2021 at 2:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  3. Aug 31, 2021 at 3:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  4. Aug 31, 2021 at 3:38 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    what shocks are those? you look to be running a similar setup as me.
    10" stroke?
    Ya I messaged BTF about them when they first released them and they are factory geometry. No added castor. Don't see the point for that price.
    Although I do like how they have a chamfered front edge versus the flat face of the solo ones.
  5. Aug 31, 2021 at 3:57 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It gives the user another hashtag to use on social media posts.
  6. Aug 31, 2021 at 5:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no clue. haha just another option I guess. Probably a bit more clearance.
  7. Aug 31, 2021 at 6:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no idea. Doesn't seem any better than the Solos really. "worse" considering the features really.
    Just interesting I think. Used to be 0 options now there are 2.
    No just stock foxes 8'' in the stock locations. Nothing fancy.
  8. Aug 31, 2021 at 6:21 PM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    Out of nowhere too. Hopefully it gets so bad that vis drops below our minimums.
  9. Aug 31, 2021 at 7:18 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Digiratus[QUOTED] likes this.
  10. Aug 31, 2021 at 7:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What did you get? Some more of those fake 35s? Or the 37s you've been wanting.
  11. Aug 31, 2021 at 7:53 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Real 35's this time, and in C load range! Stuck with the MTRs, I wouldn't mind trying a different tire but I can't think of another brand/model that has the same capabilities and value that these have given me.
    Still want to test fit some 37's though...
    jubei and Digiratus[QUOTED] like this.
  12. Aug 31, 2021 at 8:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nice! 35x12.5r17s? Thats what I want haha but don't really want to tub right now or gears or...blah blah.
    Also I agree. Hard to beat them in the dirt.
    and wow 280? When I checked it was only 110..
  13. Aug 31, 2021 at 8:48 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah jumping up to 17's. Still got that 4.56 axle collecting dust in my garage...:boink:
    Yeah it was 110 instant rebate for a set of 4 (or more), they also had 10% off for veterans. Actually I think there is a $60 mail in rebate too.
  14. Aug 31, 2021 at 8:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's a pretty sweet deal. But at $370 each, you needed a sweet deal.
  15. Aug 31, 2021 at 9:13 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    All about that cost/benefit - assuming I get about the same number of miles out of this set as my current set (55k!), that comes out to just over 3 cents per mile. Sounds like a sweet deal to me!
  16. Aug 31, 2021 at 9:16 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    where is this? AB? When are we going?
  17. Aug 31, 2021 at 9:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nice man.
    Well if i go to 35s I know I don't want 4.56s haha But if I did 34s I might. Does it have a locker in it still too? haha
    I don't think the MTRs qualified for the Mail in rebate. but still cool. Im still toying with the idea of doing the 275/85s
  18. Aug 31, 2021 at 9:31 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yep, got the ARB in it. I have the matching gears for the front diff as well.
    The rebate is on the receipt, guess I'll see if it goes through.
    Blackdawg[QUOTED][OP] likes this.
  19. Aug 31, 2021 at 9:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think its right there on the AB/BC border, but I'm not sure. And turbo was talking about it for next month. It is possible to go to CA again if you meet their criteria. Personally, I think its too soon. Maybe next year if its still possible.
    The MTRs qualify for the $60 and the $110 rebate stuff
  20. Aug 31, 2021 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats damn tempting. Im tired of not having a locker..hmm
    yeah thats cool. Hm. 1200 bucks for the 34s...
