Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 13, 2021 at 12:33 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Nice work! How soon after that did you order sliders? :rofl:
    Jensonbt[QUOTED] likes this.
  2. Oct 13, 2021 at 12:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Why bother now
  3. Oct 13, 2021 at 12:35 PM
    Squeaky Penguin
    Brett
    For the other 3/4 of the doors.
    Jensonbt likes this.
  4. Oct 13, 2021 at 12:36 PM
    Speedytech7
    Dukes of hazzard that thing and save the $400
  5. Oct 13, 2021 at 12:44 PM
    Jensonbt
    Jensonbt Well-Known Member
    Beckler
    Idaho
    2012 gray tacoma DCLB
    Just enough to look kinda cool.
    I’m guna try and get it pulled out so I can use 4/4 doors and then bedline the bottom of the doors. Then get some sliders. Until then it’s strictly a grocery getter, I learned my lesson.
  6. Oct 13, 2021 at 1:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No hopefully this week. I bolted it back together so I can take it to powell to pull the engine. So will see. That's good to hear though. I have no idea what to expect from them.
    But yes 33x10.5r17.
    Second set huh? So ATs and MTs? What would be the factor to decide when to use what? Winter? or trip based?
    And you got a new tent? What kind?
    ooooo painful man.
    :wave:
    You too!
  7. Oct 13, 2021 at 5:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am looking for a compromise tire, either an AT or RT. Trying to find a lighter tire that is either C or D. So far, the only possible downside to the Klever RT is they are E rated.
    The new tent is an Alpha II. Think iKamper Mini but without the iKamper premium price tag.
    turbodb and jubei like this.
  8. Oct 13, 2021 at 6:35 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Have you considered the ST/Maxx? My current set have 50K on them, with life left (I had a bad alignment for the first set). I have no traction complaints, and they are very well behaved on the highway. Quiet too (compared to Duratracs, and I'm sure compared to your Pros).
    Downside is that they are E, as per usual.
  9. Oct 13, 2021 at 6:36 PM
    Squeaky Penguin
    Brett
    The world is telling you to go with the Kenda's in 35x10.50 load range D. :D
    Probably the next set of tires for my 2nd gen.
  10. Oct 13, 2021 at 6:58 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    For being an E tire the Klever feel softer than the ST Maxx did. Could just be my imagination too.
    I should have done this, the cracks along my pinch weld are just yelling at me to tub.
  11. Oct 13, 2021 at 8:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So you mean just a new set not a second set? As in you wouldn't swap tires around?
    There are some C load 17s in 33/34s. I'll post some in a bit.
    Interesting. Why the change? Just cause? How's the setup time? Looks heavy maybe?
  12. Oct 13, 2021 at 9:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They are a possibility but they also are Es. And they are heavy.
    Zane has my old Pros, I am currently on Maxxis Bighorns, 255/85r16. They are losing their edge and are noisy on pavement.
    The new set will be a 2nd set. New wheels and tires.
    As I said, a lighter tire (50-55#) in C or D.
    It is a bit heavier per the scale but I did not 'feel it' on the trail or the highway. I suspect setup and tear down will get better. Not so much worried about that though.
  13. Oct 13, 2021 at 9:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
  14. Oct 13, 2021 at 9:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool.
    But still why the change? Seems like that money could have bought a whine machine for the red head maybe haha
  15. Oct 13, 2021 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I couldn't find it on their website.
  16. Oct 13, 2021 at 9:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I would say.
    Fuck yeah.
    So 35s next? MTRKs are C load in 35s? :D
  17. Oct 13, 2021 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    And to do it right, a supercharger is more like the cost of a GFC... but without the waiting
    m3bassman likes this.
  18. Oct 13, 2021 at 9:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, NO 35s!
  19. Oct 13, 2021 at 9:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh pff.
    I mean..RIGHT right with a full stand alone..then yeah maybe. But other wise not really.
  20. Oct 13, 2021 at 9:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes. With a Haltech setup.
