Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 13, 2022 at 10:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's just not capable of drawing enough to be worth cramming a tight cable like that. it's fused at 120a total that won't exceed the capacity of a 12" length of quality 8ga cable, even if it was half corroded haha
  2. Jan 13, 2022 at 11:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I just like it all to be the same...OCD i guess.
    Speedytech7[QUOTED] likes this.
  3. Jan 13, 2022 at 11:14 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Works for me.
    Not about saving pennies per say, I just don't need excessively sized cables. I'm sure that the team of engineers that developed our trucks chose the size that they determined to meet the electrical needs of the system so I hesitate to get onboard calling the OEM wires "undersized". Looks like 4g it is.
  4. Jan 13, 2022 at 11:16 AM
    Speedytech7
    It was for toyota haha, the stock cabling is very small.
  5. Jan 13, 2022 at 11:24 AM
    m3bassman
    Green truck
    And it works. Not everything needs to be over-engineered. Regardless I am cool with the 4g so nbd.
  6. Jan 13, 2022 at 11:25 AM
    Speedytech7
    I'll order some cable and make em, you in a rush?
  7. Jan 13, 2022 at 11:28 AM
    m3bassman
    Green truck
    No I'm currently on the tarmac about to leave the country for a minute. So no rush whatsoever. I still need to get the rest of the parts for when I get in there.
  8. Jan 13, 2022 at 11:29 AM
    Speedytech7
    Okay cool, I'll make cables and they'll come with new battery terminals too. Plug n' play
    m3bassman[QUOTED] likes this.
  9. Jan 13, 2022 at 11:35 AM
    Speedytech7
    @Blackdawg Had to do a double take for a second on this one...
  10. Jan 13, 2022 at 11:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Jan 13, 2022 at 3:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Lets do this...
    Looks like we have probably already done some of it.
    BossFoss and jubei like this.
  12. Jan 13, 2022 at 4:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah guessing they do kind of a big S. Start in medicine bow(where we started CO in 2020) and then follow orgeon trail stuff to Landar. Looks like they headed at least towards Shoshone Lake(Reconigize the big Red butte) then take a semi back way to the Owl Creek Mountains then the Big Horns(Lots of footage from that in the trailer) then I bet they end it with Beartooth cause its a motorcyclists wet dream.
    though if they went east again towards Devils Tower that would be cooler I think. Then they could start the MT one in eastern MT and head to the NW corner and it would probably be the longest BDR route by far.
    But no one has to convince me to go to Wyo lol.
    Be cool to see what they did and how it can be built on.
    Digiratus[QUOTED] likes this.
  13. Jan 16, 2022 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oookay riddle me this zane.
    Took the rear driveshaft off and marked it up. Lifted one wheel and marked it. Spun it to count ratio an.it only too like 2 and some change to get one wheel rotation? Wtf? Haha
  14. Jan 16, 2022 at 4:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Multiply that by two. ;)
    Speedytech7 likes this.
  15. Jan 16, 2022 at 4:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really? Why? Shouldn't the ratio be the same? Or because the spiders are spinning it halves it?
  16. Jan 16, 2022 at 4:23 PM
    Speedytech7
    Only one wheel spinning halves it
  17. Jan 16, 2022 at 4:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    fair enough. Then I'd guess it was 4.10s then. I'll redo it later. but if so, why is my speedo like 10mph off?
  18. Jan 16, 2022 at 4:28 PM
    Speedytech7
    Toyota says this is normal
  19. Jan 16, 2022 at 4:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    10? I thought 5 was normal. I don't remember mine being that off in Frank on 31s. Igor sure as hell wasn't. And going off what Dan and Ben posted its not as off either.
  20. Jan 16, 2022 at 4:30 PM
    Speedytech7
    Legally you get +/- 10%, I think this qualifies
    BossFoss likes this.
