Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 14, 2022 at 4:07 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Thanks!
    So the seal I will get from Toyota. For the flywheel - I don't know much about brands or if there are differences/tradeoffs, etc. Are they all "the same" and it's just about price, or is LUK better than Toyota, Does one offer different performance characteristics, etc.?
  2. Mar 14, 2022 at 4:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Toyota one will be more expensive. They're pretty much like brake rotors, just as long as they're flat and the same weight it'll be the same no matter who made it.
  3. Mar 14, 2022 at 4:12 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Unless you specifically wanted to get one with a different weight.
    Guessing Dan will want to stick with factory though. Also, if you could make it work when you're in the middle of that job, I would rather have the OEM one machined, than install a cheap aftermarket one.
    turbodb and Speedytech7[QUOTED] like this.
  4. Mar 14, 2022 at 4:12 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I had fitment issues with my LUK flywheel, but I believe that's exclusive to the 4cyl.
    Just ended up going to orielly's and getting their "power torque" brand or whatever and it's been fine.
    As long as the weights are the same as OEM, it'll have the same characteristics. A heavier flywheel would make the truck rev slower due to the increase in rotational mass it has to turn around. Opposite for a lighter one
  5. Mar 14, 2022 at 4:13 PM
    Speedytech7
    The machine shop I'd take it to won't be open on a weekend... but the Napa down the street grinds em I think. I can find out
  6. Mar 14, 2022 at 4:15 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Depends on your time/value. Cost savings are not worth the time to drive it to a shop, wait for it to get machined, and drive home. Shit, if we take Zane's land cruiser it's a wash just in gas prices.
  7. Mar 14, 2022 at 4:16 PM
    Speedytech7
    I live a mile from two Napas but I have the Corolla so we might come out on top
    Squeaky Penguin likes this.
  8. Mar 14, 2022 at 4:17 PM
    Squeaky Penguin
    Brett
    I honestly would pay more to have the OEM one machined vs installing one of the shitty cheap ones.
    turbodb and BossFoss like this.
  9. Mar 14, 2022 at 4:19 PM
    Speedytech7
    I've done both, there are some good third party brands, Sachs and Luk are fine and have always been balanced well. But AMS I'd stay away from. Have a Nissan with an Oriellys (cheapest shit avail) flywheel that works fine with a high performance clutch holding over 700lb ft of torque.
  10. Mar 14, 2022 at 4:22 PM
    Squeaky Penguin
    Brett
    I'm sure it's hit or miss. I've just read of all sort of issues with them, from out of balance, to starters not engaging, etc. and there's no reason not to machine the factory one unless it's completely trashed.
    I get the convenience factor, but removing the trans again to replace shitty parts isn't convenient. :rofl:
    BossFoss likes this.
  11. Mar 14, 2022 at 4:24 PM
    Speedytech7
    RIP Monte...
    Yeah, honestly we could have Dan's ground, this isn't a stepped flywheel anyway so anyone should be able to do it. I'm in the industrial area, someone's bound to be open
  12. Mar 14, 2022 at 9:21 PM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Best part about a 1st gen clutch is the slave unbolts so you never have to bleed the system!
    I've swapped 2 trans in my truck the last 2 months and never bleed the clutch.
    Speedytech7 likes this.
  13. Mar 14, 2022 at 9:31 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I did a clutch in a 2nd 4r a few months ago by myself and it took me about 10 hours. If you have it machined, Marlin has a recommendation on the step height that I've been happy with. Can't remember what it is off the top of my head though.
    turbodb[QUOTED] likes this.
  14. Mar 14, 2022 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It is a stepped flywheel. And needs to have a .5 mm step to be in OEM spec.
    Nice. MC was leaking so I rebuilt it and the slave. Don't think I've gotten all the air out if the system or something else is wrong. Slips all the time. Brand new lce performance kit.
  15. Mar 14, 2022 at 10:01 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I very much value getting in there and doing this once rather than having issues, if for no other reason than I like to get out on trips as much as possible and spend as little time possible wrenching (because I spend a lot of time on just general maintenance stuff with how many miles I put on the truck).
    From that perspective, since this is a "once every ~220-300K" item (doing the clutch), I'm a bit price insensitive. The OEM flywheel is pricey - $486 - so 10x the cost of the Luk, and maybe a similar 10x to getting the OEM one ground.
    In my ideal world, I'd get the OEM one ground at a reputable shop, since I like the idea of not "wasting" something that can be made good relatively easily, but I also don't want to end up getting it ground "cheaply" (by some place Zane doesn't really trust) only to find out that I'm doing the job again. Given all that, should I just not care and chalk it up to a few tanks of gas either way? Seriously. I'm going to spend half that just driving to Zane's from home.
    Maybe I get an OEM one, then get the old one ground (at the good shop that's closed weekends) for future reinstallation?
    And... go! :)
    Speedytech7[QUOTED] likes this.
  16. Mar 14, 2022 at 10:20 PM
    Speedytech7
    You already know what I think ;)
  17. Mar 14, 2022 at 11:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    why? You planning on keeping this truck another 200k+? I doubt it.
    Or burning up your clutch and destroying your flywheel? I doubt it.
  18. Mar 15, 2022 at 12:01 AM
    Speedytech7
    Considering how fast he went from 60k to 2xxk, that might not actually be all that long from now
  19. Mar 15, 2022 at 12:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nah. It'll have rattled apart is some other major way by then IMO. 400k with half that on bumpy roads at speed? Core support will go for sure. Body mounts maybe. Bed sides. It is inevitable.
  20. Mar 15, 2022 at 3:59 AM
    Reh5108
    Idaho
    Find a fly wheel in a junkyard and have it resurfaced. Recycle, the power is yours.
