Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 16, 2022 at 4:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I guess I shoudl be more clear.
    The speedo is off. But i have to be running much higher rpms it seems to go the true speed. Does that make sense? Like almost 3k for 70mph true speed. Speedo reads like 79. Which is "accurate" for a true speed of 80 as Ben showed his at 3k reading 80 while drivng 80 with 32s.
    mine is 3k, reading 80mph, going 70mph. The speedo being off is one thing, but the increased rpms? Seems off, or a smaller gear ratio.
  2. Jan 16, 2022 at 4:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think I see what you mean but I can't think of any reason why that might be besides a bad cluster or speedo gear/cable
  3. Jan 16, 2022 at 4:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Rpms are electonic though so can't be the cable. That and it's brand new so would hope it's okay.
    Bad cluster, maybe? As in the tach is off? possible. Doesn't seem super likely to me, i mean im sure it's not super accurate. But should be getting it's info from the CPS Yes?
  4. Jan 16, 2022 at 4:43 PM
    Speedytech7
    Yeah, the tach signal produced by the ignitor (taken from cam and crank position) is what the cluster uses. Should be accurate but I've noticed my stock cluster in the LC reads 200-300rpm high compared to the digital readout from the ECU. That's a small discrepancy but I'd imagine some are worse and some are better.
  5. Jan 16, 2022 at 4:44 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Did you count the number of teeth on your speedo gear? Maybe it was modified in the past and returned to stock.
    Also if someone open r the dash to replace the cluster bulbs they may have removed the needles and that could add significant error if they didn't put them back right.
    Speedytech7 likes this.
  6. Jan 16, 2022 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah maybe so. I guess I'll grab an UG here soon.
    Definitely thought about that. Well, the moving of the need anyways. Did not check the speedo gear in the Tcase but I can.
  7. Jan 16, 2022 at 4:51 PM
    m3bassman
    Green truck
    Worst case you do the mental math and accept the error lol
  8. Jan 16, 2022 at 4:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can live with the speedo being off honestly. Hell I've been driving it with no speedo since I bought it so like 3 years. But the rpms and true speed thing is whats bugging me..
  9. Jan 16, 2022 at 5:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How do your RPMs compare between the dash gauge and the RPMs displayed by the scangauge?
  10. Jan 16, 2022 at 5:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wrong truck. No scan gauge in the little truck
  11. Jan 16, 2022 at 5:56 PM
    Speedytech7
    So put it in?
  12. Jan 16, 2022 at 6:11 PM
    m3bassman
    Green truck
    Gtfo. He would rather feel it out!
  13. Jan 16, 2022 at 6:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh I guess. Gonna.just get an ug for it
  14. Jan 16, 2022 at 6:36 PM
    Speedytech7
    Yeah that's the right call the scan gauge is outdated and overpriced garbage that has mislabeled codes and super slow refresh time anyway.
    jubei and Blackdawg[QUOTED][OP] like this.
  15. Jan 16, 2022 at 6:43 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Does it have an R150f in it? Or were the really early models a W56?
  16. Jan 16, 2022 at 6:44 PM
    Speedytech7
    Mine's an r150 so I don't see why his would still be a w56
  17. Jan 16, 2022 at 6:46 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    The little red truck is a 95.5, right? Thought they did some weird stuff in that first 6 months of production.
  18. Jan 16, 2022 at 7:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah r150
    Did weird shit all the time haha
    But don't think it's a w.
  19. Jan 16, 2022 at 7:52 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Could also spin it twice to get a more accurate guess.
    Sure you don't have 4.30s or 4.56s?
  20. Jan 16, 2022 at 7:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I'm not. Which I why I was doing that in the first place. But got dark and cold so will have to wait until later.
    Right now I think it does have 4.30. but I want proof of that.
