Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 20, 2014 at 8:55 PM
    #4781
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Actually was real blowy here too..40 mph i guess..but damn that was intense rain.
    correct.
  2. Feb 20, 2014 at 10:42 PM
    #4782
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Was thinking of you guys when I saw this.
    http://cliffmass.blogspot.com/
  3. Feb 20, 2014 at 10:51 PM
    #4783
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good ole wyoming weather...
    although, after watching Chasing Ice..i am not that surprised. Weather is getting more crazy on a logarithmic scale lately..in a few years...shit is gonna hit the fan.
  4. Feb 21, 2014 at 9:41 AM
    #4784
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    i blame HAARP lol:tinfoilhat: seriously lots of odd shit going on with the weather. Shit is most certainly gonna hit the fan soon.
  5. Feb 21, 2014 at 9:42 AM
    #4785
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol
    nah its just global warming and climate change. Getting crazy.
  6. Feb 21, 2014 at 8:56 PM
    #4786
    Blackdawg
    Monte
    Wyoming/St. Louis
  7. Feb 21, 2014 at 8:59 PM
    #4787
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm assuming they are unplugged? Long as you routed the wire nicely it should be okay. But get a fuse ASAP.
  8. Feb 21, 2014 at 9:10 PM
    #4788
    Blackdawg
    Monte
    Wyoming/St. Louis
    Followed your cb cable??
    Damn..
    Could cause some interference. Maybe.
  9. Feb 21, 2014 at 9:17 PM
    #4789
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Good point. My 2 meter antenna runs along the same path as my amp power cables and when I transmit it makes my my subs hit with a not so nice bump.
    Hopefully you can get away with it on a cb with the lower power
  10. Feb 21, 2014 at 9:18 PM
    #4790
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it won't be much power so I don't think it'll be an issue.
  11. Feb 21, 2014 at 9:26 PM
    #4791
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right. Should be okay. I just wouldn't make it a habit of running more wires there.
    Is your cb power and ground on the main wire for the sub amp?
  12. Feb 21, 2014 at 9:40 PM
    #4792
    Blackdawg
    Monte
    Wyoming/St. Louis
    Route the ground straight the the battery.
  13. Feb 21, 2014 at 9:46 PM
    #4793
    Blackdawg
    Monte
    Wyoming/St. Louis
    no just the CB. It'll clean up the interference and your broadcast signal.
  14. Feb 21, 2014 at 9:56 PM
    #4794
    Blackdawg
    Monte
    Wyoming/St. Louis
    i have one :cool: got it for xmas. Think its the same one you linked in here the one time. It's goning on my roof rack and will actually charge my starter battery to make sure its allways charged and i can start the truck.
    second battery just charges off alternator. Might put a second panel on it some day but..don't see the need as i have a big enough alternator to keep it good after a day of wheel and the alt will run everything i want by itself anyways if the second one dies.
    That's how id wire it, not to the second battery. You'll want a much bigger alternator if your gonna do dual batteries.
  15. Feb 21, 2014 at 10:05 PM
    #4795
    Blackdawg
    Monte
    Wyoming/St. Louis
    Duals are better as the second battery is totally isolated from the starter..so you can have all your accessoreis run all night off the second without having any affect what so ever on your starter one.
    For living out of the truck..your still gonna have to start it every day probably just to keep the batteries from totaly dying. Or your gonna one hell of a solar kit that'll be like 6-800 bucks to actually charge them fully and all.
    Mine is just a maintainer..and its big.
    But also depends on what your gonna be running..
  16. Feb 21, 2014 at 10:15 PM
    #4796
    Blackdawg
    Monte
    Wyoming/St. Louis
    that would be easy. Just route a small two pair of 16 or 18 ga wire to the tent and get a quick usb end and set it up in the tent. Done.
    IF your only gonna have the tent lights and maybe charge the phone..you don't need a solar kit or second battery..haha thats nothing..
    now if you had a fridge/freezer..maybe a coffee machine..played music for a while at night..that kinda stuff..then you might want that stuff...
    but for what you just said..your main battery is fine.
  17. Feb 21, 2014 at 10:23 PM
    #4797
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes..yes you are haha
    the only girl i have ever met that is okay even a little bit with that kinda stuff..is Jessica that gal i brought on first leg. But this would push it i bet..haha
    yea water will be tricky..might just have to get a tank wrapped in a blanket...then you would want a second battery..haha
    might look into like bed drawers perhaps??
  18. Feb 21, 2014 at 10:31 PM
    #4798
    Blackdawg
    Monte
    Wyoming/St. Louis
    When we got our first toyota, the good ole 86 blue one..it had some weird thing in the bed that was like multicomparment like out of plywood and shit..was even with the bed rails. We tore it out but i think i know what you mean.
    but not like you use it as a "truck" truck anyways very much..doubt that'll be an issue.
  19. Feb 21, 2014 at 10:37 PM
    #4799
    Digiratus
    Roaming the PNW
    The RedHead
    I don't understand the concern over where the tents power cables are run. It seems unlikely that the CB will be in use while the tents power is in use. The only time the CB's broadcast or receive ability might be interfered with is when power is being drawn by the tent accessories...
  20. Feb 22, 2014 at 6:59 AM
    #4800
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i know. But its a bad habit..haha
    :rofl:
    IM ON PINTREST!!! HAHAHAHAHAHAHA
    Edit: wow actually on there a lot...weird.
