Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 2, 2022 at 6:41 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    A few weeks back, I believe @Digiratus posted the teaser video
    Digiratus likes this.
  2. Feb 2, 2022 at 7:15 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I must've missed it too :laugh: I only remember the overlander video
  3. Feb 2, 2022 at 10:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    BossFoss[QUOTED] likes this.
  4. Feb 3, 2022 at 7:33 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    I need new rear shocks and front upper control arms. Original rears were too long and sold the uppers with the extended cab last summer. It's been prob 8yrs since I bought the camburg uppers and fox rear shocks. Are there better options today for uppers or are they pretty much the same whatever I choose? I was thinking ADS for the rear shocks unless there are comparable for less money or better for the same cost.
  5. Feb 3, 2022 at 8:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think for less maintainance and just as good of performance the SPC Light racing Uppers are nice. They are adjustable too to dial in caster/camber. But its a sealed Ball joint that is pretty easy to swap out so they last longer.
    Rear shocks, I don't think you can beat ADS for top of line choice if you're wanting top of the line shocks.
    RoaminRoman likes this.
  6. Feb 3, 2022 at 8:42 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    I seen a pick searching for ucas of the spc ones. Was curious if they were good, I like the idea of going back to a sealed setup over the camburg.
  7. Feb 3, 2022 at 8:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I have em on Igor, Ben and Dan both run them too. No complaints.
  8. Feb 3, 2022 at 1:36 PM
    m3bassman
    Green truck
    Learned today my truck can only do 250 miles, but not a mile more :anonymous: also with the new O2 sensor, it's apparent that my lean issues were not true but false readings from the Bosch. Knocked out about 500 miles with 350 to go!
  9. Feb 3, 2022 at 3:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :laugh:
    You always gotta find the edge don't you? Be safe,have a great time.
    And only 850 eh? Would have been ~1200 for me.
  10. Feb 3, 2022 at 3:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    what do you mean? Your O2 was bad so your ecu was readign lean?
  11. Feb 3, 2022 at 4:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The O2 sensor he is referring to is the one connected to his wideband gauge.
  12. Feb 3, 2022 at 5:20 PM
    m3bassman
    Green truck
    Well I have made it there in one shot before but I suspect there was more of a head wind in the snow storm today than I realized.
  13. Feb 3, 2022 at 7:15 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I personally don't see a reason to go with anything other than SPC. They are plenty strong, have more than ample articulation, sealed joint, and make doing alignments super easy.
    Are you doing a relocate or just using the factory location for shocks?
  14. Feb 3, 2022 at 8:24 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Just factory for now, want to keep it simple. Truck is complicated enough ATM, just want to finish and drive it.
    Reh5108[QUOTED] likes this.
  15. Feb 3, 2022 at 8:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    slap some 5100s/5160s on it and call it day. Get some ADS when you get around to relocate them.
  16. Feb 4, 2022 at 3:06 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Are those 10"? I do have a lift on this currently.
  17. Feb 4, 2022 at 4:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You should be able to get 5160s in 10" or 5125s
  18. Feb 4, 2022 at 5:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you are going to use the OEM mounts, 10" shocks will be to long.
    Even with 2.5-3" of lift, mine could only handle a shock that was ~22" extended, 13.5" compressed.
  19. Feb 4, 2022 at 5:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've had 10'' 5150s on Frank for years. They are too long unless you have a lot of lift then its not too much of a concern. yeah you'll bottom em out at some point and ruin them. But if they are 5125s, who cares. They will last a couple years still. Especailly if he isn't you know, beating the crap out of it.
  20. Feb 4, 2022 at 6:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No Monte, that makes no sense if he is buying a new set. 10" travel 5125s are too long. Yes they will mount, but you'll end up very little up travel. An 8-8.5" travel version would be way better.
    I realize you said 5150s which are considered short bodies, but it looks like the same story with those.
    Squeaky Penguin, BossFoss and turbodb like this.
