Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 28, 2021 at 6:34 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Some day I'll add a real sub. The speakers we have do well with lower frequency stuff (go to 35hz) but only having two 7" drivers for "bass" (and only being supplied 100w for the whole speaker) it doesn't compare to a real sub.
  2. Oct 28, 2021 at 6:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well you took the shoes off yourself! Wasn't to far off to get the diff.
    Either way stick a scope up it's butt and see what's going on.
    Yeah no even close haha I have just some old two way altec Lansing and a 8" powered sub. Works great for a simple home setup. When I have my own house I'll try to do an Atmos setup with Sonos speakers probably.
    Think mine have 5.5" drivers. Can't remember.
    Either way not as nice as being in the studio haha
    velillen[QUOTED] likes this.
  3. Oct 28, 2021 at 8:16 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The shitbox is shitty and I have not noticed any new issues yet...
  4. Oct 28, 2021 at 8:21 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    They were the T35350.
    No cutting needed but you would need to swap to 95-00 wheel bearings.
    jubei likes this.
  5. Oct 28, 2021 at 9:01 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I don't, but they're fairly inexpensive for what we'd need and it would be worthwhile to have one.
  6. Oct 28, 2021 at 9:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is very interesting. Yukon T35350 is made from 1541H alloy and has no Chromium in it.
    Nitro Gear has an axle part number of AXT35350 and it is made from 4140 which does have Chromium in it.
    https://www.nitro-gear.com/AXT35350-p/axt35350.htm
    Yukon T35350
    https://www.ebay.com/itm/264533389813
    https://www.amazon.com/Yukon-Gear-YA-T35350-Differential/dp/B00ERXYU6Q
    Chromoly
    Stock axle shafts are typically made from 1040 and 1541 steel and are perfectly adequate for stock applications. For performance axle shafts, we use 1541H steel, 4140 and 4340 Chromoly steel, which has been hardened to maximize the strength and ductility of the axle shafts.
    1541 is a plain high carbon steel similar to 1040 but with added manganese for better hardenability, but there is not enough alloying elements in it to be classified as an “alloy” steel. 1040 and 1541 are used by manufacturers as a cheap alternative in meeting requirements for stock axles; they heat treat 1040 and 1541 by induction hardening, which is a production form of case hardening. It is fast, cheap and works very well. 1541 is able to be hardened to a greater depth (better hardenability) than 1040/1050 and is therefore stronger.
    4140 and 4340 are true alloy steels. 4140 is alloyed with chromium, molybdenum and 4340 with chromium, molybdenum and nickel. 300M is also called 4340 modified, as it is basically 4340 with silicon added. The strength of steel is generally directly related to the hardness. The harder you can get the steel, the stronger it is (tensile strength), but you generally loose toughness. These alloys give the steel increased hardenability and reliable toughness at higher hardness/strength levels. They can be induction hardened but their purpose and advantage is that they can be thru hardened, due of their better hardenability. 4340 has better hardenability than 4140 so it can be heat treaded harder, and thus stronger, than 4140. The 4140 and 4340 material is available in commercial and aircraft quality. Aircraft quality is achieved by vacuum melting to minimize impurities and is a more costly endeavor. Most 4140 and 4340 axles are made of commercial quality steel.
    https://www.alloyusa.com/blog/
    betterbuckleup, drr and Blackdawg[OP] like this.
  7. Oct 28, 2021 at 9:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    get the nittos then!
  8. Oct 28, 2021 at 9:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
  9. Oct 29, 2021 at 4:36 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ive had this one (yellow not the "black" version but a yellow verison, same company and specs though) and it has worked just fine. Not the best image quality but enough to stick it somewhere and check for damage. I use mine with my tablet
    https://smile.amazon.com/DEPSTECH-W...rtphone/dp/B01MYTHWK4?pd_rd_i=B01MYTHWK4&th=1
    These days I would spend a bit more and get a 5MP over a 1080p one. Bit better image for not to much more money.
  10. Oct 29, 2021 at 2:38 PM
    Reh5108
    Idaho
    I think that is the same one I have and my complaint is that anywhere I want to put it is too close for it to focus on. Only time I can get a clear image of cylinder walls is when it's at the top of the hole. Try and get closer and it becomes way too blurry to make much out.
    Digiratus likes this.
  11. Oct 29, 2021 at 3:56 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Weird. I havent had any sort of issues like that. But being cheaply made video equipment Im sure theres a bit of hit-or-miss from unit to unit.
    Also to be fair I do have this specific one which might be slightly different than the all black model?
    https://smile.amazon.com/gp/product/B06XSDF8Y5?ie=UTF8
    Doesnt compare to the ones we had at work but not paying the price for one of those (think they were around 10k) but good enough for the couple times a year I use it.
    Reh5108[QUOTED] likes this.
  12. Oct 29, 2021 at 3:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was wondering about this. The camera portion looks like it is at least an 1" long and I can't tell how sharply the cable can be bent right after the camera section. Can it be bent 90°? In those tight spaces, did you try using that mirror thing that it comes with?
    I have looked at several models today trying to choose wisely. Having said that, I just bought one of these.
  13. Nov 1, 2021 at 10:39 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Dumb question, probably.
    I'm gathering bits and pieces so that when my new rear axle housing arrives, I'm as ready to go as I can be. Obviously I'll need new axle seals and o-rings, and I plan to make new hard brake lines (and possibly ditch the BPV). I also need some sort of gasket/seal for the joint between the third member and housing. What's the best thing to use there? Something in a tube? Some actual rubber or paper thing? The Right Stuff, stuff? 90 minute?
  14. Nov 1, 2021 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Toyota FPV is what is used. i think you can buy a high quality gasket that is resuable though but I can't remember who makes it..
    Digiratus and turbodb like this.
  15. Nov 1, 2021 at 10:47 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Permatex black RTV, way better than any paper gasket.
  16. Nov 2, 2021 at 10:09 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I have an extra tube of Toyota FPV (103) Black you can have if you want. Somehow I ended up with two of them.
    turbodb[QUOTED] likes this.
  17. Nov 9, 2021 at 12:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ooookay so Hopefully Igor is driveable by the end of the month. Might try to do something in Dec down south maybe. But only for a week. That sound interesting?
    RoaminRoman likes this.
  18. Nov 9, 2021 at 12:05 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    YES.
    When in Dec? I'm free the first half, but not the second. I can plan the route, obviously...if by south you mean DV area.
  19. Nov 9, 2021 at 3:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    first half. Second half is too close to christmas.
    Idk about DV, might be too far south? Was thinking maybe AZ.
  20. Nov 9, 2021 at 3:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Where in Az do you want to go? Mogollon Rim? Prescott, Sedona areas?
