Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 21, 2021 at 8:23 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Did I give you a new bracket at one point or are we talking about the Trans bracket on the actual transmission you picked up?
  2. Nov 21, 2021 at 8:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You gave me one of the transmission rubber mounts that bolts the transmission to the cross member. I can't remember when you gave it to me but you gave it to me because you ended up swapping the five-speed into the double cab.
  3. Nov 21, 2021 at 8:42 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah sorry I had forgot about that when answering the first time. I'm pretty sure I got that from partsouq for the DC, so should of been for an 01 Tacoma. Thing was for a 2wd Trans so maybe that's the issue
  4. Nov 21, 2021 at 9:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hm maybe that's it then. 2wd vs 4wd.
    Well cool. Haha well I'll pass it along to someone else that needs it. Didn't work for me.
    Speedytech7 likes this.
  5. Nov 21, 2021 at 9:52 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Pretty sure you can control the torque output of some Milwaukee tools that connect to an app.
  6. Nov 21, 2021 at 10:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That sounds cool. I'll have to look for that
  7. Nov 22, 2021 at 5:44 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    One key tools. But it's not perfect. Like you can't set it to 80ftlbs. More set it to a power level mode.
    To many factors to really have a gun that can do specific torques. Like socket sizes and types.
  8. Nov 22, 2021 at 7:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Seems like you could be able to put in the size socket, if you have any extensions or adaptors and what torque you want and get it within 5%.
    But maybe so
  9. Nov 22, 2021 at 8:36 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    It exists if you’re willing to pay the money. Hytorc normally deals in very high priced precision tools for industrial work.
    https://www.reasontekstore.com/products/lion-gun
  10. Nov 22, 2021 at 12:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    How did you guy torque the flex plate to TC bolts? My wrench doesn't fit. Did you use a 3/8" wrench?
  11. Nov 22, 2021 at 2:17 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I believe so. Other than having to work in that tight little spot through the inspection port, I don’t recall it being very difficult actually.
  12. Nov 22, 2021 at 2:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I do have a small, 3/8" torque wrench but I can't recall if it was used. I'm pretty sure it was Big Dan @drr who was under there. You're right tho, with the limitations of the inspection cover and the engine block in the way, there isn't much room to work with. It could very well have been the gootentite method.
    Dan do you recall?
  13. Nov 22, 2021 at 2:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You guys torqued those? I sent em with blue loctite and a calibrated hand
    BossFoss and Digiratus like this.
  14. Nov 22, 2021 at 2:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :cheers:
  15. Nov 22, 2021 at 2:21 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah almost positive we got a 3/8 torque wrench in there, I remember looking up the torque specs and everything like a real mechanic
  16. Nov 22, 2021 at 2:28 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Probably could figure it out. I don't think One Key is that fancy though. Been awhile since I used it but it was more just percentage and like lug nut modes.
    But really most people aren't doing stuff that needs absolute precision. Like lug nuts...spec might be 80ftlb but really 70-90ftlb is fine.
    I didn't know hytorc was making a gun now. It slow though at the 5rpm.
    But would be awesome for doing 20 bolt flanges and stuff where the nuts are already snugged up then you go back for final torque.
    One of the scarier things I've experienced was a hytorc exploding. A hydraulic one at something like 60k ftlbs.
    PcBuilder14[QUOTED] likes this.
  17. Nov 22, 2021 at 2:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I went and bought one it fit plus I had one back in Montana but it was a really cheap and crap one so now I have a decent Craftsman one so win I guess
    Yeah 1/2 won't fit too tall of sockets and long too.
    Lol I hope you're joking..
  18. Nov 22, 2021 at 3:08 PM
    Speedytech7
    Nope, they're not a super high torque fastener and there's a lot more of them on a Toyota than on most makes anyway so the load is shared even more
  19. Nov 22, 2021 at 6:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    @m3bassman
    Welcome back Ben. In is the place you are appreciated.
    Blackdawg[OP] and Speedytech7 like this.
  20. Nov 22, 2021 at 6:35 PM
    Speedytech7
    Ditto @m3bassman
