Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 9, 2021 at 10:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    what year supra? Cause early ones..probably. Later ones...mmmmidk.
  2. Nov 9, 2021 at 10:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Whatever the mark IV was. I forget the year ranges. I just know they had an a340 if whoever bought it was dumb enough to buy it with an auto.
  3. Nov 9, 2021 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you don't mind if your parts come from Abu Dhabi, sometimes partsouq can be a good option. Always cheaper.
    Not a good option for this item though.
    https://partsouq.com/en/search/all?q=32101-35010
  4. Nov 9, 2021 at 10:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    93-98
    Yeah that would likely be the same then. Maybe look at it...
    worried about shipping times for that though. Want this stuff by next weekend.
  5. Nov 9, 2021 at 10:29 PM
    Speedytech7
    I wouldn't worry about shipping times from partsouq, those dudes are freaking fast man
  6. Nov 9, 2021 at 10:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, you are pushing the limits on that. Using the cheap shipping options, especially if your parts are coming from the east coast, deliveries can be sketchy these days.
  7. Nov 9, 2021 at 10:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The flex plates are out of stock there anyways. So doesn't matter.
  8. Nov 9, 2021 at 10:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah looking at just around 900 for stuff for Igor and clutch stuff for lil red.
    sheesh.
    Oh well. gotta do it.
  9. Nov 9, 2021 at 10:38 PM
    Speedytech7
    Is your flex plate broken Monte? Does it show signs of stress? If it doesn't it's probably fine to keep running it as long as your ring gear still has all the teeth. It could still fail but if it's not cracking around mounting holes it's probably okay for another round
  10. Nov 9, 2021 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I didn't look that close at it, but Id say probably is fine. Just figure it's out, might as well do it.
    Especially since pulling the auto sucked haha
  11. Nov 9, 2021 at 10:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is exactly why I replaced mine.
  12. Nov 9, 2021 at 10:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah way easier to pull the manual that's for sure. mostly because it has less connectors hahahaha
  13. Nov 18, 2021 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  14. Nov 18, 2021 at 9:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Nice to see that thing out there.
  15. Nov 21, 2021 at 2:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    30 days should just about be up. Been to quiet in here...
  16. Nov 21, 2021 at 3:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I'll be curious to see how much he comes back. It really peeved him that's for sure.
  17. Nov 21, 2021 at 4:13 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I probably wouldn't if I had your guys' numbers and could reach you other ways. Other than the meme thread and this thread I really don't use this site for anything
  18. Nov 21, 2021 at 7:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hey there automatic transmission Mount you gave me what was that for exactly? It doesn't fit the Tacoma at all The bottom bolts line up way differently. We tried hacking up the cross member to make it fit but it wouldn't fit. Just curious what the heck is it actually for?
    Also million-dollar idea time, why the heck has it somebody developed an automatic torque gun? Like I have this badass electric impact why can't I like tell it to torque my bolt to 50 ft pounds or whatever. Tool like that would be freaking awesome.
  19. Nov 21, 2021 at 7:36 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Well if the description was correct upon purchasing then it's from a 2000-01 Hilux surf.
    I would of thought somebody had invented that already, would be handy if it was accurate.
    RoaminRoman likes this.
  20. Nov 21, 2021 at 7:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Got you That's probably why then. They must be just ever so slightly different because the bottom bolts that attach it to the cross member are offset and the one on the Tacoma is dead center. Interesting I guess.
    You would think not that I've looked but somebody should freaking make that thing.
