Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 24, 2021 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well drove it home which is just over 100 miles. I've driven on worse alignments. Steering wheel isn't perfectly straight but better than the shop that did it a month ago. Slight bit if bump steer in some conditions.
    I'll take it for now.
    Seems to run and drive good. Temps were all good.
    However I still can't just fill my fucking gas tank. Pissing me off. Not sure what to do now. New tank? Fill neck? Something else EVAP related?
  2. Nov 24, 2021 at 9:59 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I also seem to have a bit of bumpsteer with my alignment on my Solo LCA's.
    I wonder if it's just due to the fact of having a shit load of castor. I have 4.35 deg on mine rn.
  3. Nov 24, 2021 at 11:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Possible. Didn't have any with the previous couple of alignments. I have like 4.5 and 5.1 castor. Drove great. So not sure. I should have over 4 right now but didn't bother checking that in detail.
  4. Nov 24, 2021 at 11:15 AM
    betterbuckleup
    Ian
    Concord, CA
    Interesting. Can't imagine anything other than castor and camber affecting bump steer...
  5. Nov 24, 2021 at 11:21 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    toe being off will make the bump steer feel more dramatic
  6. Nov 24, 2021 at 11:28 AM
    betterbuckleup
    Ian
    Concord, CA
    I'll have to double check that.
    I was measuring off of the tire lugs. Shot for around 1 deg of toe in
  7. Nov 27, 2021 at 2:05 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I hope you all had a good Thanksgiving!
    Digiratus and Speedytech7 like this.
  8. Nov 27, 2021 at 2:06 PM
    Speedytech7
    You too my friend
    Digiratus likes this.
  9. Nov 27, 2021 at 2:12 PM
    m3bassman
    Green truck
    :cheers:
    Speedytech7[QUOTED] likes this.
  10. Nov 27, 2021 at 5:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You too! I did a crap load of wrenching. Still wrapping up a clutch job
  11. Nov 27, 2021 at 5:33 PM
    m3bassman
    Green truck
    Clutch is fun and easy!
  12. Nov 27, 2021 at 5:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not sure about easy..but you are much smaller than I was easy compared to pulling the auto tranny a couple weeks ago that's for sure. Haha
    While job had a few more steps for me. New engine mounts(franks old ones) and speedo cable. Rebuild the master cylinder and slave too. Stoked to have a working speedo again. And clutch for that matter. Can't wait to see how fast this lil truck is stock.
    Next will be tcase swap if I can find one and 5th gear swap when that happens.
  13. Nov 27, 2021 at 5:57 PM
    Speedytech7
    I like the idea of the 5th gear swap to make 5.29s highway-able
  14. Nov 27, 2021 at 6:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Exactly why I want to try it. For Frank. Should help a ton on that truck. But the little truck is so light and has the torque to do 70mph below 2500 so figure good place to try it.
  15. Nov 27, 2021 at 6:47 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    What is the 5th gear swap?
  16. Nov 27, 2021 at 6:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You swap out the 5gear for a taller gear. It's about 20% taller.
    Only works on the R150 though not the w59 as you take a 5gear from another R series transmission. I posted a write up to it a while ago from Pirate
    Reh5108[QUOTED] and Speedytech7 like this.
  17. Nov 27, 2021 at 7:16 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Just get 4.88s and a crawl box.
    Driving my 1st gen around with no weight, 34s, and 4.88s is fun. It's got plenty of power, pulling speed limit up the passes, etc.
    I think it will be just fine on 35s.
  18. Nov 27, 2021 at 7:18 PM
    Speedytech7
    This is probably true with a manual, with an auto it's still lethargic on 33s. Like living at 15k feet with a clogged air filter
  19. Nov 27, 2021 at 8:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That is brutal.
  20. Nov 27, 2021 at 8:26 PM
    Speedytech7
    Sorry, I know you've got plans to overcome the shortcomings though.
