Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 15, 2022 at 6:40 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Price insensitive? Then just take it to Toyota and have them replace it all with OEM parts. :rolleyes:
  2. Mar 15, 2022 at 7:24 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    At my current rate, it'll be 4-5 years. On the edge of possibility for sure.
    I am worried about this.
    Do I need to worry about them getting messed up in some way other than just needing to be resurfaced? Part of what I'm looking for is reliability, part is convenience and timing. And, are all the flywheels (for the V6 M/T) the same? (having just gone through the transfer case thing, where they aren't)
    I also like doing things myself. Price insensitive to parts, maybe? :rolleyes:
    Edit: Also, is there much to worry about with getting a used one and grinding it, vs. getting a new one? As in, how does "wear" work on a flywheel - is it just some surface that wears unevenly? Is the entire thing under stress and so there's benefit to a new one?
  3. Mar 15, 2022 at 9:07 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Sounds like your pedal free play is adjusted wrong. That's the easiest system to bleed because it's so simple. Or you nicked the plunger on assembly.
  4. Mar 15, 2022 at 9:38 AM
    m3bassman
    Green truck
    My oem flywheel had visible hot spots on it. It is also possible for flywheels to develop hairline cracks. The surface gets heated every time you change gears so I decided to take no chances (or gamble according to Brett) with the LUK.
    turbodb[QUOTED] likes this.
  5. Mar 15, 2022 at 10:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah fair. your aren't abusing the clutch with the kind of driving you do a lot. At least not by doing tons of harder crawling.
    You should be haha not to be "morbid" but we have all seen what happens to these trucks with lots of abuse. And you're racking up a LOT.
    Nah the free play is fine. I think there is air still in the MC right now. Nothing is leaking.
  6. Mar 15, 2022 at 4:08 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If you had a hydraulic problem wouldn't you have an issue with disengaging only?
    Which reminded me - I would swap in a steel braided clutch line Dan.
  7. Mar 15, 2022 at 4:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :notsure:
    I have no idea what else it could be. Everything else is brand new and i know its not wrong this time.
    I've read a bad slave can cause issues too so I might get a new one, and do the steel breaded line at the same time.
  8. Mar 15, 2022 at 7:45 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Any of you 1st gen homies have experience with old Camburg 2.5" C/O's? Looking to buy a set for $750 and wanted some input. Fresh rebuild on 13" 650lb Icon coils. I know Camburg had sold that C/O design to Sway-a-way or something along those lines and now AFE. @TMFF ever messed around with these at all? Appreciate it! Posted in here as there are many knowledgeable 1st genners lurking in here.
  9. Mar 15, 2022 at 7:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think camburg came after swayway.
    They don't have the fixed top hats do they? Otherwise they will be just fine with a good rebuild I'm sure.
    That said after a rebuild you aren't that far from a brand new set at that price. Although I know wait times on most coilovers is very high.
  10. Mar 15, 2022 at 8:25 PM
    TacoVio
    Kolton
    CO/WY
    Not a fixed top. Pinned top so it has that flexibility. They are already rebuilt as well. No use since the rebuild. So $750 ready to throw on and good for another 30k+ or until I finish building this HP Dana 44 or go LT lol...:spy:
  11. Mar 15, 2022 at 8:42 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I got a set that I used on my truck since 2005 with many rebuilds and revalves along the way. ANY red coilover with camburg on it is a SAW. Hell I have short 8" Kings that have Camburg etched into the coilover top hats!
    Buy them and run them! The only thing I would do is put 14x650 springs on them if your are lifted high or lots of added LBS up front.
  12. Mar 15, 2022 at 8:51 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Zane and I just rebuilt his SAWs and it was super easy. Easier by far than ADS and King, and the internals looked nearly identical from a functionality perspective. Like everyone else says, sounds like you're good to go.
    We did put the 14x650 springs on them to replace what was on there.
    Speedytech7[QUOTED] likes this.
  13. Mar 15, 2022 at 8:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    fuckin send it!
    if the coils are fine id just run em to save the $100 but 14x650s would be better.
  14. Mar 15, 2022 at 9:31 PM
    TacoVio
    Kolton
    CO/WY
    Sweet. My truck is becoming a pig up front with the relentless plate bumper, winch, and hopefully skids soon. Those top hats still the king blue even? Thats wild they are camburg lol. Yea I was surprised that they arent 14" anyways as the 14X650 is a common combo. Thanks for the insight! Appreciate you!
    Seems I may do 14x650. Ill have to get em on the truck and go from there. As I dont want to preload that stiffer spring too much.
    Very torn between 3-link SAS and LT, gonna be a bit of custom work to keep a lcog with SAS. But the MCM kit is enticing for sure! Essentially bolt on and rip it!
    Speedytech7 likes this.
  15. Mar 15, 2022 at 9:44 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    You're not preloading them, your just adjusting where they sit on the shock. I'd run em and see where your at.
    TMFF and Speedytech7 like this.
  16. Mar 15, 2022 at 9:47 PM
    TacoVio
    Kolton
    CO/WY
    Gotcha! Thats the plan. I have an old set of toytecs on now. Adjustment collars are froze and they are cupping my front tires. Time for them to go and upgrade to these.
  17. Mar 15, 2022 at 10:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I wouldn't hesitate to run em, SAW was its own company, then Camburg licensed the design to brand as their own, and then aFe bought SAW. But the design is the same and all parts are available still. As Dan (@turbodb) said, their design is just like King (shares parts with king) and ADS. Easy rebuild, I'd assume they're probably good to go for a while even with the slightly shorter springs. Should still work well.
  18. Mar 15, 2022 at 10:19 PM
    TacoVio
    Kolton
    CO/WY
    Wicked. That was one of my main concerns, parts availability. But as mentioned now, they share parts with king and ADS so that's not worrisome anymore. Appreciate it buddy!
  19. Mar 15, 2022 at 10:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    pretty much all the early CO's ran 13'' spings. Think Foxes still do and maybe icons too.
  20. Mar 15, 2022 at 10:21 PM
    TacoVio
    Kolton
    CO/WY
    Interesting. Yea the coils on em now are ICON anyhow.
