Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 26, 2022 at 4:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There were large organized training sessions for volunteers on the weekends for a few weeks leading up to it. Which a lot of people participated in.
    BossFoss[QUOTED] likes this.
  2. Feb 26, 2022 at 4:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No but I need to I think in both trucks.
    Digiratus[QUOTED] likes this.
  3. Feb 26, 2022 at 4:40 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    I need to put a new ps pump in my Tacoma, the last NAPA one completely died after 15k, what’s the general consensus? Is OEM worth it at 4 times the price?
  4. Feb 26, 2022 at 4:44 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Sure its noble to stand up to bullies, but the world is not that black and white. Our involvement in WWII was not standing up to "do the right thing", our hand was forced on December 7th, 1941. The rest, as they say, is history.
    I would argue we are "standing up" as you will, as are other nations offering what aid they can. No one wants to see the events that are unfolding but from a risk assessment perspective, no country wants to take on the risk of nuclear war on their own soil. The scary question is, how many Americans is it acceptable to lose by "doing the right thing"? 10? 1000? 1,000,000?
    I never said never in my posts, that was a stretch you made. At this point, as in the current situation, we are picking the lesser of the two evils.
    I think we both agree the situation sucks, and that the aggressor is a lunatic. We seem to disagree about the actions taken on our side of the fence and yes, we can certainly disagree on that :) ill just give you some extra shit at the next campfire.
  5. Feb 26, 2022 at 5:02 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Utah doing it’s part :rofl:
  6. Feb 26, 2022 at 5:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Unknown, but I am guessing OEM is the way to go.
    Mine is OEM but the pump whine I am starting to hear is probably indicating it's days are numbered at 225K. It does not appear to have been caused by a clogged screen. :annoyed:
  7. Feb 26, 2022 at 5:23 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    My OEM died around 180k, the NAPA crapper whined from the start, I should probably just spend the money.
  8. Feb 26, 2022 at 6:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think they sell a rebuild kit for it and is the way to go. Can't remember.
    But yes OEM pump for sure over the part stores ones.
  9. Feb 26, 2022 at 6:18 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    @Blackdawg
    Can you explain how that center lock works on that transfer case you have? I've been curious how it helps exactly
    Edit. Never mind, found a post on a 4runner forum that made sense of it.
  10. Feb 26, 2022 at 7:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah would have linked to that post probably.
    Just allows power to slip at the tcase to the diffs. Which allows tight turns. And better grip in rain and snow generally.
    4wd can cause under steer to happen in those conditions while turning.
  11. Feb 28, 2022 at 9:58 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Obv with the senseless loss of life, the waste of money, which is just made up anyway, but the waste of resources is equally frustrating. Like, we are trying to reduce global emissions by 20whatever to avoid further climate temperature increases, and here we are all sending thousands of tanks and choppers and planes and destroying shit we will have to use even more resources to rebuild, and for what? Just such a god damn waste of everything
    jubei and turbodb like this.
  12. Feb 28, 2022 at 11:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    But think of all the jobs it will create!
    Jensonbt and IDtrucks[QUOTED] like this.
  13. Feb 28, 2022 at 1:20 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    That will probably be a campaign ad in the future
  14. Feb 28, 2022 at 2:23 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I, for one, am resting easier knowing that Lockheed Martin, Raytheon, and Northrop Grumman are all going to be just fine now.
    I was really worried about them before this latest version of forever war kicked off!
  15. Feb 28, 2022 at 3:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Probably already started somewhere..
  16. Mar 1, 2022 at 4:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am not sure how long a good quality AGM type battery is supposed to last. Also not sure if having it in a dual battery configuration will make a difference. I suppose it can vary greatly, depending upon factors like the number of deep discharges and how hot the normal working conditions are. In any case, for the first time in 5 years of use, I've begun to notice a change in the charging behavior of my group 24F Northstar batteries.
    So I began poking around, looking at options and pricing and started noticing the atteries I have are kind of hard to find. And the listings I do find list them at very high prices. Like $450+ for the same battery I bought for $275 not all that long ago.
    Then I came across this quote:
    FWIW, EnerySys is the parent company for Odyssey Batteries. Apparently, this is not recent news. :oops:
    https://www.northstarbattery.com/enersys-aqcuires-northstar
    I guess the good news is that a good quality group 24F AGM is still available and at a reasonable price.
  17. Mar 1, 2022 at 5:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What kind of behavior is happening to make you want new batteries?
  18. Mar 1, 2022 at 7:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @turbodb Thanks again for doing the SAW rebuild with me. Was pretty enjoyable work really. I did the spherical bearings today, man were those shot.
    Digiratus likes this.
  19. Mar 1, 2022 at 7:15 PM
    m3bassman
    Green truck
    What is the condition of your stock stuff, wore out?
  20. Mar 1, 2022 at 7:21 PM
    Speedytech7
    It works, still damps and holds the front up albeit not very high. Dan has my old Billies and Eibachs that don't damp much anymore but have strong springs. What's up?
