Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 27, 2022 at 8:31 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It's a vibe.
    TacoVio[QUOTED] likes this.
  2. Mar 28, 2022 at 5:44 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    lol. youve outdone yourself this time
    Squeaky Penguin likes this.
  3. Mar 28, 2022 at 5:49 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    His next truck
  4. Mar 28, 2022 at 6:53 PM
    m3bassman
    Green truck
    No the logical step is earth roamer.
    Jokes aside we actually were close to pulling the trigger on a diesel with a slide in 4wheelcamper. It would have saved some money but what ended up being a deciding factor was that in such a setup the living space is separated from the driving space. So you can only use one at a time. With the van setup both are integrated so you have a lot more living space at the end of the day. Time will tell how much I handicapped us with such a large truck on the trails.
    Speedytech7 and TacoVio like this.
  5. Mar 28, 2022 at 7:05 PM
    JKO1998
    Utah
    I’m all about the camper trailer life. But with my hobby’s I’m fine with finding a nice camp spot and setting up shop for a week or two.
  6. Mar 28, 2022 at 8:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's the departure angle that's going to get to you.
  7. Mar 28, 2022 at 8:48 PM
    m3bassman
    Green truck
    Big time :oops:
    Digiratus[QUOTED] likes this.
  8. Mar 28, 2022 at 9:02 PM
    m3bassman
    Green truck
    But I did order some 285 Nittos for it today :anonymous:
    TacoVio likes this.
  9. Mar 28, 2022 at 11:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    lame. wheres the 37s
    Jensonbt likes this.
  10. Mar 29, 2022 at 6:02 AM
    m3bassman
    Green truck
    Right behind your long travel :stirthepot:
    Can't go much bigger really without moving the front axle forward on this setup.
  11. Mar 29, 2022 at 9:08 AM
    Digiratus
    Roaming the PNW
    The RedHead
    FTFY
  12. Mar 29, 2022 at 9:11 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    x2. its a 7.3, 35s minimum man. itll turn em no problem!
    send those 285s back
  13. Mar 29, 2022 at 10:03 AM
    m3bassman
    Green truck
    I need to do more research on it. Kinda felt like 70mph was top speed for it. Engine was at 2700rpm-ish. So a regear wouldn't be great in that regard if I'm truly on 3.55 gears. But semi related would be to find a FF D60 for the rear.
    Lol also limited by wheel width. So that's a no. Was gonna stick with 265 but the manager at discount tire convinced me to step up. Hope it's limited trimming...
  14. Mar 29, 2022 at 10:23 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    2700 at 70? How much does that van weigh? Even with a heavy van that seems like a horribly high rpm for that mileage and (relatively) light weight?
  15. Mar 29, 2022 at 10:30 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's a sign that it wants bigger tires!
  16. Mar 29, 2022 at 10:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    10,000lbs or more
  17. Mar 29, 2022 at 11:33 AM
    m3bassman
    Green truck
    I could be misremembering but the engine feels happier at 65 than 70+ like my wife was cruising at lol
    Haven't gotten it in the scales but it's around that.
  18. Mar 29, 2022 at 8:52 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    That speed and RPM almost has me thinking your OD was off...when im pulling anything on the highway im fighting to keep it 75+ mph so I stay in the boost and keep EGT's down. Which is around 2k RPM in 4th/OD. Unless that thing is geared pretty high. Im running 3.73s with 35s. And I know even 4.10's on stock 265s doesnt do 2700 RPM at 70mph. Thats interesting. It wouldn't surprise me at all if it was 4.56+. It would turn 35's with ease right now.
  19. Mar 29, 2022 at 9:35 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    That was my first thought when I read it, but then I was like, " I'm sure he's thought of that"
    TacoVio[QUOTED] and m3bassman like this.
  20. Mar 30, 2022 at 7:12 AM
    m3bassman
    Green truck
    No I'm just a goof. Drove it today and it hums at 1980 at 70mph. There may be a speedo error, I haven't gps compared it yet but will on the commute home. Certainly will be error once the 33s go on. Once I get a floor jack that can lift the rear axle I'll verify the 3.55 gear set in it.
    One question I have, it got down to the mid 30s last night. Fired up like a champ today but I was expecting a voltage drop when the glow plugs are on. I don't notice any drop though. Is that normal?
