Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 8, 2022 at 7:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It's getting harder and harder to find a new vehicle worth buying..
    Or maybe it's just easier to see why I should keep my old shit running.
    Grabbing a low mileage 2nd gen or something pre 2010-2015 makes more sense these days.
  2. Feb 8, 2022 at 8:11 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    According to my wife a new bronco is easy to buy :anonymous: the new tundra is incredible too.
    New vehicles are just getting harder to afford, not less cool or desirable.
  3. Feb 8, 2022 at 9:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    tell me about it. I got told we have to build a smaller house than we want because costs are so high right now. You'd think for near half a million dollars you'd be able to build a freaking mansion...nope.
    tundra is interesting to me. But yeah, so expensive. I don't think i'll ever buy anything brand new in my life at this rate haha
  4. Feb 8, 2022 at 9:32 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Low mileage vehicle, eh? I got you.
    https://sandiego.craigslist.org/csd/ctd/d/portland-2002-toyota-tundra-4x4-54k/7441477713.html
    But to put a different spin on the whole new vehicle subscription thing, while I hate it as well, it is what it is at this point. Heated/power seats, Apple CarPlay/Android Auto, most features inside the truck are yours to keep. If you want remote start, can always install an aftermarket unit, with the added benefit of the truck not shutting off when you open the door. “Free” nav also only runs 3 years, but that’s what Apple CarPlay/android auto are for. Plus the Toyota nav system is meh.
    I am more concerned about the nanny and emissions stuff over time. But with used prices as crazy as they are, you get a lot more truck/features by going new-ish.
  5. Feb 9, 2022 at 4:14 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Unfortunately even aftermarket remote starts won’t bypass the auto shutoff when you open the door. I also couldn’t care less about the navigation. My phone is always better. The RAV4 we bought used started at nearly $5k more than what it would cost if we would have just ordered a new one and waited 3-6 months. Thankfully they came way down on the price, but I almost laughed when they told me what they initially wanted for it. I truly hope most people aren’t paying those prices, but I know they’re out there…
  6. Feb 9, 2022 at 8:03 PM
    m3bassman
    Green truck
    @Digiratus I measured 23.75". Kinda hard with the big bulging tires.
    I'm having second thoughts though, should I just add keepers to my pack and run it? Is cracking the main leaf really a risk? The ride and flex is what I want, and changing it is worrisome.
  7. Feb 9, 2022 at 8:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean if nothing is wrong I'd send it.
    More likely to crack a shorter leaf than the main one. I wouldn't worry about it personally
  8. Feb 9, 2022 at 8:41 PM
    m3bassman
    Green truck
    The leafs keep shifting so I'm worried there's been loads concentrated on it unevenly for a while. I can weld on an old ubolt as keepers but I can't remember if that's gonna create a weak point in the leaf due to the heat.
  9. Feb 9, 2022 at 8:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah so if that's happening what you should be worried about is the center pin.
    Just like what happened to me this last summer if you recall.
    So I'd pull the leaf springs, replace the bushings(probably well over due for that anyways) and then replace the center pins. The bolts probably stretched and the more movement the worst it will get and you'll end up shearing it at some point.
    Then it'll be fine.
    Hell, I have another skyjacker leaf if you want to put a new leaf in. It's even the same leaf I put in yours originally.
  10. Feb 9, 2022 at 8:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I had 11s on for the longest time, it's doable haha
  11. Feb 9, 2022 at 8:49 PM
    m3bassman
    Green truck
    Center pin isn't a real concern. I rebuilt the pack and replaced a leaf (from a second gen) and new center pins last year, so maybe a few thousand miles on them. Granted they need pulled off the truck to straighten the leafs anyways so ya I'm sure lots of bushings are due at that point.
  12. Feb 9, 2022 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah well then you didn't torque em down enough if they are spinning. So maybe just tighten them up and you'll be good.
  13. Feb 9, 2022 at 9:03 PM
    m3bassman
    Green truck
    Monte, the clamping force of the center pin has little to do with negating the leafs from spinning. That's why leaf packs have keepers. It's a single point with long moment arms, you would strip the threads before you could clamp the springs enough with a single nut :laugh:.
  14. Feb 9, 2022 at 9:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks like the rear so I'm going to say that is a bit under 3" over stock. The OEM setup had about a 1/2" more in the rear than in the front. My truck, with 36K when I first got it was ~21" in the rear.
  15. Feb 9, 2022 at 9:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It helps. Certainly the simplest thing to do if you don't want to replace them. If they were new they have no doubt stretched. So they could use a re torque I'm sure.
    Frank doesn't have enclosed retainers and I don't think Igor does either.
  16. Feb 9, 2022 at 9:11 PM
    m3bassman
    Green truck
    Yeah rear, front is at least adjustable and about as low as the icons go.
    2.75" of lift seems like a lot as I've been trying to keep it low for a while. 21" is a good data point. I think I'll pull the tire and try to get center of the drum, might give more accurate reading. Thanks Mike.
  17. Feb 9, 2022 at 9:17 PM
    m3bassman
    Green truck
    At this point anything done to frank is irrelevant as it's non-op for the last 5 years, hate to say it.
    I'll probably look into dropping the axle this weekend or finish reinforcement of the driver's shock tower. Can't just tighten the center pin without going to that level of work sadly. I just get uncomfortable seeing the leafs like this:
    Jensonbt likes this.
  18. Feb 9, 2022 at 10:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    literally just have to undo the U bolts and your there, then just a 14mm or 9/16 depending on the bolt and hit it a wrench. I would use a gun as you can zip it off.
    none of your leafs have the retaining U still?
  19. Feb 10, 2022 at 8:09 AM
    m3bassman
    Green truck
    No someone cut then off in Wyoming years ago. I found some on Amazon I'll get ordered though, never thought to look for them before.
    Also here's some photos from my trip to the races. Didn't take all that many pictures, mostly used my phone.
    2022-02-09_09-20-59.jpg 2022-02-09_09-21-03.jpg 2022-02-09_09-21-07.jpg 2022-02-09_09-21-11.jpg 2022-02-09_09-21-26.jpg 2022-02-09_09-21-33.jpg 2022-02-09_09-21-44.jpg 2022-02-09_09-21-58.jpg
    Blackdawg[QUOTED][OP] likes this.
  20. Feb 10, 2022 at 7:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm pretty sure you will change the property of the spring by welding it.
    Speedytech7 and jubei like this.
