Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 28, 2021 at 10:15 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    https://frontrangeoffroadfab.com/proportioning-valve-kit/
    Digiratus[QUOTED] likes this.
  2. Sep 28, 2021 at 10:16 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    For some reason, my LSVP has always seemed to be more effective than what most experience. I was a bit concerned this would happen when I removed the rod system. As I said, it is very balanced when she is at full weight.
    I've considered doing what you and Monte and @drr have done to get some adjustibility back. What manual valve did you use Dan?
  3. Sep 28, 2021 at 10:18 AM
    Digiratus
    Roaming the PNW
    The RedHead
  4. Sep 28, 2021 at 10:20 AM
    Speedytech7
    Yeah I think I bought the last one, but they're all the same, the only thing special is they sell theirs with the stub lines to convert SAE to Metric... Those can be made at any NAPA really
    jubei and Digiratus[QUOTED] like this.
  5. Sep 28, 2021 at 10:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah Willwood sells one that several have used in the past as well. Just the valve. You'll have to build you're own line adapter.
  6. Sep 28, 2021 at 11:49 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Don't zip the zip tie as tight. Or a piece of angle with two hole drilled to fit the lspv bolts and then one in the center on the opposite side of the angle. Grab 3 nuts and a bolt. Weld one nut to the bolt head and slide the lspv rod into it. Then put the bolt through the hole in the angle and tighten them down to the desired adjustment.
    jubei and Speedytech7 like this.
  7. Sep 28, 2021 at 12:24 PM
    Speedytech7
    There's some for sure, but there are lots of purpose built items that do their job poorly. Doesn't help that this one is bulky and leak prone. Unfortunately it's in my way now so it had to go, only once it was gone did I realize how bad it was at its job. Notice they don't use them anymore.
  8. Sep 28, 2021 at 1:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I used the front range one as well, but it’s just a Wilwood valve and they make little adapter lines to convert from SAE to metric fittings. No real need for those, I have all the flaring tools needed to make custom brake lines with an SAE fitting on one end and metric on the other.
  9. Sep 28, 2021 at 1:11 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    @turbodb I have my OEM axle just sitting here taking up space in my garage. It’s an 8.4, I can’t recall if you have an e-locker or ARB though.
    turbodb and jubei like this.
  10. Sep 28, 2021 at 1:12 PM
    Speedytech7
    His rear is 8" elocker :/
  11. Sep 28, 2021 at 1:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I lost suggested that.
    I mean...he could mod it to fit the elocker. It's not too hard.
  12. Sep 28, 2021 at 1:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks. I'll check this out as well take a closer look at what I have now to see if I can make it (somewhat) adjustable.
    Yours has an ARB in it doesn't it? Even better than the OEM e-locker.
    drr[QUOTED] likes this.
  13. Sep 28, 2021 at 2:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wrong gears though. Dan has 4.88s and...well Dans arb is 4.56
  14. Sep 28, 2021 at 2:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh, that's right. Yeah, that wont work.
  15. Sep 28, 2021 at 2:16 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    My guess is that with all the little bits I'd also need to buy (u-bolts, perches, shock mounts, etc.) and shipping, it'd be ~$1500-1700. The housing alone was $1150, which is a lot less than I was expecting for a fabbed housing.
    Yep, I'm not complaining at all about the fab work - it's all pretty easy since it's really just gluing bits together once they are appropriately aligned. I'd probably do all new brake lines, just to make everything cleaner, as you suggest. Interesting note about the LSVP (and the resulting discussion), thanks. I know that if I go full float (still waiting on the quote on that - likely about $3000 I bet), you get rid of it for sure.
    Thanks for the offer. I'll see what the wait time for this Diamond is... I mean, I suppose I could always install yours for a bit and only run in 2WD. Maybe better than not getting out on trips at all. Even if they would be a little more on the tame side.
    I'd just have to rebadge the tailgate to PRERUNNER. ;)
    RoaminRoman and drr[QUOTED] like this.
  16. Sep 28, 2021 at 2:21 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    did you blow your axle up or something
  17. Sep 28, 2021 at 2:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It is possible to fit an Elocker into an 8.4 housing. Just a little grinding and drilling. So could be an option, fast one anyways: http://www.4x4wire.com/toyota/tech/electric_locker/
  18. Sep 28, 2021 at 4:51 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah this is certainly an option. Dan you’d probably want to use your 3rd and axles anyway, since at least one of my axle shafts is bent and Monte wants to buy my ARB/4.56 setup :D
    FWIW, Diamond quoted me an FZJ80 axle with spindles and chromo shafts for 2150. That was in March, I’m sure it’s gone up considerably since then.
    jubei and Digiratus like this.
  19. Sep 28, 2021 at 5:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its true. I pretty much want it haha
    drr[QUOTED] and Digiratus like this.
  20. Sep 28, 2021 at 5:07 PM
    Speedytech7
    I mean if you dont....
    Digiratus likes this.
